Member: 749297
Sonork: umukri Thanks Meter: 2 | after update 3.5 2.5 my mx key card is blocked please contact reseller, please help Quote:
Originally Posted by MANOLE v3.5 revision 2.5, Public-Release HTI ONLINE SERVICES module updated to version 2.1
- [IPHONE_CHECK] added dialog message on specific events (license expired, blocked ...)
- [IPHONE_FU] countries and carriers are now sorted
- improvements to the current systems
Some more news for HTI ONLINE SERVICES
- USA AT&T - REDUCED price consumption
- CANADA TELUS - REDUCED price consumption
- DENMARK TELENOR - REDUCED price consumption NOKIA module updated to version 2.5
- added: XG223 phones(new Asha series) support by USB (mode: Nokia Suite)
- Normal USB(Nokia Suite) and DEAD USB(Nokia USB ROM) flashing supported
- Legacy RPL(IMEI,CCC,HWC,SIMLOCK) backup/restore supported
- added latest flash update v 12.33.000.3 to setup
- minor bugfix FIRE module updated to version 1.4
- added: Nokia schematics and SM download menu Common changes:
- improved internal download task routine(random stop bugfix)
- minor bugfix and improvements BUS CHECK LOG: Code: Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsucx64\Nokia USB Flashing Generic, PORT_ID: 11DB3447
CMT SYSTEM ASIC ID: 00000C201610004049922C09A2E184848332F200 [XGOLD 223]
CMT PUBLIC ID: A8222DC55C56BB0F49922C09A2E184848332F200
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 125FC72605B5C4E48A9E0225084D2579
CMT ROM ID: 535882252F54C676
Loading CMT secondary boot code
SecondaryBoot: XG223_v11_usb2nd.fg [XG223] version: 12.30.1 revision: 4.0 size: 0x59C0
Supported Ids: 00000C2016000040, 00000C2016100040
Secondary boot loaded.
Loading CMT update server data
Algorithm: XG223_v11_usbalg.fg [XG223_V0 ALG] version: 12.30.1 revision: 4.0 size: 0x32338
Update server code loaded.
Initializing Update Server ...
Configuring Algorithm clients...
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: 42E7CDDAAE2ACD72926AC996E98AEC576D7840C3
Selected firmware certificate matched.
Original Imei: 35284105154390
Original Product code: 059N975
Bluetooth ID: C83D97676FA6
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x204 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Waiting for device boot up ...
Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 97BB22D
Verifying communication to device OK.
Phone type: RM-843 (Nokia 309)
SW version: V 05.85 23-10-12 RM-843 (c) Nokia
Imei plain: 352841051xxxxx-9
Battery voltage: 4073 mV, current: 93 mA
Language Pack:
- not available.
SLPA ver[5]: PA_SIMLOC30 (20 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: 115B6002005006, ver:
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 352841051xxxxxx
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FLASHING LOG: Code: Processing MCU file: rm843__05.85.mcusw
[XG223,XG223_V0 ALG] size: 28.91 MB
Supported Ids: 00000C2016100040
NOR page size in the phone is 128 K.
Battery voltage: 4049 mV
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
CMT PUBLIC ID: 0000000000000000000000000000000000000000
CMT ROOT KEY HASH: 00000000000000000000000000000000
Using default Root Hash for XG223.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Erase size: 38.87 MB
CMT FLASH,NOR area [40000000-4003FFFF]
CMT FLASH,NOR area [47E00000-47E3FFFF]
CMT FLASH,NOR area [400A0000-4251FFFF]
CMT FLASH,NOR area [42520000-4261FFFF]
CMT FLASH,NOR area [47E40000-47F1FFFF]
Flash programming ...
CMT ISSW block sent
CMT MEMSET block sent
CMT PRIMAPP block sent
CMT LOADER block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 42E7CDDA [] sent
CMT UPDAPP block sent
CMT MCUSW block sent
Programming completed in 19.158 s
Processing PPM file: rm843__05.85.ppm_x
[XG223,XG223_V0 ALG] size: 7.31 MB
Erase size: 9.87 MB
CMT FLASH,NOR area [42620000-42FFFFFF] erased in 0.001 s
Programming completed in 4.324 s
Processing CNT file: rm843__05.85.image_x_059P061
[XG223,XG223_V0 ALG] size: 43.38 MB
Erase size: 78 MB
CMT FLASH,NOR area [43000000-47DFFFFF] erased in 0.007 s
Programming completed in 26.955 s
Total time for flashing process(boot+erase+write) was 53.379 s
Battery voltage: 4054 mV, current: 136 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN DOWNLOAD LINK MXBOX v3.5 revision 2.5, Public-Release
BR,
Manole | after update 3.5 2.5 my mx key card is blocked please contact reseller, please help |
