MXBOX - NOKIA NEW/Old PROTOCOL Successfully Unlocked/Repaired/Flashed By MXBOX C 5 Buscheck MXKEY Serial: C0xxxxx Using device: HTI BOX, FW ver: 00.07 Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 2260020D75A20344C9B40A05294D5CBFDF66F9AB ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.10.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.10.0 revision: 3.0 size: 0xC621C Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Original Imei: 35484xxxxxxxxxx Original Product code: 0592678 Bluetooth ID: 18145610878F SIMLOCK PA identifier: [0] PA_SL3 Phone Type: RM-645 (Nokia C5-00) SW Version: V ICPR82_10w18.5.2 16-07-10 RM-645 (c) Nokia Imei plain: 3548470xxxxxxx-8 Product Code: 0592678 Battery voltage: 4628 mV, current: 123 mA ApeCoreSw: 032.010 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35484xxxxxxxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Flash Log MXKEY Serial: C0xxxxx Using device: HTI BOX, FW ver: 00.07 Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 2260020D75A20344C9B40A05294D5CBFDF66F9AB ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.10.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.10.0 revision: 3.0 size: 0xC621C Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Processing MCU file: rm645_032.010_prd.core.fpsx [BB5,XSR 1.6] size: 90.95 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 170.06 MB CMT MuxOneNAND area [00020000-0003FFFF] CMT MuxOneNAND area [00060000-004DFFFF] CMT MuxOneNAND area [008E0000-0AE3FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 (RAP Certificate v1 249) sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 4 min 31.797 s Processing PPM file: rm645_032.010_10.01_MEA_A_prd.rofs2.fpsx [BB5,XSR 1.6] size: 39.25 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 51 MB CMT MuxOneNAND area [06D40000-0A03FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 1 min 55.016 s Processing PPM file: rm645_032.010_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 7.94 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 14 MB CMT MuxOneNAND area [0A040000-0AE3FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.297 s Processing CNT file: rm645_032.010_U000.000_prd.uda.fpsx [BB5,XSR 1.6] size: 1.76 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 72 MB CMT MuxOneNAND area [0AE40000-0F63FFFF] Flash programming ... Programming completed in 5.781 s Processing CNT file: rm645_ENO_v_0.NCP17_APEONLY.fpsx [BB5,XSR 1.6] size: 2.35 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 4 MB CMT MuxOneNAND area [004E0000-008DFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 7.141 s Total time for flashing process(boot+erase+write) was 6 min 49.687 s Phone Type: RM-645 (Nokia C5-00) SW Version: V ICPR82_10w18.5.2 16-07-10 RM-645 (c) Nokia Imei plain: 354xxxxxxxxxxxxx Product Code: 0592678 Battery voltage: 4588 mV, current: 120 mA ApeCoreSw: 032.010 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3548xxxxxxxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
Nokia X 3.02 Buscheck Log MXKEY Serial: C080573D Using device: HTI BOX, FW ver: 00.07 Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 1DF0001972825440708EFA742602CD27A12A8A22 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.10.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.10.0 revision: 3.0 size: 0xC621C Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 CMT PAPUBKEYS HASH: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C Original Imei: 35596xxxxxxxxxx Original Product code: 0598245 Bluetooth ID: A071A99B9A1A SIMLOCK PA identifier: [0] PA_SIMLOC30 Phone Type: RM-639 (Nokia X3-02) SW Version: V 05.65 26-11-10 RM-639 (c) Nokia Imei plain: 3559xxxxxxxxxxxx Product Code: 0598245 Battery voltage: 4644 mV, current: 112 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3559xxxxxxxxxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Flash Log MXKEY Serial: C080573D Using device: HTI BOX, FW ver: 00.07 Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 1DF0001972825440708EFA742602CD27A12A8A22 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.10.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.10.0 revision: 3.0 size: 0xC621C Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 CMT PAPUBKEYS HASH: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C Processing MCU file: rm639__05.65.mcusw [BB5,XSR 1.6] size: 30.64 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 45.06 MB CMT MuxOneNAND area [00020000-000203FF] CMT MuxOneNAND area [00060000-0009FFFF] CMT MuxOneNAND area [000A0000-0041FFFF] CMT MuxOneNAND area [00420000-0069FFFF] CMT MuxOneNAND area [006A0000-006DFFFF] CMT MuxOneNAND area [006E0000-0123FFFF] CMT MuxOneNAND area [02060000-020BFFFF] CMT MuxOneNAND area [02CC0000-0333FFFF] CMT MuxOneNAND area [07540000-07B3FFFF] CMT MuxOneNAND area [01240000-0205FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C (RAP Certificate v1 260) sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT LDSP block sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 1 min 52.984 s Processing PPM file: rm639__05.65.ppm_meac [BB5,XSR 1.6] size: 6.93 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Partitioning ...OK Erase size: 12 MB CMT MuxOneNAND area [020C0000-02CBFFFF] Flash programming ... Programming completed in 25.719 s Processing CNT file: rm639__05.65.image_meac_0598437_005 [BB5,XSR 1.6] size: 27.11 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Partitioning ...OK Erase size: 66.06 MB CMT MuxOneNAND area [03340000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 1 min 39.688 s Total time for flashing process(boot+erase+write) was 4 min 10.688 s Phone Type: RM-639 (Nokia X3-02) SW Version: V 05.65 26-11-10 RM-639 (c) Nokia Imei plain: 35596xxxxxxxxxxx Product Code: 0598245 Battery voltage: 4644 mV, current: 109 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3559xxxxxxxxxxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
MXBOX - Successfully Unlocked/repaired/flashed Phones By MXBOX / HTI 6303 Successfully Flashed by HTI http://i318.photobucket.com/albums/m...htiflasher.jpg Version from phone: 09.10 Version from file: 10.12 MXKEY Serial: C0800474 Using device: HTI BOX, FW ver: 00.07 Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) Reading Important data ... Reading RPL backup ... Reading Phone ID ... SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F productData saved. Restarting phone ... Reading Secure Storage ... Reading SIMLOCK data ... Reading CERT data ... CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0A500102CC1468508AA3FCDBA68752B59CD4BB43 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 TransmissionMode: DDR&TX2 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Flash Imei: 35825603439624 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK SUPERDONGLE_KEY_DATA saved OK CMLA_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35825603439624_BA CK.rpl" CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0A500102CC1468508AA3FCDBA68752B59CD4BB43 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 TransmissionMode: DDR&TX2 Processing MCU file: rm443__10.12.mcusw [BB5,BB5 ALGORITHM] size: 24.67 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Storing certificate [NPC, R&D, CCC, HWC] ...OK Erase size: 28.25 MB CMT NOR area [00000000-0001FFFF] CMT NOR area [00040000-0005FFFF] CMT NOR area [00060000-0007FFFF] CMT NOR area [00080000-0015FFFF] CMT NOR area [00160000-0023FFFF] CMT NOR area [01740000-0191FFFF] CMT NOR area [00240000-0173FFFF] CMT NOR area [022E0000-0261FFFF] erased in 2 min 26.344 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 (RAP Certificate 140 v.1) sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT ISA+DYNSW block sent Programming completed in 5 min 54.594 s Processing PPM file: rm443__10.12.ppm_cvf [BB5,BB5 ALGORITHM] size: 6.50 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 9.75 MB CMT NOR area [01920000-022DFFFF] erased in 42.359 s Flash programming ... Programming completed in 1 min 32.438 s Processing CNT file: rm443__10.12_ISM_009.image_c_uk_steel_voda_uk_stee l_v3 [BB5,BB5 ALGORITHM] page size: 128 K size: 12.51 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Converting UCP blocks to 128 K. Erase size: 25.62 MB CMT NOR area [02620000-029BFFFF] CMT NOR area [029C0000-03FBFFFF] erased in 3 min 11.906 s Flash programming ... Programming completed in 2 min 57.046 s Total time for flashing process(boot+erase+write) was 17 min 5.421 s After Flash Processing ... Reseting Factory Values OK. Phone Type: RM-443 (Nokia 6303 classic) SW Version: V 10.12 08-04-10 RM-443 (c) Nokia Imei plain: 35825603439624-8 Product Code: 0569174 Battery voltage: 4909 mV, current: 56 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358256034396248 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Br. GsmEasy |
nokia n70 flashed successfully Using device: HTI BOX, FW ver: 00.07 Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) Reading Important data ... Reading RPL backup ... Reading Secure Storage ... Reading SIMLOCK data ... Reading CERT data ... APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 56C6BB988DCDDF5EDC20C375639AB1020BFFF6F8 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 071001187D80635125F57AA5E3AA340740143DF8 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 0098 0036 - 00A5 00C0 [Toshiba 512 DDP NAND,512 Mbits] type: NAND,APE ALG [35]: OMAP1610 GBBM-1.8.1 ALG ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000 Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x4E9 bytes). Reading CMT CCC (0x0 bytes). Reading CMT HWC (0x0 bytes). Reading APE NPC (0x0 bytes). Reading APE VARIANT (0x0 bytes). Reading APE CCC (0x0 bytes). Reading APE HWC (0x0 bytes). Flash Imei: 35808001558763 NPC_DATA saved OK VARIANT_DATA saved OK SUPERDONGLE_KEY_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35808001558763_BA CK.rpl" APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 56C6BB988DCDDF5EDC20C375639AB1020BFFF6F8 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 071001187D80635125F57AA5E3AA340740143DF8 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 0098 0036 - 00A5 00C0 [Toshiba 512 DDP NAND,512 Mbits] type: NAND,APE ALG [35]: OMAP1610 GBBM-1.8.1 ALG ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000 Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Processing MCU file: RM84_50737301.C0 [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 29.41 MB Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200 Supported Ids: 17100701, 17100702 Supported speed: 650000, 6500000, 6500000, 98000 Partitioning ...OK Erase size: 68.92 MB CMT NOR area [00000000-0052B515] CMT NOR area [006A0000-006BFFFF] CMT NOR area [006DF000-006EFFFF] CMT NOR area [00700000-007EFFFF] APE NAND area [00000000-0000FFFF] APE NAND area [00010000-0001FFFF] APE NAND area [00020000-000203FF] APE NAND area [00050000-03ECFFFF] erased in 37.422 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D (Rap certificate3) sent APE KEYS block sent APE X-LOADER block sent APE PRIMAPP block sent APE SOS+LOADER block sent APE SOS+XZIP block sent APE PASUBTOC block sent APE PAPUBKEYS: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D (APE certificate3) sent APE SOS*CORE block sent Programming completed in 2 min 47.296 s Processing PPM file: RM84_50737301.V32 [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 10.27 MB Supported Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200 Supported Ids: 17100700, 17100701, 17100702, 17100703 Supported speed: 650000, 6500000, 6500000, 100000 Partitioning ...OK Erase size: 35.94 MB APE NAND area [01AE0000-02AFFFFF] APE NAND area [02B00000-03ECFFFF] erased in 0.047 s Flash programming ... Programming completed in 2 min 9.532 s Processing APE Variant file: RM84_50737301.UDA [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 3.75 MB Supported Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200 Supported Ids: 17100701, 17100702 Supported speed: 650000, 6500000, 6500000, 100000 erase skipped (no erase descriptor). Erase skipped. Flash programming ... Programming completed in 50.203 s Total time for flashing process(boot+erase+write) was 6 min 40.750 s Phone Type: RM-84 (Nokia N70) SW Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. Imei plain: 35808001558763-7 Product Code: 0539276 Battery voltage: 4866 mV, current: 107 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358080015587637 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
6120c New Protocol Type Buscheck Log MXKEY Serial: C0XXXXX Using device: HTI BOX, FW ver: 00.07 Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0470010B899E0052A04DCA5F192D31AB62B136DB ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FlashID0: 0400 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT ALG [35]: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.10.0 revision: 2.0 size: 0x875B6 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 CMT PAPUBKEYS HASH: 0FE1BA92D924A658E4800780FA6F4868100AC947 Original Imei: 352xxxxxxxxxxxx Original Product code: 0547931 Bluetooth ID: D4CBAFB7155A SIMLOCK PA identifier: [0] PA_SL2 Phone Type: RM-243 (Nokia 6120) SW Version: V 07.10 15-07-09 RM-243 (c) Nokia Imei plain: 352xxxxxxxxxxxx Product Code: 0547931 Battery voltage: 4524 mV, current: 72 mA ApeCoreSw: 07.10 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SECURITY_TEST passed Imei net: 352xxxxxxxxxxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Flash Log MXKEY Serial: C0XXXXXX Using device: HTI BOX, FW ver: 00.07 Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0470010B899E0052A04DCA5F192D31AB62B136DB ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FlashID0: 0400 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT ALG [35]: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.10.0 revision: 2.0 size: 0x875B6 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 CMT PAPUBKEYS HASH: 0FE1BA92D924A658E4800780FA6F4868100AC947 Processing MCU file: rm243_07.20_prd_core.fpsx [BB5,XSR 1.5] size: 43.63 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101031105, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103, 4003192101051105, 400C192101051105 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 74.81 MB CMT MuxOneNAND area [00040000-00082FFF] CMT MuxOneNAND area [00083400-0087FFFF] CMT MuxOneNAND area [00B80000-04DFFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 0FE1BA92D924A658E4800780FA6F4868100AC947 (RAP Certificate 68 v1) sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS*CORE block sent CMT SOS+ROFS block sent Programming completed in 2 min 34.344 s Processing PPM file: rm243_07.20_prd_vB21_01_mea_b.fpsx [BB5,XSR 1.5] size: 19.75 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101031105, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103, 4003192101051105, 400C192101051105 Erase size: 27 MB CMT MuxOneNAND area [03300000-04DFFFFF] Flash programming ... CMT SOS+ROFX block sent Programming completed in 1 min 13.406 s Processing CNT file: rm243_07.20_prd_UDA_Classic_Blue.fpsx_128 [BB5,XSR 1.5] size: 111.26 KB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105 UCP page size is 128 K. Erase size: 45.25 MB CMT MuxOneNAND area [04E00000-07B3FFFF] Flash programming ... Programming completed in 0.875 s Processing APE Variant file: rm243_ENO_A_2009wk15v0.100.fpsx [BB5,XSR 1.5] size: 1.41 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101031105, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103, 4003192101051105, 400C192101051105 Erase size: 3 MB CMT MuxOneNAND area [00880000-00B7FFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 5.844 s Total time for flashing process(boot+erase+write) was 4 min 6.968 s Phone Type: RM-243 (Nokia 6120) SW Version: V 07.20 05-10-09 RM-243 (c) Nokia Imei plain: 35xxxxxxxxxxxxxxx Product Code: 0547931 Battery voltage: 4682 mV, current: 74 mA ApeCoreSw: 07.20 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SECURITY_TEST passed Imei net: 352xxxxxxxxxxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
Nokia N81 RM-223 Flash By MXBOX/HTI Nokia N81 RM-223 Flash By MXBOX/HTI MXKEY Serial: C0808888 Using device: HTI BOX, FW ver: 00.07 Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0F10020B327B0052BF13B7F85A1DC35E970F29B9 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FlashID0: 0400 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0221 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 9.50.0 revision: 2.0 size: 0x70C62 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 CMT PAPUBKEYS HASH: E70C21157D5AB5AF61AAD376910751FB06D6E9FD Processing MCU file: RM223_20.0.057_prd.C00 [BB5,XSR 1.5] size: 46.66 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 92.37 MB CMT MuxOneNAND area [00040000-00082FFF] CMT MuxOneNAND area [00083400-0087FFFF] CMT MuxOneNAND area [00B80000-05F7FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: E70C21157D5AB5AF61AAD376910751FB06D6E9FD (RAP Certificate 45 V1) sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS*CORE block sent CMT SOS+ROFS block sent Programming completed in 2 min 21.415 s Processing PPM file: RM223_20.0.057_prd_1701.V17 [BB5,XSR 1.5] size: 23.71 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103 Erase size: 40.31 MB CMT MuxOneNAND area [03730000-05F7FFFF] Flash programming ... CMT SOS+ROFX block sent Programming completed in 1 min 15.419 s Processing CNT file: RM223_20.0.057_003_000_U03_uda.fpsx [BB5,XSR 1.5] size: 74.71 KB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101011105, 400C192101011105, 4003192101021103, 400C192101021103 Erase size: 26.44 MB CMT MuxOneNAND area [05F80000-079DFFFF] Flash programming ... Programming completed in 0.890 s Total time for flashing process(boot+erase+write) was 3 min 45.569 s Phone Type: RM-223 (Nokia N81) SW Version: V 06wk41v56.1 18-04-08 RM-223 (c) Nokia Imei plain: 3519350xxxxxxx Product Code: 0554834 Battery voltage: 4773 mV, current: 43 mA ApeCoreSw: 20.0.057 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3519350xxxxxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BR. lieren |
Nokia N81 RM-223 Flash By MXBOX/HTI http://www.gsm88.com/bbs/attachment/...c89c7331ed.jpg Nokia N81 RM-223 Flash By MXBOX/HTI MXKEY Serial: C0808888 Using device: HTI BOX, FW ver: 00.07 Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0F10020B327B0052BF13B7F85A1DC35E970F29B9 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FlashID0: 0400 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0221 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 9.50.0 revision: 2.0 size: 0x70C62 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 CMT PAPUBKEYS HASH: E70C21157D5AB5AF61AAD376910751FB06D6E9FD Processing MCU file: RM223_20.0.057_prd.C00 [BB5,XSR 1.5] size: 46.66 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 92.37 MB CMT MuxOneNAND area [00040000-00082FFF] CMT MuxOneNAND area [00083400-0087FFFF] CMT MuxOneNAND area [00B80000-05F7FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: E70C21157D5AB5AF61AAD376910751FB06D6E9FD (RAP Certificate 45 V1) sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS*CORE block sent CMT SOS+ROFS block sent Programming completed in 2 min 21.415 s Processing PPM file: RM223_20.0.057_prd_1701.V17 [BB5,XSR 1.5] size: 23.71 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103 Erase size: 40.31 MB CMT MuxOneNAND area [03730000-05F7FFFF] Flash programming ... CMT SOS+ROFX block sent Programming completed in 1 min 15.419 s Processing CNT file: RM223_20.0.057_003_000_U03_uda.fpsx [BB5,XSR 1.5] size: 74.71 KB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101011105, 400C192101011105, 4003192101021103, 400C192101021103 Erase size: 26.44 MB CMT MuxOneNAND area [05F80000-079DFFFF] Flash programming ... Programming completed in 0.890 s Total time for flashing process(boot+erase+write) was 3 min 45.569 s Phone Type: RM-223 (Nokia N81) SW Version: V 06wk41v56.1 18-04-08 RM-223 (c) Nokia Imei plain: 3519350xxxxxxx Product Code: 0554834 Battery voltage: 4773 mV, current: 43 mA ApeCoreSw: 20.0.057 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3519350xxxxxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BR. lieren |
RM-721 (Nokia C2-01) Flash By MXBOX/HTI Code: Version from phone: 10.50 |
6700 c 1 Attachment(s) Code: Version from phone: 07.60 |
Nokia - 7230 1 Attachment(s) Code: Version from phone: 06.90 |
6700s superdongle_key backup by mxbox/hti 6700S SUPERDONGLE_KEY BACKUP BY MXBOX/HTI Code: Using device: HTI BOX, FW ver: 00.07 LIEREN |
6700S Successfully Flashed by MXBOX/HTI 6700S Successfully Flashed by MXBOX/HTI http://i56.tinypic.com/33o5fsy.jpg Code: Using device: HTI BOX, FW ver: 00.07 lieren |
Nokia 3110c flashed successfully but still cnt extraction unsuccessfull (gallery empty) Quote:
