Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 02-20-2009, 14:55   #16 (permalink)
Member: 780644
Sonork: 100.88888
April 14 2008
v3.0 Beta9 RC1, Public-Release
Whats NEW:
MAIN
- Improved, Check for updates (more control to updates)
- Implemented, Online News(add RSS feeds and forum news)
- Implemented, Options to enabled/disabled specific module
NK
- MTBOX Partially supported(FBUS function)
- Improved, DCT4 boot
- Improved, Auto phone detection (always "Scan phone" or "Bus check" before any operation!)
- Improved, CDMA phones compatibility
- Improved, Keyboard test map (now possible to test all keys including communicator series)
- Added, Various tests (Camera,IR,MMC,SIM,USB)
- Added, Band & System mode control
- Added, CDMA NVD (Pri) management (under Phone Settings tab)
- Added, CDMA CS product type read
- Added, RF/BB PM backup/restore
- Added, BB5 CNT 128 K conversion
- Added, COMBOFLASH detection
- Fixed, DCT4 write RPL (add DATA1/2 only options)
- Fixed, BB5 Custom erase
- Fixed, DCT4 APE flash(better error handler)
- Improved, DCT4 SP unlock routine
- Improved, CDMA tuning (SET,CAL and PANEL data are now readed and written correctly)
- Redesigned, PMM, Phone Settings, CDMA tune & Quick Fix page(under services tab)
- Reconstructed, BB5 'Dejan K' unlocker
- Introduced, DCT4 read flash works for Asic type 2 phones only (check 'Phoenix format' for writable output) - just for test !
- Introduced, DCT4 Non Volatile Data(NVD) management (in development, not finished yet)
CCS
- Added, ARMPRG/Bootloader manual select to handle 'dead' phones
- Improved, Phone explorer routine and ui
use "Check for Update" button
The Following 18 Users Say Thank You to MANOLE For This Useful Post:
Old 02-20-2009, 15:59   #17 (permalink)
Member: 780644
Sonork: 100.88888
June 08 2008
v3.0 Beta10 RC, Public-Release
Whats NEW:
MAIN
- Added, Support forum and homepage menu (News)
NK
- Added, Image DL button (direct image download from support based on product code, currently for BB5 products only !)
- Implemented, RX2 loader support (UFS FW v28 only !!!).
- Implemented, Show detailed options in configuration window
- Added, Auto select Gen when "Scan" product in configuration window
- Added, Auto set RX2 for BB5 in configuration window
- Added, market highlight for easy market choice in configuration window
- Added, BB5 CNT page size detection for auto CNT conversion
- Added, Skip if not empty option
- Added, Manual PP write file
- Added, BB5 MMC and SD card content flashing
- Added, BB5 verify NPC option on write RPL
- Added, BB5 skip specific section on write RPL
- Added, BB5 skip (certificate) erase option on write RPL
- Added, BB5 Reset NPC
- Added, BB5 online logger client (instant !!!)
- Added, BB5 RPL write on RX2 enabled phones
- Fixed, DCT4 MM flash handling
- Added, DCT4 imei OTP/UEM read via FBUS for non CUI phones.
- Added, Latest DCT4PLUS ASIC11 sp unlock patch method(Patch on the fly)
- Added, DCT4PLUS ASIC11 online logger client
- Added, extended GSM/WCDMA band type set
- Improved, BB5 (RAP/CMT) NAND flash handling
- Improved, Flash chip info. device page size and type now displayed.
- Improved, DCT4PLUS ASIC11 ask read + manual IMEI/ESN input when UEM damaged
- Changed, 'Browse' to Directory setting in configuration window
CCS
- Improved, QCOM protocol for faster flashing
- Improved, Dead phone flashing handle
- Added, Phone code read for 6088,7088 phone
- Added, Image DL button (direct image download from support)
- Fixed, User area backup/restore
The Following 15 Users Say Thank You to MANOLE For This Useful Post:
Old 02-20-2009, 16:24   #18 (permalink)
Member: 780644
Sonork: 100.88888
June 09 2008
v3.0 beta10 RC2 released (
module patch update)
Whats NEW:
- NK library version 1.0.0.4225
-Fixed, BB5 Online Logger
-Fixed, BB5 RAP NAND (with RX2 enabled) flashing
-Added, Full BB5 RPL backup for new phone (SIMLOCK+SIMLOCK_KEY,WMDRM_PD)
-Added, BB5 user code reset(blocked counter) and status, will not lose user data.
-Improved DCT4 Asic 11 Online Logger (Imei challenge issue)
-Added, auto create folder option on configuration window
-Fixed, DP2.0 folder listing
Use "Check for update" but u need to tick "Check modules update automatically" on Options-> General Settings (beta10 required to be installed first !).
After update:
Main:
» mobileEx.exe, version: 3.0.0.2329
» mobileEx.dll, version: 1.0.0.2098
Modules:
» ccs.dll, library version: 1.0.0.498, module version: 1.00 B
» nk.dll, library version: 1.0.0.4225, module version: 1.00 B10a
» siem.dll, library version: 1.0.0.293, module version: 1.01 B
» vcom.dll, library version: 1.0.0.757, module version: 1.03
Drivers:
» UFS2XX.sys, version: 2.2.4.1
» FTD2XX.sys, version: 1.6.20.1
Old 02-22-2009, 06:40   #19 (permalink)
Member: 780644
Sonork: 100.88888
June 27 2008
v3.0 Beta11 RC2, Public-Release
Whats NEW:
MAIN
- Improved, dongle communication routine
- Fixed, Self Update
NK
- MTBOX DCT4 flash supported.
- Improved, DCT4&BB5 Online Logger
- Improved, RX2 auto enabled
- Added, Simple hint "detailed" BB selftests
- Fixed, PP extract for DP2.0 phones
- Added, DCT4PLUS UEM imei read
CCS
- Added, Forced RX queue for better handle of dead phone flashing
- Fixed, Emergency mode Image DL enabled
OTHER
Added Latest mxLogger client(v1.4a) in setup
The Following 16 Users Say Thank You to MANOLE For This Useful Post:
Old 02-22-2009, 06:42   #20 (permalink)
Member: 780644
Sonork: 100.88888
v 3.0 beta12 is out !
November 13 2008
v3.0 Beta12 RC, Public-Release
Whats NEW:
MAIN
- Fixed, dongle registration popup
NK
- DCT3 fully implemented
- Fixed, BB5 flash for new phones
- some improvement and minor bug fixes
CCS
- Fixed, 6066/88 flash
The Following 14 Users Say Thank You to MANOLE For This Useful Post:
Old 02-22-2009, 06:43   #21 (permalink)
Member: 780644
Sonork: 100.88888
Beta13 fixed is ready !
November 26 2008
v3.0 Beta13 RC, Public-Release
Whats NEW:
NK
- Added "skip Restore" patch for DCT4PLUS unlock
- minor bug fixes
VCOM
- Fixed, registration popup
- Added, PK-83 Dongle emulation (you need to install CCS3 Tool first before it works)
Old 02-22-2009, 06:47   #22 (permalink)
Member: 780644
Sonork: 100.88888
Beta14 now ready !
December 08 2008
v3.0 Beta14 RC, Public-Release
Whats NEW:
HW
- MXKEY LiTE dongle firmware version 00.14 released(Improvement dongle check, to avoid CARD BLOCKED)
- Please update using SW build beta14 only.
NK
- Added RAP NAND option in manual erase
- Added, CRC check before flashing if declared in definition files(BB5)
- Image DL in background mode improved (CRC check)
- minor bug fixes
Old 02-24-2009, 11:57   #23 (permalink)
Alim Hape's Avatar
Member: 43548
mobileEx Setup beta15 released !
Changes:
v3.0 Beta15 RC, Public-Release
- MAIN
help file updated
minor bug fixes
- NK
DCTL/LINDA fully implemented with Custom erase to fix old 9210i CS problem
Fixed, Image DL (server communication protocol changed)
Fixed, BB5 custom certificate backup
Fixed, New PP files manual upload
Improved, SUPERDONGLE auth (show the detailed error msg)
Improved, User code reset for BB5 phones
minor bug fixes
Download area for MXKEY users:
http://id.mxkey.biz/downloads.php
Old 03-24-2009, 08:25   #24 (permalink)
Alim Hape's Avatar
Member: 43548
v3.1 Beta16, Public-Release
Changes:
- MAIN
Removed old card protocol(MXKEY REV 1.X/ROCKEY6), for this release only MXKEY REV 2.X card supported
minor bug fixes
- NK
Fixed, loader issue
Added, single phones setting (VPP,RX2, Fast checkbox now saved to config for each phone)
Added, BB5 No TP Unlocker, Dejan RAP3GV2 unlocker removed.
Fixed, `highlight market` bug
minor bug fixes
- CCS
Improved, communication. Dead phones full flashing now working without errors
BR.
Old 03-24-2009, 20:13   #25 (permalink)
Member: 780644
Sonork: 100.88888
Hi,
All MXKEY working with last update V3.1 Beta16 will have, starting today, 1000 mxLogger credits for DCT4 RPL and for DCT4+ RPL.
Old MXKEY dongle that are purchased before 1 march will not have this service for free.
BR,
Manole
Old 03-25-2009, 01:11   #26 (permalink)
Alim Hape's Avatar
Member: 43548
v3.1 Beta16a (Patch update)
Changes:
NK
-Fixed Online logger using "Dongle Id".
Password is automaticaly sent to email address after registration/activation. The email address will be asked when registration process begin, make sure you're entering the correct email address.
BR.
Old 04-17-2009, 05:18   #27 (permalink)
Alim Hape's Avatar
Member: 43548
v3.2 FINAL, Public-Release
- MAIN
Improved Server communication
Added, Support area access
Goto Options->Server->Server List (make selection on 'Support') then Goto Support button will enabled
- NK
Added, Standalone BB5PLUS SL2 No TP Unlocker
PM Auth checkbox also added for some phones which need SUPERDONGLE to be authorized while writing PM120 and PM308
Added, DCT4PLUS "on the fly" imei changes
Improved, DCT4PLUS "on the fly" unlock patch (+new security also supported)
Improved, PM read and write (if field not checked will be skipped)
To Open PM, you can now Drag And Drop PM file to listbox
Fixed, BB5 loaders bug for new phones
Fixed, image download
Fixed, BB5 auto set RX2
Fixed, DCT4PLUS Online Logger bug
minor bug fixes
- VCOM
Fixed, PK-83 binary for MXKEY REV 2.0 compability
#Siemens FREE module recompiled for new api & library compability.
BR.
Old 04-22-2009, 10:52   #28 (permalink)
Alim Hape's Avatar
Member: 43548
v3.2 bug-fixed, Public-Release
- NK
DCT4 RPL server host changed, to fix timeout in some country
Improved, DCT4PLUS "on the fly" unlock patch and imei patch
Added, AMS loader v. 8.49.19.36652 to the installer
minor bug fixes
- VCOM
Fixed, Active-X initialization to fix rx no respond in some pc
Main:
» mobileEx.exe, version: 3.0.0.3182
» mobileEx.dll, version: 1.0.0.3345
Modules:
» ccs.dll, library version: 1.0.0.796, module version: 1.01 B
» nk.dll, library version: 1.0.0.6438, module version: 1.02
» vcom.dll, library version: 1.0.0.935, module version: 1.03
PS:
to avoid confuse to existing users, maybe we will not call any future release a final or beta
Download at:
BR.
Old 06-09-2009, 03:32   #29 (permalink)
Alim Hape's Avatar
Member: 43548
mobileEx v3.2 revision 1.0, Public-Release
- MAIN
Added, UI Localization
;languages selectable from 'quote' menu
;locale files stored to 'locale\*.xml' directory
;added, Chinese (Simplified) language for test (translated using Google Translate, so am sure its not 100% correct), unicode enabled.
;full localization might be added at the future
Added, balloon Tips stored to locale files
Fixed, Application not opened in some PC caused by not previlege account (specially XP SP3 and Vista SP1)
List of loaded drivers version are now displayed at start up
Server list are now selectable
Added, posibility to play custom sound on error/finish
Added, Card Serial Port drivers
;allow to use serial(comport) based reader for the card
Added, 'Nokia USB ROM' virtual device to be used for BB5 USB DEAD PHONE flashing
Fixed, Connect<->Disconnect bug (appl. crash)
- VCOM
Small change in UI
Changed, PK-83 binary to support new drivers
- CCS
Fixed, nkser(6088,6066,7088) driver handling when flashing stop at the middle of process
- NK
Added, BB5 USB Flashing
; Supported loaders
RAP3Gv2+APE(external loader),
RAP3GV3+APE,
RAP3GV3 NON APE+DEAD FLASH,
RAPIDO NON APE+DEAD FLASH,
RAPIDO +APE,
RAPIDO (RAP3NAND) NON APE+DEAD FLASH.
; Version check mechanism is possible when flashing NON DEAD phone
; LANGUAGE only option also posible for fast and safe phone update
Added, Multiple version of flash update/loaders
; selectable from 'quote' menu 'Config->Directory'
; Newer phones might need newer flash loader, by default is '8.6.1.31560'
Fixed, BB5PLUS RAPIDO SL2 spunlock
Added, Pinout image for UFC based cable (press small button near phone image)
; pinout images are stored at 'data\image\pinout' directory
Multiple Data Package directory are now possible (usefull when working with Multi-OS PC)
Added, 'Force WHOLE flash' on erase(Advance Page) to allow RAP flash full erase (Last chance, if NPC reset still not work to revive DEAD/BLINK Phone)
Added, PP file read
Added, Phonebook/Contacts backup and restore (Phone Settings->Selection:User Settings)
Removed, Host setting (please use 'select server' from Main|Server List page)
- SIEM
Siemens module recompiled for new api compability
Download at:
http://id.mxkey.biz/downloads.php or goto Support Area for existing users.
PS: To go to Support Area, Go Options page->Server, push 'Server List' then select on of active server so "go to Support Area" will be enabled.
Old 06-09-2009, 19:35   #30 (permalink)
Alim Hape's Avatar
Member: 43548
v3.2 revision 1.1, Public-Release
#Patch update
- NK
Fixed, Online Logger not shown when 'Imei changes' disabled.
Fixed, BB5 Restore Imei+Write RPL
Download at:
MXKEY - Official Mirror (rapidshare)
http://rapidshare.com/users/P5JHS5
will also available in support area and download page.
BR.
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
ORIGINAL SOFTWARE FOR SALE OR TRADE !!!!!!!!!!!!!!!!! andrew bennett Main Sales Section 1 07-27-1999 21:31
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 0.64875 seconds with 11 queries
