Old 02-13-2014, 12:23   #1 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,146
Mx key is still best tool for me .
Nokia c2-01 flashing failed on bb5 best tool but done by mxkey without any problem .
BB5 best tool
How to solve this problem.
Solved by Mxkey.
Processing MCU file: rm721__11.40.mcusw
[BB5,XSR 1.6] size: 28.58 MB
Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x]
CMT EM0 ID: 00001051
CMT EM1 ID: 00001060
CMT PUBLIC ID: 2350020D602256406CFFE0EC451B7BAA76913C8B
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
CMT ROM ID: 67E82268F29CEA60
Loading CMT secondary boot code
SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 12.8.0 revision: 3.0 size: 0x3AC0
Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 12.8.0 revision: 3.0 size: 0x9AEDA
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1390F6B7
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 37.69 MB
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-0009FFFF]
CMT FLASH,MuxOneNAND area [000A0000-0025FFFF]
CMT FLASH,MuxOneNAND area [003E0000-005DFFFF]
CMT FLASH,MuxOneNAND area [005E0000-010DFFFF]
CMT FLASH,MuxOneNAND area [01EC0000-01EDFFFF]
CMT FLASH,MuxOneNAND area [027C0000-02CBFFFF]
CMT FLASH,MuxOneNAND area [077C0000-07B3FFFF]
CMT FLASH,MuxOneNAND area [010E0000-01EBFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 8443ECD5 [] sent
CMT RAP3NAND block sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 1 min 0.328 s
Processing PPM file: rm721__11.40.ppm_meac
[BB5,XSR 1.6] size: 5.81 MB
Erase size: 8.87 MB
CMT FLASH,MuxOneNAND area [01EE0000-027BFFFF]
Programming completed in 12.391 s
Processing CNT file: rm721__11.40.image_meac_059D644
[BB5,XSR 1.6] size: 16.68 MB
Erase size: 75.06 MB
CMT FLASH,MuxOneNAND area [02CC0000-077BFFFF]
Programming completed in 36.063 s
Total time for flashing process(boot+erase+write) was 3 min 18.328 s
Note. Best team ,i hope you never mind ,but this is true.
Regards
amn32
The Following 3 Users Say Thank You to amn32 For This Useful Post:
Old 02-13-2014, 13:36   #2 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,130
Yes I Agree With You Dear My Lab Most uses On This Box.
WBR.
Arsalan gsm2000.
Old 02-13-2014, 14:34   #3 (permalink)
sen george's Avatar
Member: 300529
Thanks Meter: 54
BB5 best tool
Solved by Mxkey.
Regards
amn32
WBR.
Arsalan gsm2000.
WOW really the legends solve my problem & more peoples r waiting this is my third box
Nokia gone from Mxkey
Old 02-13-2014, 15:00   #4 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,264
NOKIA ASHA 206 successfull BY [email protected]@ ATF FAIL infinity BEST fail
MXBOX GREEN
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C085DE08
Using device: USB Phonet  and HTI, FW ver: 00.50, SN: 0000F555
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: nmwcdnsuc, ver: 7.1.32.84
Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
 Boot mode: 0xCC
 EBL version major/minor: 10.37
 EBL version: Quantum_Bootloader_10.37_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
 Flash settings: 0/1024, size: 0x04000000
 1 Block regions:
  512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI:
RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD__back.RPL"
Processing file: FEBD2E18_rm872__04.52.mcusw
 Downloading item CODE:rm872__04.52.mcusw_ebl_psi.fls, num block: 4, size: 25.25 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.344 s
Erasing area 0x40040000-0x4005FFFE ...OK
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.390 s
Erasing area 0x40280000-0x41A7FFFE ...OK
Programming completed in 28.954 s
Checksum verified (0xFA4D)
Processing file: 3265D915_rm872__04.52.ppm_m2
 Downloading item CUST:package_m2.ppm_ebl_psi.fls, num block: 1, size: 3.78 MB
Erasing area 0x41A80000-0x41E468EE ...OK
Programming completed in 4.797 s
Checksum verified (0xC9E6)
Processing file: 81DD7A9E_rm872__04.52.image_m2_059Q8L5
 Downloading item CUST:package_m2_059Q8L5.image.fls, num block: 1, size: 16.25 MB
Erasing area 0x42100000-0x43E1FFFE ...OK
Programming completed in 25.156 s
Checksum verified (0xA5A8)
Total time for flashing process(boot+erase+write) was 8 min 36.578 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia X2-02 USB Phonet, PORT_ID: 356352055749241
Verifying communication to device OK.
Phone type: RM-872 (206)
SW version: V 04.52 30-06-13 RM-872 (c) Nokia
Imei plain: 35635205574924-1
Product code: 059Q4J7
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: 0FD00F22004004, ver:
MMC password: asif
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_RM-872_356352055749241_13_02_14_183957_SIM.RPL"
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35635205574924
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000004000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
ATF
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Unique Data: 12200C01A0012827
Original Product Code: 059Q4J7
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\356352055749241\356352055749241_62735.rpl
Certificate Block Saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\356352055749241\356352055749241_CERTIFICATE_F8BE004C.bin
Data Sections : 04
Current File    : FEBD2E18_rm872__04.52.mcusw
Compile Name: rm872__04.52.mcusw_ebl_psi.fls
Image Type   : Main Firmware
Data Size       : 26480008 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
 Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
ERROR: Erasing Failed
INFINITY BEST
Core : v1.82 , BB5XG FlashEngine : v9.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : FEBD2E18_rm872__04.52.mcusw
PPM : 3265D915_rm872__04.52.ppm_m2
CNT : 81DD7A9E_rm872__04.52.image_m2_059Q8L5
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
IF xCPUID    : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data  :  1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.53_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 356352055749241
IMEI 2 : 356352055749258
PCcode : 059Q4J7
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\356352055749241_XG213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
   ===Flashing [MCU]===
Image : rm872__04.52.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:01
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:06
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:02:05
Write , Start : 0x40280000 , Len : 0x01800000
Flashing , wait ...
Region flash done, time : 00:00:31
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
[ERR_ReqFlashEraseStart] : 0E00AD0400000A00
Error...
-> Check cable, flashfile, try again from this file
Connect phone on selected interface...
The Following 4 Users Say Thank You to Tanha0321 For This Useful Post:
Old 02-13-2014, 18:07   #5 (permalink)
Member: 749017
Thanks Meter: 16
try to flash nokia 302 RM-813 and RSVP
Old 02-19-2014, 21:59   #6 (permalink)
tolga02's Avatar
Member: 371390
Thanks Meter: 21
1 2 boxes dongle means your brother had died did not die would not write this: D
Page generated in 0.32030 seconds with 7 queries
