View Poll Results: Is this free MXBOX update useful for you ? | |||
YES | 2,283 | 92.50% | |
I do not have MXBOX | 185 | 7.50% | |
Voters: 2468. You may not vote on this poll |
12-19-2012, 06:26 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | MXBOX/HTI v3.5 revision 2.5 - public discussion thread HTI ONLINE SERVICES module updated to version 2.1 - [IPHONE_CHECK] added dialog message on specific events (license expired, blocked ...) - [IPHONE_FU] countries and carriers are now sorted - improvements to the current systems Some more news for HTI ONLINE SERVICES - USA AT&T - REDUCED price consumption - CANADA TELUS - REDUCED price consumption - DENMARK TELENOR - REDUCED price consumption NOKIA module updated to version 2.5 - added: XG223 phones(new Asha series) support by USB (mode: Nokia Suite) - Normal USB(Nokia Suite) and DEAD USB(Nokia USB ROM) flashing supported - Legacy RPL(IMEI,CCC,HWC,SIMLOCK) backup/restore supported - added latest flash update v 12.33.000.3 to setup - minor bugfix FIRE module updated to version 1.4 - added: Nokia schematics and SM download menu Common changes: - improved internal download task routine(random stop bugfix) - minor bugfix and improvements BUS CHECK LOG: Code: Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device connected: nmwcdnsucx64\Nokia USB Flashing Generic, PORT_ID: 11DB3447 CMT SYSTEM ASIC ID: 00000C201610004049922C09A2E184848332F200 [XGOLD 223] CMT PUBLIC ID: A8222DC55C56BB0F49922C09A2E184848332F200 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 125FC72605B5C4E48A9E0225084D2579 CMT ROM ID: 535882252F54C676 Loading CMT secondary boot code SecondaryBoot: XG223_v11_usb2nd.fg [XG223] version: 12.30.1 revision: 4.0 size: 0x59C0 Supported Ids: 00000C2016000040, 00000C2016100040 Secondary boot loaded. Loading CMT update server data Algorithm: XG223_v11_usbalg.fg [XG223_V0 ALG] version: 12.30.1 revision: 4.0 size: 0x32338 Supported Ids: 00000C2016000040, 00000C2016100040 Update server code loaded. Initializing Update Server ... Configuring Algorithm clients... FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: 42E7CDDAAE2ACD72926AC996E98AEC576D7840C3 Selected firmware certificate matched. Original Imei: 35284105154390 Original Product code: 059N975 Bluetooth ID: C83D97676FA6 SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x204 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 97BB22D Verifying communication to device OK. Phone type: RM-843 (Nokia 309) SW version: V 05.85 23-10-12 RM-843 (c) Nokia Imei plain: 352841051xxxxx-9 Product code: 059N975 Battery voltage: 4073 mV, current: 93 mA Language Pack: - not available. SLPA ver[5]: PA_SIMLOC30 (20 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 115B6002005006, ver: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352841051xxxxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FLASHING LOG: Code: Processing MCU file: rm843__05.85.mcusw [XG223,XG223_V0 ALG] size: 28.91 MB Supported Ids: 00000C2016100040 NOR page size in the phone is 128 K. Battery voltage: 4049 mV Waiting for USB device removal ...OK Waiting for USB device arrival ...OK CMT SYSTEM ASIC ID: 00000C201610004049922C09A2E184848332F200 [XGOLD 223] CMT PUBLIC ID: 0000000000000000000000000000000000000000 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 00000000000000000000000000000000 CMT ROM ID: 535882252F54C676 Using default Root Hash for XG223. Loading CMT secondary boot code SecondaryBoot: XG223_v11_usb2nd.fg [XG223] version: 12.30.1 revision: 4.0 size: 0x59C0 Supported Ids: 00000C2016000040, 00000C2016100040 Secondary boot loaded. Loading CMT update server data Algorithm: XG223_v11_usbalg.fg [XG223_V0 ALG] version: 12.30.1 revision: 4.0 size: 0x32338 Supported Ids: 00000C2016000040, 00000C2016100040 Update server code loaded. Initializing Update Server ... Configuring Algorithm clients... FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: 42E7CDDAAE2ACD72926AC996E98AEC576D7840C3 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 38.87 MB CMT FLASH,NOR area [40000000-4003FFFF] CMT FLASH,NOR area [47E00000-47E3FFFF] CMT FLASH,NOR area [400A0000-4251FFFF] CMT FLASH,NOR area [42520000-4261FFFF] CMT FLASH,NOR area [47E40000-47F1FFFF] Flash programming ... CMT ISSW block sent CMT MEMSET block sent CMT PRIMAPP block sent CMT LOADER block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 42E7CDDA [] sent CMT UPDAPP block sent CMT MCUSW block sent Programming completed in 19.158 s Processing PPM file: rm843__05.85.ppm_x [XG223,XG223_V0 ALG] size: 7.31 MB Supported Ids: 00000C2016100040 Erase size: 9.87 MB CMT FLASH,NOR area [42620000-42FFFFFF] erased in 0.001 s Flash programming ... Programming completed in 4.324 s Processing CNT file: rm843__05.85.image_x_059P061 [XG223,XG223_V0 ALG] size: 43.38 MB Supported Ids: 00000C2016100040 Erase size: 78 MB CMT FLASH,NOR area [43000000-47DFFFFF] erased in 0.007 s Flash programming ... Programming completed in 26.955 s Total time for flashing process(boot+erase+write) was 53.379 s Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 97BB22D Verifying communication to device OK. Phone type: RM-843 (Nokia 309) SW version: V 05.85 23-10-12 RM-843 (c) Nokia Imei plain: 352841051xxxxx-9 Product code: 059N975 Battery voltage: 4054 mV, current: 136 mA Language Pack: - not available. SLPA ver[5]: PA_SIMLOC30 (20 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 115B6002005006, ver: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352841051xxxxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN DOWNLOAD LINK MXBOX v3.5 revision 2.5, Public-Release BR, Manole Last edited by MANOLE; 12-19-2012 at 09:07. |
The Following 353 Users Say Thank You to MANOLE For This Useful Post: |
12-19-2012, 07:00 | #6 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | hti green box dead bus check and scan problem please make a softwer for dead green box |
The Following 4 Users Say Thank You to rahihimkhan For This Useful Post: |
12-19-2012, 07:04 | #8 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | mx team no (1) good team and good update |
The Following 3 Users Say Thank You to .::THE ROCK::. For This Useful Post: |
