MX-KEY server solution 100% working 7 Step Mxkey Server ON Do As directed: 1. Uninstall all the previous versions including v 3.4. 2. Delete manually The directory c: mobileEx 3.x. 3. Search in c drive for mobileex*.* 4. Delete all the files. 5. Install mobileEx 3.4 again. 6. sign application. 7. You are ready to go. |
just open mobile.xml with notepad and change this line PHP Code: PHP Code: Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 |
i am newly installed in new update 3.4 but its already like ..<blade host.1="host2.mxkey.biz"/> no need to edit... |
Black_Attack solution is worcking thx man |
Blade server #1 US Blade server #2 EU Blade server #3 EU Blade server #4 ID no need modify any file. |
thanks work ok 100% server2!!!!!!!!!!!!!!!!!!!!!!!!!!111 |
Help me mx key team |
Help me step by step sir...???? thanks |
Woooorking 100% now !!!!! ;) |
yes sir's is big solution |
its worck since yesterday by this solution.... |
ok.......................... |
How can you select a server if no server on the list? When I click Server List no server appears.. TESTED WORKING: Quote:
