12-23-2009, 11:05 | #1 (permalink) |
Insane Poster Join Date: Jul 2006
Member: 306677 Status: Offline Thanks Meter: 6 | mx key problem by register and software i have buy a mxkey dongle. have install latest mxkey soft. have registried my card username is berwan, after register card cant login in support site why? and when i open soft after 3 second closed self. what is problem please help me. wait of help and answer. best regard berwan |
12-23-2009, 11:33 | #2 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Indonesia
Member: 1169189 Status: Offline Sonork: 100.1591528 Thanks Meter: 94 | First thing is, You only have 3 seconds after program running so, when you select server support menu. It can't be done. And how to get registered if only have 3 seconds. Please, write down your questions correctly Mean you have registered and driver installed correctly, do you have installed antivirus or any debugger running in your system? If you can open the program then do refresh site list. Regards, |
12-23-2009, 11:41 | #3 (permalink) | |
Member: 306677 Status: Offline Thanks Meter: 6 | Quote:
what is there problem??? how can i solve this problem bro? | |
12-23-2009, 12:41 | #6 (permalink) |
Member: 1169189 Status: Offline Sonork: 100.1591528 Thanks Meter: 94 | Maybe this is will clear for you... I can open mobileEx without MXKey plugged. So try to re-installed and delete manually if there's still any folder/files within that folder. Remember to backup your signed file XML. If you already try clean install and problem still exist, try to lookup your system environment, maybe there's any apps that cause this problem. Regards, |
Error install mx-key in win 7 and xp mode | suarezfco | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 01-24-2010 03:33 |
MX-key can not register | abdin | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 10-21-2009 15:18 |
