Old 02-08-2011, 08:45   #1 (permalink)
Member: 200541
Mx key - LOADER NOT RESPONDING
loader not responding (0910000000B172)
Flashing terminated with error(s) in 7 min 50.141 s
RX Buffer: 0910000000B172
any solution for this.
it will appear like this whenever i flash any phone.
i've tried 3.4 rev 1.7 and rev 1.8, its same.
thx for info....
Old 02-08-2011, 11:25   #2 (permalink)
Moderator
Nizda Mobile's Avatar
Member: 1464783
Thanks Meter: 1,091
thx for info....
post full detail and what interface you use?
Old 02-08-2011, 11:28   #3 (permalink)
Member: 1051053
Sonork: bluesoic
Thanks Meter: 39
Use manual config, & choose another loaders...
Old 02-08-2011, 11:50   #4 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
what type of phone? it can be cable problem, or u just change using hwk...
Old 02-08-2011, 13:25   #5 (permalink)
sunny box's Avatar
Member: 1456392
Sonork: 100.1606104
Thanks Meter: 115
use thae ufs interface...
Old 02-09-2011, 04:07   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
is your cable with other flasher working good?
The Following User Says Thank You to gbluez For This Useful Post:
Old 02-09-2011, 04:14   #7 (permalink)
allentelecom's Avatar
Member: 200633
Thanks Meter: 59
check your cable and used HWK interface
Old 02-21-2011, 10:32   #8 (permalink)
Member: 1191
Thanks Meter: 128
Nokia N73 - can't flash with MX-KEY and UFS interface.
i try with 1.6 and 1.8 same problem.
this is lod:
Version from phone: 05wk47v61.1
Version from file: 4.0839.42.2.1
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011)
Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35185101000591_BA CK.rpl).
Processing MCU file: N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx
[BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 48.99 MB
Supported Ids: 0103192101003000, 010C192101003000
Supported Ids: 17100708
APE Data :
SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
ASIC MODE ID: 00
PUBLIC ID: 88156D2C55A1CA36F890247A1B4CBE8BEBBBCE7A
ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B21
PUBLIC ID: 12900206648B0054004CA461E6CE99640073C9B4
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 10.6.0 revision: 0.0 size: 0x3C40
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.28.0 revision: 0.0 size: 0x23220
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
TransmissionMode: DDR&TX2
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
i try with config:
- unmark Autoselec loader
- select one from 3 loaders, but when try to flash phone not see difference in LOG.
how to flash N73 or other mobile with this problem 0910000000B172 ?
i read many post with this problem here in forum. but not find solution.
ant answer with working solution from MX-KEY support will be good.
Old 02-21-2011, 10:41   #9 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
i m also have this problem use ufs and hwk both give same error
loader not responding and looking solution from 6 month butt no luck
mx-key is only unlocker for me not a flasher.
this will be great if mx-key team solve this via teamviever
thanks
Old 02-21-2011, 11:02   #10 (permalink)
Member: 1191
Thanks Meter: 128
thanks
JAF version 1.9cccc
Detected PKEY: 90ccccccc
Card life counter: 47.12%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B1, Driver version: 20422, Library version: 30119
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.1.36.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Phone Type:
MCU Flash file: D:\Nokia\Products\RM-133\N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx
Phone Type:
PPM Flash file: D:\Nokia\Products\RM-133\N73_rofx_4.0839.42.2.1_PRD.V05
Languages in ppm: English,German,Ukrainian,Russian,Romanian,Bulgaria n
Phone Type:
CNT Flash file: D:\Nokia\Products\RM-133\N73_userarea_4.0839.42.2.1.U02
Manual mode selected, version can't be checked!
Booting phone...
APE Boot Data:
Asic ID: 17100708
Asic Mode ID: 00
Asic Public ID: 88156D2C55A1CA36F890247A1B4CBE8BEBBBCE7A
CMT Boot Data:
Asic ID: 000000010000022600010006010C192101003000
Asic Mode ID: 00
Asic EM ID: 00000B21
Asic Public ID: 12900206648B0054004CA461E6CE99640073C9B4
HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg
Loader version: 01.23.00 -> Revision: 0000
Patching APE boot step1...
Patching APE boot step2...
Patching APE boot step3...
APE Boot Ready
APE Flash ID: 00A100EC <=> SAMSUNG (SEC) -> K5E1G12ACM
APE Flash Data: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
APE Loader: C:\Program Files\ODEON\JAF\Flash\h3_sam_nand_xsr.fg
Loader version: 01.2F.00 -> Revision: 0000
Patching APE loader step1...
Patching APE loader step2...
Patching APE loader step3...
APE Loader Ready...
Operation took 0 minutes 5 seconds...
Sending CNF Data...
Erasing...
I flash this N73 with MT-BOX and with J.A.F. w/o problem.
but what is the problem in MX-KEY to can't flash N73 and other simmilar mobiles ?
Old 02-21-2011, 13:25   #11 (permalink)
raselcox's Avatar
Member: 782943
Sonork: 100.1601067
Thanks Meter: 204
Originally Posted by gbluez View Post
hi,
Hello dude same problem with me and cable is absolutely good. Flash with another device is perfect but when try with mx 1.8 version its show that error.
Old 02-21-2011, 13:38   #12 (permalink)
Registered User
Member: 419331
Thanks Meter: 101
select other flash file on that time u r pc online otherwise u r hardware problam many time i face this problam but i am change flash files manual problam is solve try it
Old 02-21-2011, 14:16   #13 (permalink)
Member: 1191
Thanks Meter: 128
problem 100% is not hardware !
I am sure in that.
with J.A.F. I flash this N73 and mobile work w/o problems.
but if try to flash with MX-KEY every time get this error.
cable is 100% good. i test it with J.A.F. and with MT-BOX.
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-26-2000 14:31
Page generated in 0.29425 seconds with 9 queries
