06-10-2013, 16:21 | #1 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,998 | Mxbox 311 good update atf fail infinity fail mxbox falshing don Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085DE08 Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000F555 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Processing MCU file: rm911__07.37.mcusw [XG223,XG223_V0 ALG] size: 32.87 MB Supported Ids: 00000C2016100040 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 00000C201610004049922E09AAA4F91C66A13600 [XGOLD 223] CMT PUBLIC ID: DF0D20BBF8BAF12F49922E09AAA4F91C66A13600 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 125FC72605B5C4E48A9E0225084D2579 CMT ROM ID: 535882252F54C676 Loading CMT secondary boot code SecondaryBoot: XG223_v11_usb2nd.fg [XG223] version: 12.30.1 revision: 4.0 size: 0x59C0 Supported Ids: 00000C2016000040, 00000C2016100040 Secondary boot loaded. Loading CMT update server data Algorithm: XG223_v11_usbalg.fg [XG223_V0 ALG] version: 12.30.1 revision: 4.0 size: 0x32338 Supported Ids: 00000C2016000040, 00000C2016100040 Update server code loaded. Initializing Update Server ... Configuring Algorithm clients... FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x1B8 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x204 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35459805100590_CERT.rpl" CMT PAPUBKEYS HASH: 2ECFC8C8BB6F1E5571C6D30DAA717E19E9E5C31A Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 39.87 MB CMT FLASH,NOR area [40000000-4003FFFF] CMT FLASH,NOR area [47E00000-47E3FFFF] CMT FLASH,NOR area [400A0000-4261FFFF] CMT FLASH,NOR area [42620000-4271FFFF] CMT FLASH,NOR area [47E40000-47F1FFFF] Flash programming ... CMT ISSW block sent CMT MEMSET block sent CMT PRIMAPP block sent CMT LOADER block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 2ECFC8C8 [] sent CMT UPDAPP block sent CMT MCUSW block sent Programming completed in 21.203 s Processing PPM file: rm911__07.37.ppm_maa [XG223,XG223_V0 ALG] size: 5.73 MB Supported Ids: 00000C2016100040 Erase size: 8.87 MB CMT FLASH,NOR area [42720000-42FFFFFF] erased in 0.015 s Flash programming ... Programming completed in 3.609 s Processing CNT file: E3C28D62_rm911__07.37.image_maa_059R0X1 [XG223,XG223_V0 ALG] size: 44.25 MB Supported Ids: 00000C2016100040 Erase size: 78 MB CMT FLASH,NOR area [43000000-47DFFFFF] erased in 0.031 s Flash programming ... Programming completed in 30.781 s Total time for flashing process(boot+erase+write) was 1 min 7.906 s Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 354598051005903 Verifying communication to device OK. Phone type: RM-911 (Nokia 310) SW version: V 07.37 20-03-13 RM-911 (c) Nokia Imei plain: 35459805100590-3 Product code: 059R0X2 Battery voltage: 4015 mV, current: 104 mA Language Pack: - not available. SLPA ver[5]: PA_SIMLOC30 (20 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 0A350160003011, ver: RPL saved to "C:\mobileEx\3.5\data\backup\BB5_RM-911_354598051005903_10_06_13_201035_SIM.RPL" SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354598051005903 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.844 s |
The Following 3 Users Say Thank You to Tanha0321 For This Useful Post: |
06-10-2013, 18:11 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Good Job Bro. You can share your successful story here: http://forum.gsmhosting.com/vbb/f550...-mxkey-767051/ BR, ZUBER |
