08-02-2009, 07:00 | #167 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | 3120c_UNLOCKED_SUCCESSFULLY_WITH_MY_GR8_MXKEY_TOOL Provider: Hutchinson 3G, Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050600042465540 PROFILE_BITS: 8000000000000002 BLOCK 1: 1=LOCKED (MCC+MNC): 50506F, DATA=50506F BLOCK 2: 1=LOCKED (MCC+MNC): 50599F, DATA=50599F BLOCK 3: 1=LOCKED (MCC+MNC): 00101F, DATA=00101F Backup saved to "BB5_354193031199446_SIMLOCK.back" ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending bootloader, size: 0x3C00 ... Calculating data ...OK Writing PM buffer ... OK Completed in 22.906 s Restarting phone ... Reading Simlock info ... Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=00101F BR |
The Following User Says Thank You to mobile_hotman For This Useful Post: |
08-02-2009, 07:37 | #168 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | NOKIA 3500C RM-272 SL REPAIR AND UNLOCK GOOD Code: Counter: 0/3, 1/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Backup saved to "BB5_357686013777052_SIMLOCK.back" ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending bootloader, size: 0x3D00 ... Calculating data ...OK Receiving PM buffer, please WAIT ... OK Writing PM buffer ... OK Completed in 23.937 s Restarting phone ... Reading Simlock info ... Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF READED INFO Code: Version Info: MCU SW version: V 06.01 16-01-08 RM-272 (c) Nokia. HW version: 1000 RFIC version: 17211721 DSP version: 06w14pb_07w39 PPM version: V 06.01 16-01-08 RM-272 (c) Nokia. MR Retu version: 32 Tahvo version: 53 Content Pack version: Content: mr V 06.01 16-01-08 RM-272 (c) Nokia. Product Info: Production serial number: 7C4731270 Product code: 0549190 Module code: 0203472 Basic production code: 0548284 Serial Numbers: IMEI plain: 357686013777052 IMEI spare to net: 3A 75 86 06 31 77 07 05 IMEI SV to net: 33 75 86 06 31 77 07 15 F5 Other Info: Model : Nokia 3500c (Classic Phone) BSI: 5.1 KOhm Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF WBR sahil2000ind |
08-02-2009, 09:06 | #169 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | NOKIA 2680s-2 RM-392 FLASHED AND REPAIRED SUCESSFULLY BY MX-KEY Code: Processing file: rm392__06.17.mcusw ASIC ID: 0x3162 [UPP_8M ver: 6.11] u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x56E8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00533EA2:3B8ADA60 Programming MCU ... rm392__06.17.mcusw: [DCT4,DCT4 ALGORITHM] size: 11.81 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 Area [01000000-0101FFFF] erased in 1.156 s Area [01020000-01CFFFFF] erased in 2 min 0.000 s Flash programming ... Programming completed in 1 min 9.047 s File Processed in 3 min 23.172 s Processing file: rm392__06.17.image_mr ASIC ID: 0x3162 [UPP_8M ver: 6.11] u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x56E8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00533EA2:C5A4DA78 Programming Content Pack ... rm392__06.17.image_mr: [DCT4,DCT4 ALGORITHM] page size: 128 K size: 3.50 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 Area [02180000-02E7FFFF] erased in 2 min 2.656 s Area [02E80000-02FBFFFF] erased in 11.734 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 22.703 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.062 s File Processed in 3 min 1.438 s Processing file: rm392__06.17.ppm_mr ASIC ID: 0x3162 [UPP_8M ver: 6.11] u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x56E8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00533EA2:2984DA60 Programming PPM ... rm392__06.17.ppm_mr: [DCT4,DCT4 ALGORITHM] size: 3.79 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 Area [01D00000-0217FFFF] erased in 47.672 s Flash programming ... Programming completed in 26.859 s File Processed in 1 min 20.500 s Flashing completed in 7 min 48.172 s Phone Type: RM-392 (Nokia 2680s-2) SW Version: V 06.17 10-03-09 RM-392 (c) Nokia Imei plain: 35639002193460-4 Imei OTP: 35639002193460 Product Code: 0564331 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: MR Language Pack: - not available. Imei net: 35639002193460 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 7 min 59.703 s READED INFO Code: Version Info: MCU SW version: V 06.17 10-03-09 RM-392 (c) Nokia HW version: 2000 UEM version: 4386 UPP version: 12642 RFIC version: 0500 DSP version: ICPR72_08w52_UPP LCD version: SEIKO PPM version: V 06.17 10-03-09 RM-392 (c) Nokia MR BT MCM version: 2222-143C Content Pack version: Content: mr V 06.17 10-03-09 RM-392 (c) Nokia Product Info: Production serial number: IDN421897 Product code: 0564331 Module code: 0203726 Basic production code: 0556744 Long production SN: 0 Serial Numbers: IMEI plain: 356390021934604 IMEI spare to net: 3A 65 93 00 12 39 64 IMEI SV to net: 33 65 93 00 12 39 64 20 F9 Other Info: Model : Nokia 2680s-2 (Connect Contemporary) CS type : GSM/DCS1800 BSI: 4.1 KOhm Imei net: 35639002193460 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN FULL FACTORY... OK USER DATA... OK Reset User Code (to default:12345) ... OK Completed in 6.172 s WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
08-03-2009, 10:41 | #170 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | NOKIA 6300 RM-217 DEAD REPAIRED GOOD BY MX-KEY Code: Processing file: rm217__07.21.mcusw RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 1EE000130E947C567E40358ECF4011594BE3242E ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Programming MCU ... rm217__07.21.mcusw: [BB5,BB5 ALGORITHM] size: 14.50 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.375 s CMT NOR area [000006C0-0001FFFF] erased in 0.750 s CMT NOR area [00020000-0007FFFF] erased in 2.140 s CMT NOR area [00080000-000DFFFF] erased in 1.719 s CMT NOR area [00100000-001FFFFF] erased in 1.672 s CMT NOR area [00200000-0031FFFF] erased in 1.953 s CMT NOR area [00320000-0105FFFF] erased in 4.281 s CMT NOR area [01060000-01067FFF] erased in 1.594 s CMT NOR area [01068000-0107FFFF] erased in 1.578 s Flash programming ... Valid PAPUB key found, CMT PAPUBKEYS, RAP Certificate 52 v1 written. Programming completed in 7 min 32.125 s Processing file: rm217__07.21.ppm_w RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 1EE000130E947C567E40358ECF4011594BE3242E ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Programming PPM ... rm217__07.21.ppm_w: [BB5,BB5 ALGORITHM] size: 4.63 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 5.50 MB CMT NOR area [01080000-015FFFFF] erased in 13.296 s Flash programming ... Programming completed in 2 min 25.891 s Processing file: rm217__07.21_sd_apac_tuw_512.fpsimage file is empty, skipped. Processing file: rm217__07.21.image_w NOR page size in the phone is 128 K. RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 1EE000130E947C567E40358ECF4011594BE3242E ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Programming Content Pack ... rm217__07.21.image_w: [BB5,BB5 ALGORITHM] page size: 64 K size: 6.82 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 9.87 MB CMT NOR area [01600000-01FDFFFF] erased in 12.984 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 3 min 35.329 s Flashing completed in 15 min 0.641 s Phone Type: RM-217 (Nokia 6300) SW Version: V 07.21 05-11-08 RM-217 (c) Nokia. Imei plain: 35683202816632-6 Product Code: 0515596 VariantId: W Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 15 min 21.188 s READED INFO Code: Version Info: MCU SW version: V 07.21 05-11-08 RM-217 (c) Nokia. HW version: 1011 RFIC version: 17211721 DSP version: ICPR61_08w10 PPM version: V 07.21 05-11-08 RM-217 (c) Nokia. W Retu version: 32 Tahvo version: 53 Content Pack version: Content: w V 07.21 05-11-08 RM-217 (c) Nokia. Product Info: Production serial number: DUD564558 Product code: 0515596 Module code: 0203166 Basic production code: 0537040 Serial Numbers: IMEI plain: 356832028166326 IMEI spare to net: 3A 65 38 02 82 61 36 02 IMEI SV to net: 33 65 38 02 82 61 36 22 F5 Other Info: Model : Nokia 6300 (Classic Phone) BSI: 4,9 KOhm Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF WBR sahil2000ind |
08-03-2009, 10:45 | #171 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | E71 unlocked successfully Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 2: 1=LOCKED (MCC+MNC): 23595F, DATA=23595F Backup saved to "BB5_351940033574460_SIMLOCK.back" ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending bootloader, size: 0x3AC0 ... Calculating data ...OK Writing PM buffer ... OK Completed in 16.453 s Restarting phone ... Reading Simlock info ... Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=00101F |
08-04-2009, 13:36 | #172 (permalink) |
No Life Poster Join Date: Mar 2007 Location: SL3;HTC DesireHD DIRECT UNLOCk Age: 44
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | n958gb unlocked successfully Provider: SFR, Country: France Counter: 0/3, 0/10 CONFIG_DATA: 2081000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 20810F, DATA=20810F BLOCK 2: 1=LOCKED (MCC+MNC): 20810F, DATA=20810F BLOCK 3: 1=LOCKED (MCC+MNC): 64710F, DATA=64710F BLOCK 4: 1=LOCKED (MCC+MNC): 64710F, DATA=64710F Backup saved to "BB5_354829029730292_SIMLOCK.back" ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 Sending bootloader, size: 0x3AC0 ... Calculating data ...OK Writing PM buffer ... OK Completed in 18.531 s Restarting phone ... Reading Simlock info ... Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=00101F |
08-04-2009, 15:25 | #173 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Look up in the Sky
Member: 902570 Status: Offline Thanks Meter: 162 | N73 Unlocked Successfuly! Provider: Globe Telecom, Country: Philippines Counter: 0/3, 0/10 CONFIG_DATA: 5150200000000000 PROFILE_BITS: 8000000000000006 BLOCK 1: 1=LOCKED (MCC+MNC): 51502F, DATA=51502F BLOCK 2: 1=LOCKED (MCC+MNC): 51502F, DATA=51502F BLOCK 3: 1=LOCKED (MCC+MNC): 00101F, DATA=00101F Backup already exist. ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending bootloader, size: 0x3D00 ... Calculating data ...OK Receiving PM buffer, please WAIT ... OK Writing PM buffer ... OK Completed in 39.140 s Restarting phone ... Reading Simlock info ... Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000006 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following User Says Thank You to G3N3RAL For This Useful Post: |
08-05-2009, 11:37 | #174 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Nokia 5310b from Rogers Canada unlocked successfully >>>>> Provider: Rogers AT&T Wireless, Country: Canada Counter: 0/3, 0/10 CONFIG_DATA: 3027200000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 302720, DATA=302720 Backup saved to "BB5_359827011xxxxxx_SIMLOCK.back" ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending bootloader, size: 0x3C00 ... Calculating data ...OK Writing PM buffer ... OK Completed in 16.000 s Restarting phone ... Reading Simlock info ... Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=00101F |
08-07-2009, 12:56 | #175 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 946569 Status: Offline Thanks Meter: 326 | 2760 RM-258 6.82 successful unlock 2760 RM-258 6.82 successful unlock Code: Imei net: 35932302987552 Provider: Movistar (DCT4), Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140700000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.LOCKED (MCC+MNC): 21407F BLOCK 2: 1.LOCKED (MCC+MNC): 21402F PhoneType:RM-258 SwVersion: V 06.82 26-09-08 RM-258 (c) Nokia MCU file: rm258__06.82.mcusw Trying to find patch position ...OK, case id: 4 ROM version: 4 Using device: UFS_USB V2.8 (c) SarasSoft 2007. ASIC ID: 0x3162 [UPP_8M ver: 6.11] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008FF91F:3B8ADA60 Area [01000000-0101FFFF] erased in 0.375 s Area [01080000-0109FFFF] erased in 0.359 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3162 [UPP_8M ver: 6.11] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7528 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008FF91F:3B8ADA60 Area [01000000-0101FFFF] erased in 0.375 s Area [01080000-0109FFFF] erased in 0.344 s Programming ... Programming completed. Completed in 56.515 s Reading Simlock info ... Imei net: 35932302987552 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
08-07-2009, 13:53 | #176 (permalink) |
Banned Join Date: Jun 2009 Location: near gsmhosting Age: 35
Member: 1060683 Status: Offline Sonork: 100.1593478 Thanks Meter: 203 | 6120c Unlocked Successfuly Provider: Hutchinson 3G, Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050600042465540 PROFILE_BITS: 8000000000000006 BLOCK 1: 1=LOCKED (MCC+MNC): 50506F, DATA=50506F BLOCK 2: 1=LOCKED (MCC+MNC): 50599F, DATA=50599F BLOCK 3: 1=LOCKED (MCC+MNC): 00101F, DATA=00101F Backup saved to "BB5_xxxxxxxxxxxxx8_SIMLOCK.back" ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending bootloader, size: 0x3AC0 ... Calculating data ...OK Writing PM buffer ... OK Completed in 18.891 s Restarting phone ... Reading Simlock info ... Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=00101F |
08-07-2009, 15:55 | #177 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | <<<<Succsessfully unlock done nokia 2680s with mx-key>>>> Here is log: Imei net: 35319403276087 Provider: Virgin - SPECIAL CODE, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2340000100000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 23430F 2.LOCKED (GID1): 2800 PhoneType:RM-392 SwVersion: V 05.28 05-11-08 RM-392 (c) Nokia MCU file: rm392__05.28.mcusw Trying to find patch position ...OK, case id: 4 ROM version: 3 ASIC ID: 0x3162 [UPP_8M ver: 6.11] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008D4F70:3B8ADA60 Area [01000000-0101FFFF] erased in 1.156 s Area [01080000-0109FFFF] erased in 1.156 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3162 [UPP_8M ver: 6.11] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008D4F70:3B8ADA60 Area [01000000-0101FFFF] erased in 1.172 s Area [01080000-0109FFFF] erased in 1.156 s Programming ... Programming completed. Completed in 44.297 s Reading Simlock info ... Imei net: 35319403276087 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Br: Harkishan |
08-08-2009, 11:00 | #178 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Hungary Age: 48
Member: 141809 Status: Offline Thanks Meter: 30 | 3110c Unlocked Successfuly Imei: xxxxxxxxxxxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Westel 900 GSM Mobile, Country: Hungary Counter: 0/3, 0/10 CONFIG_DATA: 2163000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 21630F, DATA=21630F Backup saved to "BB5_xxxxxxxxxxxxxxx_SIMLOCK.back" ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending bootloader, size: 0x3D00 ... Calculating data ...OK Receiving PM buffer, please WAIT ... OK Writing PM buffer ... OK Completed in 27.172 s Restarting phone ... Reading Simlock info ... Imei: xxxxxxxxxxxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
08-08-2009, 13:25 | #179 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | 6500 slide unlock succesful. Quote:
The Following User Says Thank You to asad_nomy7 For This Useful Post: |
08-08-2009, 13:43 | #180 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks Meter: 290 | 6126 RM126 Successfully Unlocked: Provider: CINGULAR - Pacific Bell Wireless, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3101700000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 310150, DATA=310150 BLOCK 2: 1=LOCKED (MCC+MNC): 310170, DATA=310170 BLOCK 3: 1=LOCKED (MCC+MNC): 311180, DATA=311180 BLOCK 4: 1=LOCKED (MCC+MNC): 310410, DATA=310410 Backup saved to "BB5_359734001215178_SIMLOCK.back" ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending bootloader, size: 0x3D00 ... Calculating data ...OK Receiving PM buffer, please WAIT ... OK Writing PM buffer ... OK Completed in 35.266 s Restarting phone ... Reading Simlock info ... Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF WBR |
The Following User Says Thank You to NawabN Sahoo For This Useful Post: |
