01-30-2011, 09:41 | #1 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Mx-key Team Why This Problem...............? Why This Problem Mx-key Team..........................? 1'st Time Repair Status Result But Set is Contact Service Same Result Today More 3110 Set................. Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35196303810505-6 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 351963038105056 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Set Status Steel Contact Service...................... Then Next Scan Check Result ......................... Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35196303810505-6 Product Code: 0514950 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed Imei net: 351963038105056 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
01-30-2011, 09:52 | #3 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9113(26-12-2010), 1.0.0.15152(26-12-2010) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[1DA0000B8E567D560A6FF502953AF2BA73CA1BEB] ... Calculating SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.5 Completed in 7.109 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-237_351963038105056_SD.RPL" Updating SUPERDONGLE_KEY ...error 0x0 |
01-30-2011, 10:05 | #5 (permalink) |
Freak Poster Join Date: Sep 2010 Location: I M FOLLOWING YOU
Member: 1398435 Status: Offline Sonork: 100.1664179 Thanks Meter: 172 | 7737077111 same problem for my set guy pls tell me the reason mx-key team ....... big issue ?????????????? Guide the teams asap.... |
01-30-2011, 12:02 | #7 (permalink) |
Member: 1398435 Status: Offline Sonork: 100.1664179 Thanks Meter: 172 | many time flash phone but nt sucess scan the phone ::: Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35934302417319-8 Product Code: 0566963 Language Pack: - not available. SIMLOCK valid! SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST pass! SECURITY_TEST pass ! Imei net: 359343024173198 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED but bus check the phone ::: Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35934302417319-8 Product Code: 0566963 Language Pack: - not available. SIMLOCK not valid! SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST falied! SECURITY_TEST failed ! Imei net: 359343024173198 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED tell me pls help |
01-30-2011, 12:32 | #8 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | no reply mx-key team.............................? |
01-30-2011, 12:53 | #10 (permalink) | |
Insane Poster Join Date: Aug 2009 Location: between the real and unreal
Member: 1089712 Status: Offline Thanks Meter: 25 | Quote:
01-30-2011, 13:28 | #11 (permalink) | |
Freak Poster Join Date: Jul 2009 Location: JATRABARI
Member: 1080951 Status: Offline Sonork: 100.1591728 Thanks Meter: 89 | Quote:
tested by me 100%.this is mobileEx 3.4 (rev1.8) problem | |
The Following User Says Thank You to JIBON JIBON For This Useful Post: |
01-30-2011, 13:36 | #12 (permalink) |
Member: 1398435 Status: Offline Sonork: 100.1664179 Thanks Meter: 172 | many time update repair simlock but no reslove plssss help reply mxkey team i will wait.............................................. .................................... |
01-30-2011, 13:40 | #13 (permalink) |
Member: 1398435 Status: Offline Sonork: 100.1664179 Thanks Meter: 172 | Dear nullled many time update see the log SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Product: V 07.30 07-05-09 RM-237 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...OK Sending CustomLoader(0x50B0 bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x3B0 bytes) ...OK Calculating LOCK data ...OK Receiving PM, please WAIT ... OK PM saved to "C:\mobileEx\3.4\data\backup\359343024173198_UNLOC KED_308.1.PM" Writing PM ... OK Completed in 38.157 s Restarting phone ... Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! no resolve??????????????????????????????????????????? |
01-30-2011, 15:27 | #15 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
But you R doing SD repair ,, If you will not follows the steps no one can help you | |
The Following User Says Thank You to srinibas For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
