Old 02-20-2010, 13:44   #1 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
MX-KEY and JAF at same pc
Can we use jaf and mx key at same pc. Is there any dangur for damage p key or mx key.
Old 02-20-2010, 13:59   #2 (permalink)
Ramzan khan's Avatar
Member: 405696
Thanks Meter: 148
dont know but i use both jaf and mx key in 1 pc from last 1 month and no problem.but mx is best just use jaf interface and flash and unlock with mx key
great tool then jaf.
Old 02-20-2010, 14:03   #3 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 397
mx and jaf were all the best device since last update of jaf.........
but as they release {jaf team} their update jaf works fcuking and when i use jaf i have to close all e gate driver first then im able to use jaf
soo it is my conclusion that dont use jaf only use mx with jaf box{old firmware 1.b1}
Old 02-20-2010, 14:07   #4 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Thanks to both persons. But i want answer from product supporter is they dont mind.
Old 02-20-2010, 14:09   #5 (permalink)
higherzman's Avatar
Member: 45387
Thanks Meter: 53
yes i confirm u can use it both in the same pc
salem
Old 02-20-2010, 14:30   #6 (permalink)
Service4Gsm.de's Avatar
Member: 811992
Sonork: 100.1584257
Thanks Meter: 162
Whom the two are functioned not installed can you only MX keys use Jaf!
Old 02-20-2010, 16:01   #7 (permalink)
Member: 113442
Thanks Meter: 9
sir i also have this type of problem, i use mxkey or jaf pkey only one at a time. when i connect both jaf and mxkey both not functioning. one more problem every time when i restart my pc i have to remove mxkey and reinsert then i able to use.
if anybody know solution pls reply.
regards.....
Old 02-20-2010, 16:36   #8 (permalink)
higherzman's Avatar
Member: 45387
Thanks Meter: 53
regards.....
try this way
-uninstall both of drivers ''rockey200 and pkey driver''
-remove all smartcard present in device manager
-restart pc
-reinstall rockey200 driver
-put mxkey dongle and let it be full install
-remove mxkey and put pkey without installing pkey driver
-it will detect it well and in the end will give u problem conlict
-restart computer
-now use mxkey and pkey at same pc
salem
The Following User Says Thank You to higherzman For This Useful Post:
Old 02-20-2010, 16:41   #9 (permalink)
deann's Avatar
Member: 765331
Thanks Meter: 78
Arrow
Originally Posted by higherzman View Post
try this way
-restart pc
-it will detect it well and in the end will give u problem conflict
-restart computer
salem
How u can use it both if have problem conflict???...
Old 02-20-2010, 16:50   #10 (permalink)
higherzman's Avatar
Member: 45387
Thanks Meter: 53
when u restart computer all will be fine no more conflict
salem
Old 02-20-2010, 16:51   #11 (permalink)
faurionutz's Avatar
Member: 607365
Sonork: 100.1590583
Thanks Meter: 294
I'm using mx-key and jaf with zulea crack on same pc without any problem
Old 02-20-2010, 16:54   #12 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 397
salem
yes he is right do as he said
The Following 3 Users Say Thank You to klmamn For This Useful Post:
Old 02-20-2010, 16:58   #13 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
Yes you can use it w/o any problem.
Happy now w answer from product supporter?
BR,
Manole
The Following 3 Users Say Thank You to MANOLE For This Useful Post:
MX-Key and P-Key on same machine ..::SuB::.. The Market Feed Back 9 03-29-2010 10:54
How to use MX Key and JAF Pkey software in same PC? tigran80 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-13-2010 09:17
ROM ID: 4B9B75103E691FF8 flashing with mx key and ufs or jaf mentholflash MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-10-2010 18:49
Mx key supported some features same as cyclone Mr.3. Cyclonebox 11 07-08-2009 21:10
im new user in mx key not open soft my pc ankur_rani143 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 04-28-2009 02:22
Page generated in 0.21670 seconds with 10 queries
