Old 09-07-2009, 14:31   #1 (permalink)
UNLOCK PARK ®'s Avatar
Member: 1004001
Sonork: WhatsApp+971506319003
Thanks Meter: 448
Mx Key PMM Auth not working
BLOCK 1: 1=OPEN, DATA=23420F
BLOCK 2: 1=OPEN, DATA=23594F
BLOCK 3: 1=OPEN, DATA=23420F
BLOCK 4: 1=OPEN, DATA=23594F
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server ...MXKEY-Server v2.4 hello 203.188.244.180
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Br,
gsm_yousuf
The Following User Says Thank You to UNLOCK PARK ® For This Useful Post:
Old 09-07-2009, 19:30   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
can u post log info / bus check info ?
br,
Old 09-07-2009, 20:58   #3 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
may be u cant access SX4 server cause u have coruoted super dongle key in phone
how ever ,post bus check log info as mobileEX told u
wbr
The Following User Says Thank You to mohA™ For This Useful Post:
Old 09-08-2009, 15:53   #4 (permalink)
Member: 1004001
Thanks Meter: 448
br,
Using device: J.A.F, FW ver: 01.B1
APE Data :
SYSTEM ASIC ID: 17100701 [OMAP1610 ver: 1.1]
ASIC MODE ID: 00
PUBLIC ID: B9FA13DC08AA728B9808290B66E764AC50359F27
ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006000C192101002100 [RAP3G ver: PA 2.0]
EM1 ID: 00000232
EM2 ID: 00000341
PUBLIC ID: 0CD00109E182465107501BA78AF5699D357D16E9
ASIC MODE ID: 00
ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FAC901AEE
SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
FlashID0: 0001 0002 - 0000 0111 [AMD NA] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
FlashID0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: NAND,APE
ALG [35]: OMAP1610 GBBM-1.8.1 ALG
ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000
Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908
APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
Original Imei: 35566000355222
Original Product code: 0524479
Bluetooth ID: 001262F81B10
Phone Type: RM-84 (Nokia N70)
SW Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia.
Imei plain: 35566000355222-3
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
SIMLOCK_TEST passed
SECURITY_TEST passed
"RM-84" folder created.
Imei: 355660003552223
Version: SIMLOCK SERVER VERSION 58
Provider: Hutchinson 3G (3), Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2342000000000000
PROFILE_BITS: 0000000000000000
Old 09-08-2009, 15:57   #5 (permalink)
Member: 1004001
Thanks Meter: 448
Repair Sl Log
Counter: 0/3, 0/10
Backup already exist.
Sending bootloader, size: 0x3D00 ...
Calculating data ...OK
Receiving PM buffer, please WAIT ... OK
Writing PM buffer ... failed
Restarting phone ...
Reading Simlock info ...
Counter: 0/3, 0/10
Old 09-08-2009, 16:10   #6 (permalink)
Crazy Poster
Member: 571191
Thanks Meter: 10
I think this is U phone problem..SUPERDONGLE_KEY invalid!
The Following User Says Thank You to rizky_m For This Useful Post:
Old 09-08-2009, 16:54   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
please known your problem before punish working or not working.
your phone need RPL Calculation.
for repair that kind of problem
br,
Old 09-08-2009, 18:06   #8 (permalink)
..::Mr999::..'s Avatar
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,048
br,
its old N70 and i think possible to repair without rpl no ?
Old 09-08-2009, 18:18   #9 (permalink)
Member: 310155
Thanks Meter: 1,313
If SUPERDONGLE_KEY invalid !!!!
so............................................
How it's possible without RPL ????
The Following User Says Thank You to reaz.com For This Useful Post:
Old 09-08-2009, 18:22   #10 (permalink)
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,048
why we use repair SL in other softwares did not used mx key yet but as i know jaf bb5 unlocker doing . will check in office tomorrow in mx key unlocking TAB
Old 09-08-2009, 18:24   #11 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
for sure it work.. a matter with habbit
Old 09-08-2009, 18:28   #12 (permalink)
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,048
means of "a matter with habbit " :P
Old 09-08-2009, 18:32   #13 (permalink)
Member: 310155
Thanks Meter: 1,313
I think "SL repair" button cant repair "SUPERDONGLE_KEY"
Old 09-08-2009, 18:35   #14 (permalink)
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,048
try then talk Mr the tell work or no
Old 09-08-2009, 18:43   #15 (permalink)
Member: 310155
Thanks Meter: 1,313
Ok sir, i'll try tommrow.................
MX key PMM Auth error 5130 contact service Elshad Ngage MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 11-29-2009 19:31
pmm auth not working after 5.6 dat time king222 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 11-09-2009 13:47
pmm auth not working after 5.6 dat time king222 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 11-09-2009 12:39
MX KEY RPL server not working srinibas MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 10-31-2009 16:11
Mx Key PMM Auth not working AswanX MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 09-18-2009 22:21
Page generated in 0.25957 seconds with 9 queries
