01-18-2010, 16:10 | #1 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Pakistan Bahawalpur
Member: 986273 Status: Offline Thanks Meter: 397 | to mx team sl3 unlocking V 1.0.0.24 - 18 Jan 2009 - Support for SL3 data requests and status check. No more need for separate executable for Beta testing of SL3 Unlock, all is activated based on the user server privileges - User Name and Password boxes moved to the About menu. The login credentials will be saved to the ini file regardless if use server check box is selected - New loaders added for not supported RAPIDO hashes Now will be possible to unlock E63 v200 via RPL file (thanks to James for the test phone !) - No more need for good quality cable with RX2 connection this should increase the comm stability with the cables in mass use - Super Dongle data added to calculated RPL file - No more need to have 200 credits for the code reading function orig link: http://forum.gsmhosting.com/vbb/newt...ewthread&f=305 now it is ur turn mx team |
01-20-2010, 21:31 | #3 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | Try to understand that genie solution is not commercial one. Do not expect to get SL3 unlock from them at lower price then 40 EUR / phone. Do not expect to get your phone unlocked by genie in hours, you can expect even few weeks after you have requested your phone to be unlocked w Alex method. And i wander how much will be Alex electricity bill Think before ask something. BR, Manole |
Request TO MX-team | asad_nomy7 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 01-25-2010 09:47 |
A suggestion to MX-TEAM !! | wx654242 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 01-25-2010 07:50 |
To Mx-Team how i know my Mx-Key original or an imitator ? | comp_new2006 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-07-2009 19:25 |
