06-16-2011, 15:46 | #1 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 381171 Status: Offline Thanks Meter: 52 | mx key not working after update 3.5 rev1.1 (ANSWERED) access violation error reinstall and delete mobileex.xml same problem |
The Following User Says Thank You to inaam143 For This Useful Post: |
06-16-2011, 19:00 | #3 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1359672 Status: Offline Thanks Meter: 8 | i have this same problem dude with a computer win xp based but i try in win 7 and work fine at all mxkey and mxbox ready to go |
The Following User Says Thank You to diamar For This Useful Post: |
06-17-2011, 05:50 | #4 (permalink) |
Junior Member Join Date: May 2007
Member: 503170 Status: Offline Thanks Meter: 3 | Im also facing the same issue as above and have the exact screenshot he have. If it is because of the OS that caused this interfaces not to work, then they should have atleast release a system requirements so that the users will not wonder. I tried reinstalling and installing and deleting the .xml files but still having the same error. I will try to install a lower version of V5.1.1 and post my reply also.. I will try xe_d_sono suggestion. thanks! |
06-19-2011, 02:56 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, delete mobileex dir, reinstall LAST version, don't forget to exclude it on your antivirus program. |
The Following User Says Thank You to gbluez For This Useful Post: |
06-19-2011, 03:38 | #6 (permalink) | |
Freak Poster Join Date: Dec 2008 Location: cebu city
Member: 920138 Status: Offline Thanks Meter: 97 | Quote:
06-19-2011, 11:39 | #8 (permalink) |
Freak Poster Join Date: Feb 2011 Location: mumbai mira road Age: 51
Member: 1524461 Status: Offline Thanks Meter: 26 | i have no problem this is created by our own mistake . fisrt install 3.5.1.1 mxkey setup . then update the box property then update minor updates also. blakberry nokia cdma now available. then un install ufs old setup & driver. install 2.2.00 support suite setup update box properly. now install main setup 2.2.00 if you have 2 ufs box then connect both box to usb before installing main setup box should be connected firt both box then install main set up. and now put your mxkey dongle in slow usb and mx box in fast usb and do usb flashing from another fast usb. now you mxkey will support box hti box and ufs box. better then before. |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
