02-08-2010, 06:02 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 387696 Status: Offline Thanks Meter: 161 | mx-key team I am sad plz help me Phone Type: RH-99 SW Version: V 5.91 27-03-09 RH-99 (c) NMP Imei plain: ??????????????-? Product Code: 0546370 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MM Language Pack: - not available. TimeStamp: 2009-03-30T08:46:42Z SW Version: 5.91 Variant Version: 001 ProductProfile: RH99_0546370_5.91_001.spr Simlock: 0546370_SimLockDataVerifier_vDCT4.sim Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 But not flashing and not unlocking not write rpl my hwk another mx-ky ok working my mx-key another hwk and jaf not working problem same BootLoader not responding, mostly RAM problem very big problem in mx-key plz mx-key solve this problem |
02-10-2010, 05:43 | #7 (permalink) |
Member: 387696 Status: Offline Thanks Meter: 161 | bus check Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! scan Phone Type: RH-64 SW Version: V 7.02 10-12-07 RH-64 (c) NMP Imei plain: 35204902308298-6 Product Code: 0525378 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: AC Language Pack: English,Danish,Icelandic Imei net: 35204902308298 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.CORRUPTED (20) 4.CORRUPTED (20) 5.CORRUPTED (20) Flashing Using device: UFS_USB V2.8 (c) SarasSoft 2007.Library version: 1.0.0.11985, Date: 03-02-2010Rpl backup already exist. Processing file: rh64_07.020 as MCU [DCT4,DCT4 ALGORITHM] size: 1.84 MBSupported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 ASIC ID: 0x2201 [UPP_2M ver: 2]SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! flashing terminated ! Flashing terminated with error(s) in 46.062 s RX Buffer: D372 |
manole & MX key team and all exparts pls help me | tanveeranjum | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 3 | 03-27-2010 19:41 |
Mx-key team take a look and help! | dee4dee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 03-26-2010 16:40 |
MY MX-KEY not flash any set plz help | amanhalwara | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 02-07-2010 10:14 |
Mr manole o Mx-key team, please i need your help | Hacker84 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 12-30-2009 01:59 |
I Can't Download flash file from MX Key Support Area,hope you can help me Mr. Manole | makasa | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 12-20-2009 23:27 |
