05-11-2010, 18:29 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: GSM WORKSHOP
Member: 468970 Status: Offline Sonork: M.G.T Thanks Meter: 70 | MX-key v3.4 revision 1.0 Error Super SD Auth SW Version: V 07.20 23-10-08 RM-146 (c) Nokia. Imei plain: 35483102434138-0 Product Code: 0540652 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! TimeStamp: 2007-01-30T14:04:14Z SW Version: V 04.70 Variant Version: 007 ProductProfile: RM146_0540652_04.70_007.spr Simlock: 0540652_simlock.bin Imei net: 354831024341380 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.20 23-10-08 RM-146 (c) Nokia. Using cached productData[0C40000A75FF7B56880FA65223BD1423CB9A918D] ... Authenticating to SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.0 revision 1.7 Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request first time I think This caused Bad rpl or something else, but I try with normal phone result is same..here is log with normal phone : Phone Type: RM-217 (Nokia 6300) SW Version: V 06.60 21-05-08 RM-217 (c) Nokia. Imei plain: 35983501111753-4 Product Code: 0554263 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359835011117534 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 06.60 21-05-08 RM-217 (c) Nokia. Using cached productData[1E80010BA8496E567C81F05DC0B70FABADF346A1] ... Authenticating to SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.0 revision 1.7 Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Plz mr.Manole can U tell me what's wrong....??? thx in advance |
05-11-2010, 18:36 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: libya Age: 44
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | BRO. try use another server from server list you used BLADE X at host2 try with BLADE X at host1 , BLADE X at host3 or BLADE X at host4 best regards |
The Following User Says Thank You to Gsm Benghazi For This Useful Post: |
05-11-2010, 18:50 | #7 (permalink) | |
Member: 468970 Status: Offline Sonork: M.G.T Thanks Meter: 70 | Quote:
Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.20 23-10-08 RM-146 (c) Nokia. Using cached productData[0C40000A75FF7B56880FA65223BD1423CB9A918D] ... Authenticating to SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.0 revision 1.7 Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.20 23-10-08 RM-146 (c) Nokia. Using cached productData[0C40000A75FF7B56880FA65223BD1423CB9A918D] ... Authenticating to SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.0 revision 1.7 Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.20 23-10-08 RM-146 (c) Nokia. Using cached productData[0C40000A75FF7B56880FA65223BD1423CB9A918D] ... Authenticating to SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.0 revision 1.7 Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.20 23-10-08 RM-146 (c) Nokia. Using cached productData[0C40000A75FF7B56880FA65223BD1423CB9A918D] ... Product: V 07.20 23-10-08 RM-146 (c) Nokia. Using cached productData[0C40000A75FF7B56880FA65223BD1423CB9A918D] ... Authenticating to SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.0 revision 1.7 Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Confused.............. | |
05-11-2010, 22:47 | #10 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | You need to write CORRECT PM or as alternative use 'Load RF/BB from Server' so sw will request PM from server and write to the phone. BR, Manole |
The Following User Says Thank You to MANOLE For This Useful Post: |
05-12-2010, 07:32 | #11 (permalink) | |
Freak Poster Join Date: Aug 2005
Member: 171342 Status: Offline Thanks Meter: 36 | Quote:
FOR PM WRITE MAKE FIRST SUPER SD AUTH OR PMM AUTH BUT WHEN WE MAKE TIS THE RESULT IS SAME Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
