Old 01-30-2011, 09:41   #1 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,110
Question Mx-key Team Why This Problem...............?
Why This Problem Mx-key Team..........................?
1'st Time Repair Status Result But Set is Contact Service Same Result Today More 3110 Set.................
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.30 07-05-09 RM-237 (c) Nokia.
Imei plain: 35196303810505-6
Product Code: 0514950
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351963038105056
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Set Status Steel Contact Service......................
Then Next Scan Check Result .........................
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed!
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 01-30-2011, 09:46   #2 (permalink)
rana_g_mobiles's Avatar
Member: 1421704
Thanks Meter: 64
rapeir simlock with mark rpl
and write good pm
Old 01-30-2011, 09:52   #3 (permalink)
Moderator
Member: 1162626
Question
and write good pm
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9113(26-12-2010), 1.0.0.15152(26-12-2010)
Product: V 07.30 07-05-09 RM-237 (c) Nokia.
Using cached productData[1DA0000B8E567D560A6FF502953AF2BA73CA1BEB] ...
Calculating SUPERDONGLE using security server ...
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.5
Completed in 7.109 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-237_351963038105056_SD.RPL"
Updating SUPERDONGLE_KEY ...error 0x0
Old 01-30-2011, 10:04   #4 (permalink)
Member: 1421704
Thanks Meter: 64
bro just rapeir simlock with rpl mark
not sd rapeir
Old 01-30-2011, 10:05   #5 (permalink)
alwarmobile's Avatar
Member: 1398435
Sonork: 100.1664179
Thanks Meter: 172
same problem for my set guy
pls tell me the reason mx-key team .......
big issue ??????????????
Guide the teams asap....
Old 01-30-2011, 11:43   #6 (permalink)
Member: 731314
Sonork: 100.1591813
Thanks Meter: 81
1st flash your phone and then do your job.
Best Luck
Old 01-30-2011, 12:02   #7 (permalink)
Member: 1398435
Sonork: 100.1664179
Thanks Meter: 172
many time flash phone but nt sucess
scan the phone :::
Imei plain: 35934302417319-8
Product Code: 0566963
Language Pack:
- not available.
SIMLOCK valid!
CMLA_KEY seems to be valid
SIMLOCK_TEST pass!
SECURITY_TEST pass !
Imei net: 359343024173198
Counter: 0/3, 0/10
but
bus check the phone :::
Language Pack:
- not available.
SIMLOCK not valid!
SIMLOCK_TEST falied!
SECURITY_TEST failed !
Counter: 0/3, 0/10
tell me pls help
Old 01-30-2011, 12:32   #8 (permalink)
Moderator
Member: 1162626
no reply mx-key team.............................?
Old 01-30-2011, 12:49   #9 (permalink)
Registered User
Member: 820730
Thanks Meter: 7
just repair simlock by mx-key
Old 01-30-2011, 12:53   #10 (permalink)
Member: 1089712
Thanks Meter: 25
scan the phone :::
Language Pack:
- not available.
SIMLOCK valid!
SIMLOCK_TEST pass!
Counter: 0/3, 0/10
but
Language Pack:
- not available.
SIMLOCK not valid!
Counter: 0/3, 0/10
tell me pls help
pls update simlock sir
Old 01-30-2011, 13:28   #11 (permalink)
Member: 1080951
Sonork: 100.1591728
Thanks Meter: 89
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Language Pack:
- not available.
SIMLOCK invalid!
Counter: 0/3, 0/10
Palash_love2000 bro try to setup mobileEx 3.4 (rev1.7) update simlock
tested by me 100%.this is mobileEx 3.4 (rev1.8) problem
The Following User Says Thank You to JIBON JIBON For This Useful Post:
Old 01-30-2011, 13:36   #12 (permalink)
Member: 1398435
Sonork: 100.1664179
Thanks Meter: 172
many time update repair simlock but no reslove
plssss help
reply mxkey team
i will wait.............................................. ....................................
Old 01-30-2011, 13:40   #13 (permalink)
Member: 1398435
Sonork: 100.1664179
Thanks Meter: 172
Dear nullled
many time update
see the log
SIMLOCK_DATA corrupted!
Backup already exist.
Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010)
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK
Sending PreLoader(0x2E4 bytes) ...OK
Sending ROM(0x3948 bytes) ...OK
Sending CustomLoader(0x50B0 bytes) ...OK
Sending SecurityBlock(0x2000 bytes) ...OK
Sending SimlockBinary(0x3B0 bytes) ...OK
Calculating LOCK data ...OK
Receiving PM, please WAIT ... OK
PM saved to "C:\mobileEx\3.4\data\backup\359343024173198_UNLOC KED_308.1.PM"
Writing PM ... OK
Completed in 38.157 s
Restarting phone ...
Reading Simlock info ...
no resolve???????????????????????????????????????????
Old 01-30-2011, 13:49   #14 (permalink)
Member: 1089712
Thanks Meter: 25
yes iam agre this solusition
Old 01-30-2011, 15:27   #15 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Wrong process following >>>>>>>>>>>> Need SP Unlock With tick on Make simlock RPL
But you R doing SD repair ,, If you will not follows the steps no one can help you
The Following User Says Thank You to srinibas For This Useful Post:
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.28733 seconds with 9 queries
