07-30-2009, 05:18 | #3 (permalink) |
Freak Poster Join Date: May 2005 Location: hanoi.vietnam
Member: 142949 Status: Offline Thanks Meter: 71 | imei 1110i ??????? very good ASIC ID: 0x2201 [UPP_v2.2x] u_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD 29BDS320] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_amd.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 001239BA:2984DA60 ASIC type: 2 UEM Imei: 35867001191026 Connecting to server ...OK, Login ... Hello A. RPL saved to "D:\3.2\data\backup\RPL\35867001191026.RPL" ASIC ID: 0x2201 [UPP_v2.2x] u_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD 29BDS320] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u_amd.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-93 SW Version: V 6.41 06-04-07 RH-93 (c) NMP Imei plain: 35867001191026-0 Product Code: 0526954 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MD Language Pack: English,Filipino,Vietnamase |
Mx key support good or bad pl vote | debmobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 55 | 03-29-2010 07:21 |
Mx key support good or bad pl vote | debmobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 10-24-2009 17:55 |
mx key is good unlocking of all nokia | lilong_lee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 10-24-2009 03:54 |
mx key very nice to use | ohdie | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 06-08-2009 10:13 |
mx key very bad software | ravi..gupta | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 38 | 06-02-2009 05:09 |
