12-07-2010, 05:30 | #1 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 702362 Status: Offline Thanks Meter: 49 | mx team help please (ANSWERED) |
12-07-2010, 10:43 | #5 (permalink) |
Member: 702362 Status: Offline Thanks Meter: 49 | nokia 5130c here is the logs contact service after logo.... ''' 'Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0E1001064BA87D563E0FB4F04C8DE84FC3AA8A95 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Original Imei: 35932902626858 Original Product code: 0577793 Bluetooth ID: 00247C445036 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35932902626858-1 Product Code: 0577793 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted |
12-07-2010, 10:46 | #6 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed 5130c is sl3,so you cat repair simlocks without write rpl. |
The Following User Says Thank You to laduka For This Useful Post: |
12-07-2010, 11:08 | #7 (permalink) |
Member: 702362 Status: Offline Thanks Meter: 49 | i have another mobile nokia 5130 actual problem is ,while starting music player it shows memory full, after flashing its shows blank display after logo.......but no errors in flashing i tried with various versions.....please help me |
12-07-2010, 11:16 | #9 (permalink) | |
Freak Poster Join Date: Mar 2007
Member: 469011 Status: Offline Thanks Meter: 33 | Quote:
tray bro 7.97 tested many time | |
The Following User Says Thank You to kkvachhani For This Useful Post: |
12-07-2010, 11:46 | #11 (permalink) |
No Life Poster Join Date: Apr 2005 Location: lebanon Age: 49
Member: 141363 Status: Offline Sonork: 100.1594362 Thanks Meter: 148 | SUPERDONGLE_KEY invalid! u need rpl or backup file to solve your problem br |
The Following User Says Thank You to enzawigroup For This Useful Post: |
12-07-2010, 12:38 | #13 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. if you had flash then it may be water damaged phone or rapido ic problem & it is a hardware problem. the solution is clean the pcb board & reflash it. if not solve heat rapido with medium heat it will solve or after heating procedure reflash will solve your problem 1000000000% i have done it before. click thanks botton if problem solve. |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
12-07-2010, 16:37 | #15 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hello, this case is so many time discussed. all sl3 with corrupted security, the only solution is by original rpl. no backup? please contact Fast Unlocking to purchase rpl. BR sorry, i have to close it. |
The Following User Says Thank You to gbluez For This Useful Post: |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
