05-08-2011, 03:24 | #4 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, hope this will answer to all C1-01 questions USB Flashing Code: MXKEY Serial: [MxKey HTI FLASHER INTERFACE 0] - C0696666 Driver: NMWCD, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 26212134 Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 2.3 EBL version : Quantum_Bootloader_2.3_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6500000 Flash ID: 00EC 3012 [Samsung ] Processing file: rm607__04.40.mcusw Downloading item CODE:rm607__04.40.mcusw_ebl_psi.fls, num block: 5, size: 25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.561 s Erasing area 0x40040000-0x4007FFFE ...OK Programming completed in 0.769 s Erasing area 0x40080000-0x4009FFFE ...OK Programming completed in 0.574 s Erasing area 0x400A0000-0x4019FFFE ...OK Programming completed in 1.919 s Erasing area 0x40400000-0x41B7FFFE ...OK Programming completed in 32.976 s Checksum verified (0xD471) Processing file: rm607__04.40.ppm_x Downloading item CUST:package_x.ppm_ebl_psi.fls, num block: 1, size: 4.10 MB Erasing area 0x41C00000-0x42019006 ...OK Programming completed in 6.005 s Checksum verified (0xBE9A) Processing file: rm607__04.40.image_x_0595594 Downloading item CUST:package_x_0595594.image.fls, num block: 1, size: 13.63 MB Erasing area 0x42200000-0x43E5FFFE ...OK Programming completed in 19.101 s Checksum verified (0x971B) Total time for flashing process(boot+erase+write) was 3 min 28.885 s Waiting for device boot up ... Device found: nmwcdc\Nokia C1-01 USB Phonet, PORT_ID: 434E537 Verifying communication to device OK. Phone Type: RM-607 (C1-01) SW Version: V 04.40 23-02-11 RM-607 (c) Nokia Imei plain: 35700904550046-9 Product Code: 059F0V3 Battery voltage: 3979 mV, current: 102 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! Imei net: 35700904550046 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Load market, do buscheck, service tab will be activated BR |
05-14-2011, 02:42 | #5 (permalink) |
Junior Member Join Date: Sep 2006
Member: 341635 Status: Offline Thanks Meter: 1 | @mr gbluez: do you try with normal phone or phone with security code problem ?? i have tried phone with security code problem,but didnt work.. MXKEY Serial: [FT SCR2000 0] - C0600F5C Driver: nmwcdnsuc, ver: 7.1.32.66, NTMP ver: Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1C82EDB WriteDevice failed: A device attached to the system is not functioning |
05-21-2011, 09:27 | #6 (permalink) | |
No Life Poster Join Date: Mar 2007
Member: 472378 Status: Offline Sonork: 100.1597506 Thanks Meter: 292 | Quote:
when we salect usb nokia usb rom then seves opption not open plaz tell mean who to open it | |
09-22-2011, 08:32 | #9 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: esat africa,tanzania,iringa
Member: 569063 Status: Offline Thanks Meter: 25 | Quote:
09-23-2011, 12:18 | #12 (permalink) |
Freak Poster Join Date: Mar 2011 Location: Do not want to tell you Age: 38
Member: 1538800 Status: Offline Sonork: Offline Thanks Meter: 18 | My English is poor, using the Nokia USB ROM port, you upload the picture, you can see Flash and Service. I uploaded the picture, only the Flash, no Service. I want to know the reason? Curious to ask |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
