Old 02-19-2013, 15:04   #1 (permalink)
Member: 151584
Sonork: ghauribrothers
Thanks Meter: 39
Mxbox kept on blinking lights/connecting and disconnecting....hepl
Hi there,
When I connect MXBOX to the cable,it kept on bilnking red and yellow lights and sounds like connecting and disconnecting... i need you to help me solve this asap... thanx
Old 02-19-2013, 15:09   #2 (permalink)
FasGsm's Avatar
Member: 283725
Sonork: 100.1584053
Thanks Meter: 1,927
Originally Posted by Bismillah_mob View Post
Hi there,
just connect box and update firmware no matter if drivers r not installed.
Old 02-20-2013, 11:56   #3 (permalink)
Member: 151584
Thanks Meter: 39
if it is drivers problem then it should ask for drivers intallation... but its not... its jst blikns lights and nothing else.... plz hlep
Old 02-20-2013, 12:00   #4 (permalink)
samithashiva's Avatar
Member: 1356665
Sonork: 123
Thanks Meter: 31
remove setup and reinstall v3.5 2.5 then update agin ur problem is solve its tested solution
Old 02-20-2013, 12:24   #5 (permalink)
Member: 464619
Thanks Meter: 40
Waiting for HTI in boot mode ...
Aborted (timeout on device scan), please make retry !
Old 02-24-2013, 07:36   #6 (permalink)
Member: 151584
Thanks Meter: 39
i have removed all previous setups and drivers as well and re installed latest version but the problem is same still... still on blinking lights while vonnecting... i think manole himself should take some responsibility.... im waiting for solution coz without that i cannot use my HTI credits and iphone section... plz help
Old 02-24-2013, 07:37   #7 (permalink)
Member: 151584
Thanks Meter: 39
i have removed all previous setups and drivers as well and re installed latest version but the problem is same still... still on blinking lights while connecting... i think manole himself should take some responsibility.... im waiting for solution coz without that i cannot use my HTI credits and iphone section... plz help
Old 02-24-2013, 07:51   #8 (permalink)
Member: 1842527
Thanks Meter: 40
bro 1 st send ur box model iam solved ur problim
Old 02-27-2013, 11:31   #9 (permalink)
Member: 151584
Thanks Meter: 39
bro can u cehck it via TeamViewer????
Old 02-27-2013, 11:38   #10 (permalink)
Member: 558339
Thanks Meter: 10
My box was analogous situation
Old 02-27-2013, 11:41   #11 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Hi there,
blinking led indicates HTI FW problem. please update HTI.
try to update first your HTI box.
- do not plug hti to pc
- make sure you are using LATEST version: 3.5rev2.5
- do not connect box to USB. open mobileex.exe, ignore no dongle detection
- press update HTI, plug HTI to usb immediately.
- proceed with driver installation after update FW is done.
Old 02-27-2013, 12:14   #12 (permalink)
Member: 558339
Thanks Meter: 10
Old 02-27-2013, 16:06   #13 (permalink)
Member: 151584
Thanks Meter: 39
Receive firmware from server ...
[UnauthorizedFault] Update service is busy, please try again later !
ERROR: Receive buff error no: 0x00
» End transaction (status: 13, Failed to fetch data from server.)
this error occuring..... plz help team...
Old 02-28-2013, 22:36   #14 (permalink)
Member: 223770
Thanks Meter: 49
plz my hti when i connect to usb "péripherique usb non reconnu "
i use mobileEx_setup_v3.5_rev2.5(20121212) i installe the driver from path C:\mobileEx\3.5\data\drivers\hti
bat no result plz help
Old 03-03-2013, 17:02   #15 (permalink)
Member: 151584
Thanks Meter: 39
i think no frnd have any solution.... its useless to appeal again n again....
Page generated in 0.21620 seconds with 8 queries
