12-25-2012, 14:09 | #1 (permalink) |
Moderator Join Date: Dec 2010 Location: Malaysia
Member: 1464783 Status: Offline Thanks Meter: 1,091 | MXBOX HTI Installation On Windows 8 100% Working With New Driver How To Install HTI Driver: Select Settings (right bar)/More PC Settings (at bottom) Then go General/Advanced Startup/Restart Now/Troubleshoot/Advanced Options/Windows Startup Settings/Restart As your PC is starting up be pressing F8 to get to the menu where you can choose to Disable driver signature enforcement or Enable low-resolution video mode or Enable safe mode. Use This Driver for Microsoft Usbccid Smartcard Reader (WUDF) BR Nizda Mobile |
The Following 8 Users Say Thank You to Nizda Mobile For This Useful Post: |
12-30-2012, 04:11 | #3 (permalink) |
Member: 1464783 Status: Offline Thanks Meter: 1,091 | How To Install HTI Driver: Select Settings (right bar)/More PC Settings (at bottom) Then go General/Advanced Startup/Restart Now/Troubleshoot/Advanced Options/Windows Startup Settings/Restart As your PC is starting up be pressing F8 to get to the menu where you can choose to Disable driver signature enforcement or Enable low-resolution video mode or Enable safe mode. select Disable driver signature enforcement when you pc restart & install all driver. BR Nizda Mobile |
The Following User Says Thank You to Nizda Mobile For This Useful Post: |
09-07-2014, 10:29 | #15 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Other good Info for ALL, NO need all these trouble, if you "PLASTIC COLOUR BOX", Orange, Green, itcc..is always alive you can INSTALL W/O problem also in XP sp3 whith same driver which had Worked Version 3.5 rev.2.5 THIS. So, any new, issue isn't THIS, but that no more supported so cannot Unlock Anythinghs, cannot Flash BB5 right W/O damage device, cannot use S.dongle repair or Sx4 itccccccccc...... What do you do with a piece of plastic with no support or Sw working??? BR allumts | |
