Old 10-11-2012, 12:07   #1 (permalink)
Member: 852547
Sonork: 100.1621506
Thanks Meter: 40
Nokia 1616 Not enter Local Mode
Phone was dead, flashing done complete with checksum mismatch error( with same product code )but phone not on. log is :
MXKEY [FT SCR2000 0], SN: C08
Using device: HTI, FW ver: 00.50, SN: 00000
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21200(18-07-2012), Library ver:
1.0.0.14205(18-07-2012)
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 00EC 2254 - 23280002 [Samsung K8S6415ETC,64 Mbits]
CFI information:
Flash settings: 0/1, size: 0x00800000
2 Block regions:
127 x 0x00010000 = 0x007F0000
8 x 0x00002000 = 0x00010000
EBL ready !
Processing file: rh125_006.520
Downloading item CODE:hw_f11_rh125_r06.520.fls, num block: 3,
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 49.750 s
Erasing area 0x00C60000-0x00E72D7E ...OK
Programming completed in 48.922 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.188 s
Checksum mismatch: Phone calculated 0x9BF3, software calculated
0x7819
Processing file: rh125_006.52mg
Downloading item CUST:hw_f11_rh125_006.52mg.fls, num block: 1,
Erasing area 0x00210000-0x003F6C3E ...OK
Programming completed in 45.750 s
Checksum mismatch: Phone calculated 0x5803, software calculated
0x576B
Processing file: rh1250_nai06.52mg_nlt
Downloading item CUST:hw_f11_rh1250_nai06.52mg_nlt.fls , num
block: 1, size: 790.52 KB
Erasing area 0x00EB0000-0x00F74CFE ...OK
Programming completed in 18.234 s
Checksum mismatch: Phone calculated 0x75F4, software calculated
0x7E05
Total time for flashing process(boot+erase+write) was 3 min 35.3 28 s
Me changed lcd, reflow cpu & flash ic
Plz suggest any solution.
Old 10-11-2012, 13:06   #2 (permalink)
Member: 161280
Sonork: 100.1616990
Thanks Meter: 82
you deed to change display or lcd line is damaged but before do self test is software
Old 10-11-2012, 13:22   #3 (permalink)
Registered User
Member: 1437921
Sonork: 100.1668345
Thanks Meter: 13
Thumbs up chack info show lcd unkwon
Old 10-11-2012, 13:50   #4 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
CFI information:
2 Block regions:
EBL ready !
0x7819
0x576B
0x7E05
Just change LCD and need and clean pcb i hope solved your problem.
BR.
Arsalan gsm2000.
Old 10-11-2012, 16:45   #5 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
CFI information:
2 Block regions:
EBL ready !
0x7819
0x576B
0x7E05
When Phone not appears in Local Mode,
Means Phone Dead & no way to repair with changing LCD when error is:
Checksum mismatch: Phone calculated 0x75F4, software calculated 0x7E05
So don't play in Hardware,
Select Latest Firmware of Phone Product with Drop Down Menu,
Untick Safe Flash & Click Flash will update your Phone without error.
BR,
ZUBER
Old 10-12-2012, 06:09   #6 (permalink)
Member: 852547
Sonork: 100.1621506
Thanks Meter: 40
Br Zuber, unticked safe flash but same problem. Logs is :
Using device: HTI, FW ver: 00.50, SN: 00000D7B
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
CFI information:
2 Block regions:
EBL ready !
Downloading item CODE:hw_f11_rh125_r06.520.fls, num block: 3, size: 4.14 MB
Programming completed in 43.657 s
Programming completed in 47.469 s
Checksum mismatch: Phone calculated 0xB844, software calculated 0x7819
Downloading item CUST:hw_f11_rh125_006.52mg.fls, num block: 1, size: 1.90 MB
Programming completed in 44.781 s
Checksum mismatch: Phone calculated 0xBC77, software calculated 0x576B
Downloading item CUST:hw_f11_rh1250_nai06.52mg_nlt.fls , num block: 1, size: 790.52 KB
Programming completed in 19.219 s
Checksum mismatch: Phone calculated 0x1075, software calculated 0x7E05
Total time for flashing process(boot+erase+write) was 3 min 27.735 s
Now please suggest how to proceed further
Page generated in 0.18651 seconds with 8 queries
