12-24-2009, 03:27 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Sri Lanka
Member: 576633 Status: Offline Thanks Meter: 392 | Mx team help me About 1200 Imei ???????????? Logs are hear ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168Phone Type: RH-99 SW Version: V 5.23 10-03-08 RH-99 (c) NMP Imei plain: ??????????????-? Product Code: 0547525 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: MF Language Pack: - not available. TimeStamp: 2008-03-11T04:08:20Z SW Version: 5.23 Variant Version: 002 ProductProfile: RH99_0547525_5.23_002.spr Simlock: 0547525_SimLockDataVerifier_vDCT4.sim Imei plain is invalid !!! Failed to read SP data Then I try to Go Service --- IMEI & Securty --- Online logger & Do Selected job I try tomeny time But Allwes it's ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0087B8B3A3BDA66 ASIC type: 11 UEM Imei: 35290302380180 Connecting to server ...OK, Login ... دËr• what I can do, Pls help me !!! |
12-24-2009, 12:05 | #8 (permalink) | |
No Life Poster Join Date: Jul 2008
Member: 811779 Status: Offline Thanks Meter: 242 | Quote:
.RPL file according to this imei | |
12-24-2009, 13:27 | #9 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: pakistan
Member: 601913 Status: Offline Sonork: 100.1597350 Thanks Meter: 658 | Quote:
if ur problen is still then write rpl then patch ur phone with ver.4.11 | |
12-24-2009, 17:12 | #11 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Indonesia
Member: 1169189 Status: Offline Sonork: 100.1591528 Thanks Meter: 94 | The important is, MXKey Team must fix this error issue because too many user face this problem. If this error come from mobileEx then fix it first before release new version. And if error caused by connection try to make new solutions. My question is, where you hosted this service? in dedicated server or not? And for sub-domain service, can accessible from each country? Because, idle domain can caused this. Sorry, if i wrong for in this point because i don't know exactly what the problem is. |
mx team help me please | hussam@ | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 08-14-2009 14:23 |
hello MX team plz help me about soon. | themobileshop | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 05-02-2009 16:24 |
plz help me in 1200 imei patch | black snake | Multi-Box | 7 | 01-26-2008 00:55 |
GSMserver Team help me about v3ie downgrade to r479 | xiaoyuz | Smart-Clip | 17 | 12-24-2007 08:44 |
Please help me about change IMEI | dxtx1983 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-01-2006 09:06 |
