10-13-2009, 05:43 | #1 (permalink) |
Product Manager Join Date: Apr 2009 Location: BD,BH,CN
Member: 1004001 Status: Offline Sonork: WhatsApp+971506319003 Thanks Meter: 448 | Mx Key v3.2_rev5.3 Supported list Thanks......... br, gsm_yousuf |
The Following 3 Users Say Thank You to UNLOCK PARK ® For This Useful Post: |
10-13-2009, 05:47 | #3 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Changes, Code: v3.2 revision 5.3, Public-Release #Minor update - MAIN Fixed, Windows Vista & Windows 7 compability. - NK Fixed, BB5 SIMLOCK_DATA/KEY PA_SL3 write Fixed, BB5 RAPU-YAMA phones flashing Fixed, DCT4 flashing bug(DEAD after flash/unlock) Fixed, loading module sometimes failed Improved, Module stability ------------------------------------ v3.2 revision 5.2, Public-Release #Minor update - NK Fixed, WD2(PPM) flashing using UFS ------------------------------------ v3.2 revision 5.1, Private-Release #Minor update - MAIN License #0 needs to be activated(activation is FREE) to load module. - NK Added, DCT4 ASIC 0x3168 standalone 'on the fly' patch for SP UNLOCK and Imei Changes ~ This feature need License #1 to be activated(activation is FREE) Added, Low Level format before CNT write Fixed, Image Download 'in background' hang BB5 Secure Storage Validity now support PA_SL3(unlocked) phones Many Minor bug fixed. ------------------------------------ v3.2 revision 5.0, Public-Release #Minor update - MAIN Added, Dongle License status Info in the Dongle Maintenance Gro***** Added, Update License Button ~ Used to activated custom license of the card which will be used for spesific feature/module To preserve bandwidth, Refill Button will be enabled if Counter < 50 % - NK Added, BB5 PA_SL2 NCK Calculator using security server ~ This will unlock most PA_SL2 phones with protected PM308:1 ~ This feature need License #1 to be activated(activation is FREE) Added, BB5 PA_SL2 Counter Reset Added, SAFE Erase routine while using 'Custom Flash Erase' on the 'Advance Page' ~ SAFE Erase will Protect PM Data from erase specially when doing 'Erase WHOLE flash'. ~ Usefull for recovering a DEAD phone without loosing SIMLOCK DATA Fixed, BB5 Secure Storage Validity for PA_SL3 phones Added, Automatic NPC backup while doing 'Skip SX4 Auth' and 'BB5 SW Downgrade Fix' Minor bug fixed. ------------------------------------ v3.2 revision 4.1, Public-Release #Minor update - NK Fixed, PMM auth bug(application closed) ------------------------------------ v3.2 revision 4.0, Public-Release #Minor update - MAIN Binary will no more run inside Virtual Machine Added, Intrusion detection against code framework manipulation ------------------------------------ v3.2 revision 3.2, Public-Release #Minor update - MAIN Minor bugfix - NK JAF BOX stability and compability improved ~ This will also fix problem with flash dead,random stops/hang when using JAF BOX Added, Bus Check routine for 'Nokia USB ROM' ~ Usefull for 'NORMAL' phones which could not connect to USB due to phone lock or something else ~ After sucessfull flash bus check phone will reboot to local mode, so you can do fbus operation such as: reset user code/factory reset Added, Wlan settings in RF/BB tab Fixed, Keypad test start bug Fixed, Sometimes hang after flash erase Wlan settings also included when backing up ProgData ------------------------------------ v3.2 revision 3.1, Private-Release #Minor update - Application core module loader routine changed Private version released to test windows version compability ------------------------------------ v3.2 revision 3.0, Public-Release #Minor update - MAIN Fixed, Random crash on rev 2.2 Added, UI Style option - NK Added, BB5 SW Downgrade in 'Quick Fix' ~ Use this option to patch PM308,1 Downgrade subblock without full flashing. ~ Usefull for phones which 'DEAD' after PM308 write or RPL backup write Added, Skip SX4 Auth Option on 'PM options'. ~ PM options is button with '>' in the PM tab Fixed, Multiple Content selection form vpl files. Fixed, DCT4 Manual Logger error if no service selected Phones image background color now changed to be match with variant Color on market selection ------------------------------------ v3.2 revision 2.2, Public-Release #Patch update - NK Fixed, DCT4 Slow Flashing when using JAF interface. ------------------------------------ v3.2 revision 2.1, Public-Release #Patch update - NK Fixed, UEM req timeout bug on previous release (rev2.0) ------------------------------------ v3.2 revision 2.0, Public-Release #Minor update - MAIN MTBOX boot fixed. Regular minor bugfix - NK Added, BB5 Secure Storage Validation on 'Scan' ; This will validate if SIMLOCK or SUPERDONGLE_KEY is corrupt or not. ; Usefull to determine WD timer or CS issue for BB5 phones. ; Phone with SUPERDONGLE_KEY corrupted, will affect in SX4 auth unsuccessfull or WD problem. ; Phone with SIMLOCK corrupted, will end with CS problem. Added, SIMLOCK2 phones detection (with PM308 protected/read only) ; SIMLOCK2 ('SL2' or 'SIMLOCK2' firmware) phones RPL backup will not work with this phone because of SUPERDONGLE_KEY cannot be restored. Added, ASIC_ID(RAP/OMAP) chip name information Added, flash size information Fixed, BB5 'get address' Fixed, BB5PLUS RPL backup read/write ; Restoring from RPL backup after EEPROM will also restore SUPERDONGLE_KEY so phone will not have WD timer issue. Forced to change phone mode to TEST_MODE when doing factory reset and Self Test. Added, DCT4 Manual Logger ------------------------------------ v3.2 revision 1.4, Private-Release #Patch update - MAIN Improved, Scard api (spesially for ccid reader compability) - NK Improved, BB5 RPL upload/write ;Specially for phone which support SL2+SL3 simlock, by default old protocol will be used and it its failed new protocol automatically be used. ------------------------------------ v3.2 revision 1.3, Public-Release #Patch update - MAIN Improved, privilege adjustment ; hopefully will solve not starts problem ?! ; So far tested with XP XP2(OEM), Vista Ultimate(NOT OEM), Vista Ultimate SP1 (OEM) - NK BB5 SIMLOCK SL3 Structure upload from RPL backup added. ------------------------------------ v3.2 revision 1.2, Public-Release #Patch update - NK Added, Support for BB5 SIMLOCK SL3 Structure upload Fixed, WD2 CBUS Loader parse for correct BT flashing ------------------------------------ v3.2 revision 1.1, Public-Release #Patch update - NK Fixed, Online Logger not shown when 'Imei changes' disabled. Fixed, BB5 Restore Imei+Write RPL ------------------------------------ v3.2 revision 1.0, Public-Release #Major Update - MAIN Added, UI Localization ;languages selectable from 'quote' menu ;locale files stored to 'locale\*.xml' directory ;added, Chinese (Simplified) language for test (translated using Google Translate, so am sure its not 100% correct), unicode enabled. ;full localization might be added at the future Added, balloon Tips stored to locale files Fixed, Application not opened in some PC caused by not previlege account (specially XP SP3 and Vista SP1) List of loaded drivers version are now displayed at start up Server list are now selectable Added, posibility to play custom sound on error/finish Added, Card Serial Port drivers ;allow to use serial(comport) based reader for the card Added, 'Nokia USB ROM' virtual device to be used for BB5 USB DEAD PHONE flashing Fixed, Connect<->Disconnect bug (appl. crash) - VCOM Small change in UI Changed, PK-83 binary to support new drivers - CCS Fixed, nkser(6088,6066,7088) driver handling when flashing stop at the middle of process - NK Added, BB5 USB Flashing ; Supported loaders RAP3Gv2+APE(external loader), RAP3GV3+APE, RAP3GV3 NON APE+DEAD FLASH, RAPIDO NON APE+DEAD FLASH, RAPIDO +APE, RAPIDO (RAP3NAND) NON APE+DEAD FLASH. ; Version check mechanism is possible when flashing NON DEAD phone ; LANGUAGE only option also posible for fast and safe phone update Added, Multiple version of flash update/loaders ; selectable from 'quote' menu 'Config->Directory' ; Newer phones might need newer flash loader, by default is '8.6.1.31560' Fixed, BB5PLUS RAPIDO SL2 spunlock Added, Pinout image for UFC based cable (press small button near phone image) ; pinout images are stored at 'data\image\pinout' directory Multiple Data Package directory are now possible (usefull when working with Multi-OS PC) Added, 'Force WHOLE flash' on erase(Advance Page) to allow RAP flash full erase (Last chance, if NPC reset still not work to revive DEAD/BLINK Phone) Added, PP file read Added, Phonebook/Contacts backup and restore (Phone Settings->Selection:User Settings) Removed, Host setting (please use 'select server' from Main|Server List page) - SIEM Siemens module recompiled for new api compability ------------------------------------ v3.2 final bug-fixed, Public-Release - NK DCT4 RPL server host changed, to fix timeout in some country Improved, DCT4PLUS "on the fly" unlock patch and imei patch Added, AMS loader v. 8.49.19.36652 to the installer minor bug fixes - VCOM Fixed, Active-X initialization to fix rx no respond in some pc ------------------------------------ v3.2 FINAL, Public-Release - MAIN Improved Server communication Added, Support area access Goto Options->Server->Server List (make selection on 'Support') then Goto Support button will enabled - NK Added, Standalone BB5PLUS SL2 No TP Unlocker PM Auth checkbox also added for some phones which need SUPERDONGLE to be authorized while writing PM120 and PM308 Added, DCT4PLUS "on the fly" imei changes Improved, DCT4PLUS "on the fly" unlock patch (+new security also supported) Improved, PM read and write (if field not checked will be skipped) To Open PM, you can now Drag And Drop PM file to listbox Fixed, BB5 loaders bug for new phones Fixed, image download Fixed, BB5 auto set RX2 Fixed, DCT4PLUS Online Logger bug minor bug fixes - VCOM Fixed, PK-83 binary for MXKEY REV 2.0 compability Siemens FREE module recompiled for new api & library compability. +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ v3.1 Beta16 , Public-Release - MAIN Removed old card protocol(MXKEY REV 1.X/ROCKEY6), for this release only MXKEY REV 2.X card supported - NK Fixed, loader issue Added, single phones setting (VPP,RX2, Fast checkbox now saved to config for each phone) Added, BB5 No TP Unlocker, Dejan RAP3GV2 unlocker removed. supported HASH: BAF3A9C3DBFA8454937DB77F2B8852B1,E9EFF4BFAA5393217CA6B17755FC3E14,CAEEBB65D3C48E6DC73B49DC5063A2EE,9A28E119033B91D14D22838C86D0D53C supported ROM: 273F6D55DFAAF68F,191EC665DFAAF68F,F28A211FCEA7B19D,A8C1D6713E691FF8,F2C6EBADC86E6189,F28A211FAC901AEE(untested),4B9B75103E691FF8(untested) Fixed, `highlight market` bug minor bug fixes - CCS Improved, communication. Dead phones full flashing now working ==================================================================================== v3.0 Beta15 RC, Public-Release - MAIN help file updated minor bug fixes - NK DCTL/LINDA fully implemented with Custom erase to fix old 9210i CS problem Fixed, Image DL (server communication protocol changed) Fixed, BB5 custom certificate backup Fixed, New PP files manual upload Improved, SUPERDONGLE auth (show the detailed error msg) Improved, User code reset for BB5 phones minor bug fixes ------------------------------------ v3.0 Beta14 RC, Public-Release - HW MXKEY LiTE dongle firmware version 00.14 released (Improvement dongle check, to avoid CARD BLOCKED) Please update using SW build beta14 only. - NK Added RAP NAND option in manual erase Added, CRC check before flashing if declared in definition files(BB5) Image DL in background mode improved (CRC check) minor bug fixes ------------------------------------ v3.0 Beta13 RC, Public-Release - MAIN Fixed, MXKEY (ROCKEY6) dongle detection. - NK Image DL in background mode now possible Added 'skip Restore' patch for DCT4PLUS unlock Fixed, PPM2 image parsing minor bug fixes - VCOM Fixed, registration popup Added, PK-83 Dongle emulation (you need to install CCS3 Tool first before it works) ------------------------------------ v3.0 Beta12 RC, Public-Release - MAIN Fixed, dongle registration popup - NK DCT3 fully implemented Fixed, BB5 flash for new phones some improvement and minor bug fixes - CCS Fixed, 6066/88 flash ------------------------------------ v3.0 Beta11 RC, Public-Release - MAIN Improved, dongle communication routine Fixed, Self Update - NK MTBOX DCT4 flash supported. Improved, DCT4&BB5 Online Logger Improved, RX2 auto enabled Added, Simple hint "detailed" BB selftests Added, DCT4PLUS (asic type 11) phone UEM read Fixed, PP extract for DP2.0 phones - CCS Added, Forced RX queue for better handle of dead phone flashing Fixed, Emergency mode Image DL enabled - OTHER Added, Latest mxLogger client(v1.4b) in setup ------------------------------------ v3.0 Beta10a RC, Public-Release - NK Fixed, BB5 Online Logger Fixed, BB5 RAP NAND (with RX2 enabled) flashing Added, Full BB5 RPL backup for new phone (SIMLOCK+SIMLOCK_KEY,WMDRM_PD) Added, BB5 user code reset(blocked counter) and status, will not lose user data. Improved DCT4 Asic 11 Online Logger (Imei challenge issue) Added, auto create folder option on configuration window Fixed, DP2.0 folder listing ------------------------------------ v3.0 Beta10 RC, Public-Release - MAIN Added, Support forum and homepage menu (News) - NK Added, Image DL button (direct image download from support based on product code, currently for BB5 products only !) Implemented, RX2 loader support (UFS FW v28 only !!!). Implemented, Show detailed options in configuration window Added, Auto select Gen when "Scan" product in configuration window Added, Auto set RX2 for BB5 in configuration window Added, market highlight for easy market choise in configuration window Added, Auto set RX2 for BB5 in configuration window Added, BB5 CNT page size detection for auto CNT convertion Added, Skip if not empty option Added, Manual PP write file Added, BB5 MMC and SD card content flashing Added, BB5 verify NPC option on write RPL Added, BB5 skip spesific section on write RPL Added, BB5 skip (certificate) erase option on write RPL Added, BB5 Reset NPC Added, BB5 online logger client (instant !!!) Added, BB5 RPL write on RX2 enabled phones Fixed, DCT4 MM flash handling Added, DCT4 imei OTP/UEM read via FBUS for non CUI phones. Added, Latest DCT4PLUS ASIC11 sp unlock patch method(Patch on the fly) Added, DCT4PLUS ASIC11 online logger client Added, extended GSM/WCDMA band type set Improved, BB5 (RAP/CMT) NAND flash handling Improved, Flash chip info. device page size and type now displayed. Improved, DCT4PLUS ASIC11 ask read + manual IMEI/ESN input when UEM damaged Changed, 'Browse' to Directory setting in configuration window - CCS Improved, QCOM protocol for faster flashing Improved, Dead phone flashing handle Added, Phone code read for 6088,7088 phone Added, Image DL button (direct image download from support) Fixed, Userarea backup/restore ------------------------------------ v3.0 Beta9 RC, Public-Release - MAIN Improved, Check for updates (more control to updates) Implemented, Online News(add RSS feeds and forum news) Implemented, Options to enabled/disabled spesific module - NK MTBOX Partially supported(FBUS function) Improved, DCT4 boot Improved, Auto phone detection (always "Scan phone" or "Bus check" before any operation!) Improved, CDMA phones compability Improved, Keyboard test map (now possible to test all keys including communicator series) Added, Various tests (Camera,IR,MMC,SIM,USB) Added, Band & System mode control Added, CDMA NVD (Pri) management (under Phone Settings tab) Added, CDMA CS product type read Added, RF/BB PM backup/restore Added, BB5 CNT 128 K convertion Added, COMBOFLASH detection Fixed, DCT4 write RPL (add DATA1/2 only options) Fixed, BB5 Custom erase Fixed, DCT4 APE flash(better error handler) Improved, DCT4 SP unlock routine Improved, CDMA tuning (SET,CAL and PANEL data are now readed and written correctly) Redesigned, PMM, Phone Settings, CDMA tune & Quick Fix page(under services tab) Reconstructed, BB5 'Dejan K' unlocker Introduced, DCT4 read flash works for Asic type 2 phones only (check 'Phoenix format' for writable output) - just for test ! Introduced, DCT4 Non Volatile Data(NVD) management (in development, not finished yet) - CCS Added, ARMPRG/Bootloader manual select to handle 'dead' phones Fixed, Invalid hex error while flashing Improved, Phone explorer routine and ui ------------------------------------ v3.0 Beta8, Public-Release - MAIN Fixed, "Check For Updates" bug Fixed, UFS baud problem (DCT4 erase issue?) - NK Fixed, DCT4PLUS non patch unlock (1600,1110i) Added, Automatically save RPL backup on "Bus Check" for DCT4 Fixed, DCT4 Erase ! (hopefully fixes this common issue, tested on 3 different PCs Intel/AMD based) - VCOM Fixed, Incorrect registration popup ------------------------------------ v3.0 Beta7, Public-Release. Whats NEW: - [MAIN] Added, "Dont Show This Again" checkbox of UFS FW update confirmation dialog Improved, Check For update routine will allow to update module separately on future updates - [CCS] Added, New Module CCS "Foxconn PST"(NK CDMA ODM QUALCOMM) Features: * Flashing using HEX/ CBB (Bundle Files) * Normal Flashing or Emergency Mode (*+5+POWER) supported * Flashing Emulation * Security Code Read/Write * SPC read/write * LCD contrast Read/Write * Reset File System (PRI) * Userdata Backup/Restore * EFS File Explorer * And soon - [VCOM] Revised, VCOM module - [NK] Added, Patch SIMLOCK flashing option + SKip SW patch on Init Simlock (1650 bug) Improved, Flash erase routine Added, UEM WD test Added, Verify UEM option on DCT4 RPL write - [SIEM] Fixed, SGOLD baudrate issue and other minor. Version Information: Main: » mobileEx.exe, version: 3.0.0.889 » mobileEx.dll, version: 1.0.0.1144 Modules: » ccs.dll, library version: 1.0.0.103, module version: 1.00 ß » nk.dll, library version: 1.0.0.897, module version: 1.00 ß7 » siem.dll, library version: 1.0.0.293, module version: 1.01 ß » vcom.dll, library version: 1.0.0.664, module version: 1.02 ƒ Required Dongle revision: MXKEY, FW ver: 00.11 MXKEY LiTE, FW ver: 00.13 *) ß = BETA ƒ = FINAL ------------------------------------ v3.0 Beta6, Public-Release. Whats NEW: - JAF BOX fully supported. - Added, Flash Emulation mode(to verify flash files, will not write to the phone) - Added, Support for BB5 RAPIDO phones(RAP NAND flash handle) - Added, Easy IMEI restore(Automaticaly search for backup from '\data\backup\RPL\' folder if available) - Added, DCT4 Mass Memory device(NAND) flashing support - Added, UFS FW V 2.8 update dialog if needed(required for RAPIDO phones handle) - Added, UFS Driver update dialog if 'NO CONNECTION' - Fixed, N-GAGE Adsp flashing bug(CRC error=Contact retailer). - Fixed, DCT4 Online IMEI Logger (ESN issues) - Fixed, WD2 boot (increasing boot timeout) - Fixed, User Code changes - Fixed, BT MCM image upload - Fixed, Erase whole flash routine - Fixed, Reset DATA1 (WD2 bug) - Fixed, TIKU flashing with huge image header stoped - Fixed, DCT4 UCP 128k convertion(2865 issue) - Fixed, DCT4 PLUS SpUnlock bug on old models - Removed, Joker module from installer - Added, SIEMENS Tool(EGOLD, SGOLD) module. and other minor. Required: MXKEY, FW ver: 00.11 MXKEY LiTE, FW ver: 00.13 ------------------------------------ v3.0 Beta5, Public-Release. Whats NEW: New MXKEY LiTE firmware introduced, FW ver: 00.13 - Added, JAF FBUS protocol (Flashing bus not implemented yet) - Added, Component version info on load. - Fixed, Erase whole flash bug on multi flash chip phones. - Fixed, BT flush after firmware update. - Fixed, BB5RPL decryption fail when write RPL. - Added, Product code auto selection on "Scan" and other minor. Note: for MXKEY LiTE dongle user, you need to "Update FW" first. ------------------------------------ v3.0 Beta4, Public-Release. Whats NEW: - re-constructed & improved, DCT4PLUS unlock patch - RELOCK now possible, also support 1200/1208 all version(click "No" when you asked to restore flash block) - re-constructed, DCT4 CNT 64->128k convertion. - Added, support for new product profile type(BB5,DCT4PLUS). - Fixed, crash (application closed) on VCOM module. - Improved, FBUS scan (will change phone mode if needed) - Fixed, PM write function (BB5 RF & BB parameters bug) and other minor. ------------------------------------ v3.0 Beta3, Public-Release. Whats NEW: - re-constructed, CDMA Tuning. - re-constructed, Quick repair page (BT repair, LCD reset, etc). - improved, Online Updater. - added, CDMA NFP folder to model selection. and other minor. ------------------------------------ v3.0 Beta2, Public-Release. Whats NEW: Almost all elements are new, the most important part of this ßeta was that it was finally recoded from scratch. Not implemented yet: - JAF interface support - DCT3/L function - DCT4PLUS unlock patch - BB5 generic unlock - and some other. This brand new exe will supports MXKEY and MXKEY LiTE What is MXKEY LiTE? its new dongle for mobileEx, SmartCard based. What about future support about MXKEY? We released MXKEY LiTE for *******r satisfaction. MXKEY LiTE will be cheaper, and thats why we call it "Lite". MXKEY will be fully supported as MXKEY LiTE, note that there was no differences between MXKEY and the LiTE version. Unimplemented features will be added as soon as possible. while that, you could also request feature MXKEY LiTE quick driver instalation: !!! Do NOT install Smartcard reader before installing drivers. goto "C:\mobileEx\3.0\data\drivers" then click "instdrv.exe" to install the Reader driver. This is PCSC ISO7816 compatible reader, you could also use any PCSC compatible reader to work with the card. ----------------------------------- v3.0 Beta, Pre-Release. Published to beta-testers. Code: Supported BB5 No TP Unlock: RAP3GV2: -6630 (RM-1)* -6680 (RM-36)* -6681 (RM-57)* -6682 (RM-58) -N70 (RM-84)* -N70-5 (RM-99) -N71 (RM-67) -N90 (RM-42)* -N91-1 (RM-43) -N91-8GB (RM-43)* -N91-5 (RM-158)* -N93 (RM-55) RAP3GV3: ;Relock also supported -3109c (RM-274) -3110c (RM-237) -3250 (RM-38) -3500c (RM-272) -3500cb (RM-273) -5200 (RM-174) -5200b (RM-181) -5300 (RM-146)* -5300b (RM-147) -5500 (RM-86) -5700 (RM-230) -5700 (RM-302) -6085 (RM-198) -6086 (RM-188) -6086b (RM-260) -6125 (RM-178) -6126/6133 (RM-126) -6131 (RM-115) -6131 NFC (RM-216) -6136 (RM-199) -6151 (RM-200) -6233 (RM-145)* -6234 (RM-123)* -6280/6288 (RM-78)* -6290 (RM-176) -6300 (RM-217)* -6300b (RM-222) -7370 (RM-70) -7373 (RM-209) -7390 (RM-140) -8600 (RM-164) -E50 (RM-170) -E50 (RM-171) -E50 (RM-172) -E61 (RM-89) -E61i (RM-227) -E62 (RM-88) -E65 (RM-208) -N73-1 (RM-133)* -N73-5 (RM-132) -N75 (RM-128) -N76 (RM-135) -N76 (RM-149) -N77 (RM-194) -N80-1 (RM-92) -N80-3 (RM-91) -N92 (RM-100) SL2: -3120C (RM-364)* -3555 (RM-277) -3555b (RM-257) -5310 (RM-303)* -5310b (RM-304) -5610 (RM-279) -5610d-1(RM-242) -6263 (RM-207) -6300i (RM-337) -6301 (RM-322) -6500s (RM-240)* -6500c (RM-265)* -6555 (RM-289) -7500 (RM-249) -7900 (RM-264) -8800 (RM-165) exception(Not supported, new security): -3600s(RM-352) V56.26 -5310 (RM-303) V58.58 -6500c (RM-265) V59.45 -6500s (RM-240) V59.60 -6300 (RM-217) V57.20 RAPIDO: -N95 (RM-159)* -N95 (RM-245) -N95 (RM-160) -E90 (RA-6) SL2: -6110 (RM-122) -6120c (RM-243)* -6121c (RM-308) -6124c (RM-422) -6210 (RM-367) -6220c (RM-328) -6290 (RM-176) -6650 (RM-400) -E51 (RM-244)* -E66 (RM-343) -E71 (RM-346) -N79 (RM-349) -N95-2 8GB (RM-320) SL2 with Protected PM: -E75 (RM-412)* -N96 (RM-247) -5800 (RM-356)* ####################### Supported DCT4PLUS Patch Unlock: -1110i (RH-93)* -1112 (RH-93)* -2310 (RM-189)* -2610 (RM-189)* -1650 (RH-86)* -1200 (RH-99)* -1208 (RM-205) -1209 (RM-105)* -2680 (RH-392) -5000d (RM-362)* -2600c (RM-340)* -2626 (RM-291)* -2630 (RM-298)* -2670 (RM-258)* -1680c (RM-394)* -2330c (RM-512)* -2323c (RM-543)* -2720a (RM-519)* -7100s (RM-438)* *) tested. |
The Following 6 Users Say Thank You to Shakeel_pattoki For This Useful Post: |
10-13-2009, 05:50 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | Yup, be a beta tester............... from now on, i proclaim you all,mx-key user "the beta-tester" test and post all success flashing/unlocking.. test and report all new added bug's............ br. |
10-13-2009, 05:53 | #5 (permalink) |
Member: 159757 Status: Offline Thanks Meter: 461 | like bb5 flashing error:3110c Using device: J.A.F, FW ver: 01.B1 Processing file: rm237__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 28E00004E6257E564C9DC365FB98514F62CFC954 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Total erase size: 16.37 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00020000-0007FFFF] CMT NOR area [00080000-000DFFFF] CMT NOR area [00100000-001FFFFF] CMT NOR area [00200000-0031FFFF] CMT NOR area [00320000-0105FFFF] CMT NOR area [01060000-01067FFF] CMT NOR area [01068000-0107FFFF] erased in 0.844 s Flash programming ... Error while programming [00] at 0x00020000, Result: 0000 Flashing terminated with error(s) in 39.515 s RX Buffer: br. |
The Following 2 Users Say Thank You to rico_deep For This Useful Post: |
10-13-2009, 20:07 | #6 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: RIFF-XILINX
Member: 214827 Status: Offline Sonork: 100.1597158 Thanks Meter: 59 | Quote:
Still is working on software that's going to go at least as JAF ..... 's fault and style make me so Cyclone Cyclone Flash erase and write from no ... that only some phones, not at all. BR | |
10-13-2009, 22:00 | #8 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Quote:
Br. Vijendra Saini. | |
10-14-2009, 04:31 | #9 (permalink) | ||
Member: 159757 Status: Offline Thanks Meter: 461 | Quote:
all same result: failed ... phone working after re-flash it on jaf crack, take note "JAF CRACK" mx-key can do better than this..if only they could get rid of that "Bug's" I'ts always there, in every new update come's a OLD BUG... br. | ||
10-14-2009, 05:04 | #10 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: gadgets works station
Member: 1019591 Status: Offline Sonork: 100.1592733 Thanks Meter: 634 | Quote:
bro try usb flashing | |
The Following 2 Users Say Thank You to rakesh15 For This Useful Post: |
03-20-2010, 14:28 | #11 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Bangadesh.Dhaka
Member: 694638 Status: Offline Sonork: no Thanks Meter: 164 | Succesfully repair SIMLOCK_DATA corrupted! Succesfully repair 1680c SIMLOCK_DATA corrupted! 1.Full eras 2.full flash 3.Write pm 4.Then unlock by mcu file 100% ok I test it......... |
04-13-2010, 07:38 | #12 (permalink) |
No Life Poster Join Date: Mar 2010 Location: south africa Age: 41
Member: 1269056 Status: Offline Thanks Meter: 1,114 | MXKEY Nokia DCT4PLUS Unlocker -------------------------------------------------------------------------------- Partial update of Nokia DCT4PLUS Unlocker. - Server config update to another port for better unlock jobs handling To update: 1. Goto Options->Module, select "Nokia Unlocker" and click "Update" You will get this result: » Nokia Unlocker Version from module: 1.0.0.133 Version from server: 1.0.0.138 Partial update available. Whats New: GET: mobileEx.lib OK GET: nkc.mx OK Update completed, please restart application. Manually update module Right click save to C:\mobileEx\3.3 : http://www.mxkey.biz/modules/mobileEx.lib Right click save to C:\mobileEx\3.3\modules : http://www.mxkey.biz/modules/nkc.mx !!! VERY IMPORTANT !!! You will need to do Sign Application after this update. Buy only from MX-KEY authorized resellers FOR CREDITS ACTIVATIONS: mohsin from south africa press thenks |
The Following User Says Thank You to trust4eve83 For This Useful Post: |
06-16-2010, 17:53 | #13 (permalink) |
Freak Poster Join Date: Oct 2007 Location: nigeria,west africa
Member: 608803 Status: Offline Thanks Meter: 13 | Booting Box... JAF Box FW version: 01B4 Powering the phone ... Please Wait... Reading phone info ... Type: RM-438 Version: V_06.31_24-03-09_RM-438_(c)_Nokia ASIC Type: 11 IMEI: 356060034180335 UPP version: 12648 Production SN: DOV355670 HW Signature: 98D61B4422B10A22 Simlock Key: 0023410000000000 Simlock Profile: 800000000003000B Simlock Aux: 000B5555 SP LOCK status: BLOCK 1: 1.LOCKED: 23410F Cable counter: 0/10 Key counter : 0/3 Read Phone Info OK Your request is waiting for calculation. Estimated time (hh:mm:ss): 07:42:03 dct4++unlocker 0.3.1 is not working |
FAQ about Mx-key v3.3 rev1.3 and Simlock RPLs. | Maiwand khan | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 31 | 04-08-2010 14:45 |
MX-KEY v3.3 revision 1.3 public discussion thread | MANOLE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 368 | 02-07-2010 23:10 |
MX-KEY v3.3 revision 1.3 repairs SIMLOCK_DATA corrupted? | angelcelu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-29-2010 09:27 |
Mx-key v3.3 rev1.3 and Simlock RPLs. | mamun_q | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-26-2010 11:03 |
FAQ about Mx-key v3.3 rev1.3 and Simlock RPLs. | ashish mobile | Nokia Hardware & Hardware Repair | 4 | 01-26-2010 08:57 |
