02-09-2010, 14:28 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: UK , london
Member: 292640 Status: Offline Thanks Meter: 18 | N85 problem PLEASE SEE LOG Code: RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 18B0010912C20158A488211DC182C96F818C55B9 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: B5385A493D2188678E1FD88DA506480F874E2949 Reading RAP NPC (0x190 bytes) Begin Certificate Request ... Connecting to server ...OK, Login ... ERROR: No certificate found in the database ! Code: Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! TimeStamp: 2009-11-11T13:22:14+00:00 SW Version: 31.002 Variant Version: 001 ProductProfile: Simlock: simlock_3gstandard_bb5.bin Imei net: 355708022774706 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-09-2010, 16:40 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: india
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 318 | same problem ---------------------- Phone Type: RM-333 (Nokia N85) SW Version: V ICPR72_09w18.6 15-10-09 RM-333 (c) Nokia Imei plain: 356**********-4 Product Code: 0569331 ApeCoreSw: 31.002 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35************ Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-10-2010, 01:58 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | if u try with searching button , u will have same answer 1.do SX-4 and write PM without [308] area in case after Superdongle repair , please use "SUPER SD Auth" 2.Check BB5 Secure Validation [MXKEY - INFO] !!! NEW magic button inside mxkey !!! this is have important info, where the real problem 3.if "Recover CERT" doesn't work ?? Code: Begin Certificate Request ... Connecting to server ...OK, Login ... ERROR: No certificate found in the database ! Just in case if Recovery via Server doesn't work....... need more file about CCC,HWC and VARIANT [MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair br, |
n85 problem | masterspargo | Nokia Hardware & Hardware Repair | 22 | 12-20-2010 13:18 |
please help me, n85 problem | mele5 | Nokia Base Band 5 ( BB-5 ) | 4 | 10-09-2010 09:31 |
Nokia N85 problem !!!!!!! | k2cause | Cyclonebox | 39 | 02-22-2010 15:24 |
please- n85 RM-333 - HWC AND CCC DATplease- n85 RM-333 - HWC AND CCC DATA | GSMSAMI | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-18-2010 18:27 |
