Old 09-30-2011, 12:28   #1 (permalink)
adnan_taeki's Avatar
Member: 417778
Sonork: 100.1603326
Thanks Meter: 116
Mx key and Mx Boxnot detecting UFS box ## (ANSWERED)
hi,
i am using mx key and mx box boath of them not detecting UFS box
any one plz tell me the solution what to do
i did every thing i know , uninstall , reinstall mx software UFS drivers etc....
Regards,
Adnan Khaver
Old 09-30-2011, 12:36   #2 (permalink)
Member: 1627798
Thanks Meter: 164
if u have mx box why u need to connect ufs with mxkey sofware.......mxbox is ultimate and standalone for mxkey
The Following User Says Thank You to .::SAMRAT::. For This Useful Post:
Old 09-30-2011, 12:49   #3 (permalink)
Member: 417778
Sonork: 100.1603326
Thanks Meter: 116
Becouse mx box is not properly putting phone in test mode
Old 09-30-2011, 13:00   #4 (permalink)
Member: 417778
Sonork: 100.1603326
Thanks Meter: 116
i just want to know that the mx box detecting UFS ? or not if it is detecting then i have a problem in my pc i want solution , i try to resolve the problem but i am failed.
second is that the mx key is detecting the UFS and JAF but mx key is also not detecting.
Regards
Adnan Khaver
Old 09-30-2011, 13:17   #5 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Hi,
Install latest HWK support suite.
Regarding MX local/test
http://www.youtube.com/watch?v=E4zCmhL73oc
Old 09-30-2011, 13:33   #6 (permalink)
Member: 1664513
Thanks Meter: 4
You can give a try to this all you can do is install a supportive suite as it can bring the desired result in the right direction.
Old 09-30-2011, 14:06   #7 (permalink)
Member: 417778
Sonork: 100.1603326
Thanks Meter: 116
ok
i will tell you after checking
Old 10-01-2011, 11:51   #8 (permalink)
Member: 1657686
Thanks Meter: 13
Brother,
If you want to use UFS as interface, If you open any of UFS applications then close it. Restart MX Key , you can find UFS Sarasoft in MX Key Options.
Old 10-03-2011, 17:22   #9 (permalink)
Member: 1524461
Thanks Meter: 26
mxsoftware can detect only 6 to 7 ports only .
for example
no connection,
nokia usb,
hti usb,
ufs,
ufs,
communication port com1 ,
usb serialport com4
standard modem com34
potato flasher
if so many item are connected how it detect more then 7 items
so plese remove some items
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.18053 seconds with 9 queries
