05-11-2011, 09:38 | #7 (permalink) |
Banned Join Date: Dec 2010 Location: Islamic repablic of pak Age: 37
Member: 1468508 Status: Offline Sonork: 100.1584728 Thanks Meter: 159 | [QUOTE=syed tuqeer;7302851]C1-01 is BB5 (x-Gold) base phone , use BB5 option More Info , click here[/QUOTE |
05-11-2011, 10:25 | #9 (permalink) | |
Registered User Join Date: Oct 2005
Member: 195513 Status: Offline Thanks Meter: 67 | [QUOTE=Dragon Support;7302928] Quote: LOOK AT THIS IT IS FINE AND WORKING! MXKEY Serial: [MxKey HTI FLASHER INTERFACE 3] - C08215F9 Driver: NMWCD, ver: 7.1.32.62, NTMP ver: Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 378C87A0 Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 2.3 EBL version : Quantum_Bootloader_2.3_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6500000 Flash ID: 00EC 2400 [Samsung ] Processing file: rm607__04.40.mcusw Downloading item CODE:rm607__04.40.mcusw_ebl_psi.fls, num block: 5, size: 25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.422 s Erasing area 0x40040000-0x4007FFFE ...OK Programming completed in 0.609 s Erasing area 0x40080000-0x4009FFFE ...OK Programming completed in 0.407 s Erasing area 0x400A0000-0x4019FFFE ...OK Programming completed in 2.407 s Erasing area 0x40400000-0x41B7FFFE ...OK Programming completed in 56.813 s Checksum verified (0xD471) Processing file: rm607__04.40.ppm_l Downloading item CUSTackage_l.ppm_ebl_psi.fls, num block: 1, size: 3.21 MB Erasing area 0x41C00000-0x41F35C5A ...OK Programming completed in 8.344 s Checksum verified (0x7ED7) Processing file: rm607__04.40_003.image_l_ctv_hn_9d7j3 Downloading item CUSTackage_l_ctv_hn.image.fls, num block: 1, size: 11 MB Erasing area 0x42200000-0x43E5FFFE ...OK Programming completed in 24.359 s Checksum verified (0xDB22) Total time for flashing process(boot+erase+write) was 5 min 56.938 s Waiting for device boot up ... Device found: nmwcdc\Nokia C1-01 USB Phonet, PORT_ID: 2F8A6D9E Verifying communication to device OK. Phone Type: RM-607 (C1-01) SW Version: V 04.40 23-02-11 RM-607 (c) Nokia Imei plain: 35697604141406-2 Product Code: 0596359 Battery voltage: 3884 mV, current: 108 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! Imei net: 35697604141406 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! | |
The Following User Says Thank You to glenntelecom For This Useful Post: |
NEW SITE (New Hot Software),Update 20.06.01.... | gsmsolut | GSM Mobile Links | 2 | 06-21-2001 11:44 |
_sHARe_dA sTuFF - mobile.box.sk -HQ releases from Royalgsm and RADiANCE TEAM | mr_johnson | GSM Mobile Links | 1 | 05-19-2001 22:29 |
NEW NEW X-treme Gsm Team | Salami1_1 | GSM Mobile Links | 0 | 04-13-2001 13:57 |
3210 Ver 5.01 | szl | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-20-2000 22:36 |
Need solution for 3210 v5.01 | tati | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-20-2000 21:55 |
