07-01-2009, 15:19 | #46 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Code: ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0059A4BA:DA3BDA66 ASIC type: 11 UEM Imei: 35196803520713 Processing file: rm305_05.710 ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0059A4BA:2984DA60 Programming MCU ... rm305_05.710: [DCT4,DCT4 ALGORITHM] size: 2.34 MB Supported Ids: 2292 Area [01000000-0100FFFF] erased in 0.813 s Area [01010000-0179FFFF] erased in 1 min 36.375 s Area [017A0000-017EFFFF] erased in 3.969 s Area [01F00000-01FDFFFF] erased in 0.078 s Flash programming ... Programming completed in 14.110 s File Processed in 2 min 1.750 s Processing file: rm3050_nai5.71mg ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0059A4BA:2984DA60 Programming Content Pack ... rm3050_nai5.71mg: [DCT4,DCT4 ALGORITHM] size: 180.30 KB Supported Ids: 2292 Area [01760000-0179FFFF] erased in 3.219 s Flash programming ... Programming completed in 1.125 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.062 s File Processed in 16.640 s Processing file: rm305_05.71mg ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0059A4BA:2984DA60 Programming PPM ... rm305_05.71mg: [DCT4,DCT4 ALGORITHM] size: 3.52 MB Supported Ids: 2292 Area [01240000-0125FFFF] erased in 1.594 s Area [01260000-0175FFFF] erased in 1 min 3.734 s Flash programming ... Programming completed in 21.250 s File Processed in 1 min 32.172 s Flashing completed in 4 min 6.219 s Phone Type: RM-305 SW Version: V 5.71 12-09-08 RM-305 (c) NMP Imei plain: 35196803520713-6 Product Code: 0547172 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: MG Language Pack: - not available. Total time to process is 4 min 12.891 s READED INFO Code: Version Info: MCU SW version: V 5.71 12-09-08 RM-305 (c) NMP HW version: 2503 UEM version: 1328 UPP version: 8850 RFIC version: 0700 DSP version: ICPR62_08w31_UPP LCD version: WIN:GUINv93 STE2028 PPM version: V 5.71 12-09-08 RM-305 (c) NMP MG ADSP SW version: p V 5.71\n12-09-08\nRM-305\n(c) NMP\nmg Product Info: Production serial number: IHQ728930 Product code: 0547172 Module code: 0203271 Basic production code: 0573616 Serial Numbers: IMEI plain: 351968035207136 IMEI spare to net: 3A 15 69 08 53 02 17 03 IMEI SV to net: 33 15 69 08 53 02 17 63 F7 Other Info: CS type : GSM/DCS1800 BSI: 1,9 KOhm Imei net: 35196803520713 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN WBR sahil2000ind |
The Following 4 Users Say Thank You to sahil2000ind For This Useful Post: |
07-03-2009, 13:59 | #47 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | NOKIA 2630 RM-298 V6.82 IMEI PATCH AND SPLOCK OK WITH MX-KEY IMEI CHANGE Code: PhoneType:RM-298 SwVersion: V 06.82 26-09-08 RM-298 (c) Nokia MCU file: rm298__06.82.mcusw ChangeImei: YES Trying to find patch position ...OK, case id: 4 New Imei: 358658019542938 ROM version: 4 ASIC ID: 0x3162 [UPP_8M ver: 6.11] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 881C [ST M58LR256JU,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C4A968:3B8ADA60 Area [01000000-0101FFFF] erased in 0.546 s Area [01080000-0109FFFF] erased in 0.547 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3162 [UPP_8M ver: 6.11] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 881C [ST M58LR256JU,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C4A968:3B8ADA60 Area [01000000-0101FFFF] erased in 0.547 s Area [01080000-0109FFFF] erased in 0.531 s Programming ... Programming completed. Completed in 55.016 s READED INFO Code: Version Info: MCU SW version: V 06.82 26-09-08 RM-298 (c) Nokia HW version: 3000 UEM version: 1328 UPP version: 12642 RFIC version: 0500 DSP version: ICPR62_08w27_U LCD version: SUEZ PPM version: V 06.82 26-09-08 RM-298 (c) Nokia MR BT MCM version: 2222-v101 Content Pack version: Content: mr V 06.82 26-09-08 RM-298 (c) Nokia Product Info: Production serial number: IJG065107 Product code: 0549376 Module code: 0203304 Basic production code: 0544206 Long production SN: 0 Serial Numbers: IMEI plain: 358658019542938 IMEI spare to net: 3A 85 56 08 91 45 92 03 IMEI SV to net: 33 85 56 08 91 45 92 43 F5 Other Info: Model : Nokia 2630 (Classic Phone) CS type : GSM/DCS1800 BSI: 0,1 KOhm Imei net: 35865801954293 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN WBR sahil2000ind |
The Following 6 Users Say Thank You to sahil2000ind For This Useful Post: |
07-03-2009, 16:05 | #48 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Nokia N80 unlocked successfully..... Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 3/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 2: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 3: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F BLOCK 4: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F Backup saved to "BB5_35836100xxxxxxx_SIMLOCK.back" ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending bootloader, size: 0x3D00 ... Calculating data ...OK Receiving PM buffer, please WAIT ... OK Writing PM buffer ... OK Completed in 40.141 s Restarting phone ... Reading Simlock info ... Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following 4 Users Say Thank You to zeel_zeel For This Useful Post: |
07-03-2009, 22:01 | #49 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 946569 Status: Offline Thanks Meter: 326 | N95 Downgarde done N95 rm-159 Downgarde done . interface use UFS Code: Rpl backup already exist. Preparing phone for SW downgrade ... Phone is ready for SW downgrade. Processing file: RM-159_21.0.016_PR.C0R APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 69A63E1B07495AE75D34B16B63CCDBBFCEAE118B ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.x] EM1 ID: 00000296 EM2 ID: 00000B22 PUBLIC ID: 1980011439C90158B7E2CD8EC7560202FC3EF9C6 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAPIDOv11_algo.fg: [XSR 1.5] version: 1.35.0 revision: 0.0 size: 0x272B0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS ID: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89 omap2420_m1_2nd.fg: [BB5] version: 1.39.0 revision: 0.0 size: 0x7B00 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 RX2 enabled. FlashID0: 00EC 0040 - 0121 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG teflon_sam_nand_xsr151_m1.fg: [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.52.0 revision: 0.0 size: 0x2DB80 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS ID: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89 Programming MCU ... RM-159_21.0.016_PR.C0R: [BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 70.69 MB Supported RAP Ids: 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 Supported APE Ids: 24200705 Total erase size: 110.87 MB CMT NOR area [00080000-007AD4AD] erased in 34.016 s CMT NOR area [00000000-0005FFFF] erased in 1.485 s CMT NOR area [00880000-00FDFFFF] erased in 7.875 s APE NAND area [00000200-0000AFFF] erased in 0.047 s APE NAND area [0000B800-000AFFFF] erased in 0.047 s APE NAND area [00000000-00001000] erased in 0.047 s APE NAND area [0000D800-0000EA00] erased in 0.047 s APE NAND area [00080000-000BFFFF] erased in 0.047 s APE NAND area [000E0000-0045FFFF] erased in 0.922 s APE NAND area [004C0000-0073FFFF] erased in 1.031 s APE NAND area [00A40000-0633FFFF] erased in 1.125 s Flash programming ... Valid PAPUB key found, CMT PAPUBKEYS, RAP Certificate v1.0 written. Valid PAPUB key found, APE PAPUBKEYS, APE Certificate v1.0 written. Programming completed in 7 min 16.500 s Processing file: RM-159_21.0.016_PR.v08 APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 69A63E1B07495AE75D34B16B63CCDBBFCEAE118B ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.x] EM1 ID: 00000296 EM2 ID: 00000B22 PUBLIC ID: 1980011439C90158B7E2CD8EC7560202FC3EF9C6 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAPIDOv11_algo.fg: [XSR 1.5] version: 1.35.0 revision: 0.0 size: 0x272B0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS ID: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89 omap2420_m1_2nd.fg: [BB5] version: 1.39.0 revision: 0.0 size: 0x7B00 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 RX2 enabled. FlashID0: 00EC 0040 - 0121 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG teflon_sam_nand_xsr151_m1.fg: [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.52.0 revision: 0.0 size: 0x2DB80 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS ID: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89 Programming PPM ... RM-159_21.0.016_PR.v08: [BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 14.08 MB Supported RAP Ids: 4003192101002003, 400C192101002003, 400C192101011103, 400C192101021103, 4003192101021103, 4003192101011103, 4003192101031103, 400C192101031103 Supported APE Ids: 24200705 Total erase size: 23.00 MB APE NAND area [04C40000-0633FFFF] erased in 0.625 s Flash programming ... Programming completed in 1 min 22.328 s Processing file: RM159_21.0.016_032_U03_uda.fpsx APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 69A63E1B07495AE75D34B16B63CCDBBFCEAE118B ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.x] EM1 ID: 00000296 EM2 ID: 00000B22 PUBLIC ID: 1980011439C90158B7E2CD8EC7560202FC3EF9C6 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAPIDOv11_algo.fg: [XSR 1.5] version: 1.35.0 revision: 0.0 size: 0x272B0 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS ID: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89 omap2420_m1_2nd.fg: [BB5] version: 1.39.0 revision: 0.0 size: 0x7B00 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 RX2 enabled. FlashID0: 00EC 0040 - 0121 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG teflon_sam_nand_xsr151_m1.fg: [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.52.0 revision: 0.0 size: 0x2DB80 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS ID: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89 Programming Content Pack ... RM159_21.0.016_032_U03_uda.fpsx: [BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 21.10 MB Supported RAP Ids: 4003192101002003, 400C192101002003, 400C192101011103, 400C192101021103, 4003192101021103, 4003192101011103, 4003192101031103, 400C192101031103, 0003192101001003, 0003192101001103, 400C192101021103, 4003192101021103 Supported APE Ids: 24200705 Total erase size: 151.06 MB APE SOS-USER APE NAND area [06340000-0FA3FFFF] erased in 0.469 s Flash programming ... Programming completed in 2 min 7.829 s Flashing completed in 12 min 17.906 s |
The Following 6 Users Say Thank You to 1NOKIA1 For This Useful Post: |
07-04-2009, 08:39 | #50 (permalink) |
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Nokia 2630 from ZOO Australia unlocked perfectly >>>> Imei net: 3595750xxxxxxx Provider: Singtel Optus-Cable + Wireless Optus, Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050200000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.LOCKED (MCC+MNC): 50502F PhoneType:RM-298 SwVersion: V 05.61 18-04-08 RM-298 (c) Nokia MCU file: rm298__05.61.mcusw Trying to find patch position ...OK, case id: 4 ROM version: 5 ASIC ID: 0x3162 [UPP8M_v6.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 881C [ST M58LR256JU] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0045393C:3B8ADA60 Area [01000000-0101FFFF] erased in 0.578 s Area [01080000-0109FFFF] erased in 0.578 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3162 [UPP8M_v6.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 881C [ST M58LR256JU] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0045393C:3B8ADA60 Area [01000000-0101FFFF] erased in 0.578 s Area [01080000-0109FFFF] erased in 0.578 s Programming ... Programming completed. Completed in 5 min 15.985 s Reading Simlock info ... Imei net: 3595750xxxxxxx Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
07-04-2009, 10:56 | #51 (permalink) |
No Life Poster Join Date: May 2006 Location: Dhaka Age: 46
Member: 271880 Status: Offline Sonork: 100.1578866 Thanks Meter: 1,289 | 3110c unlock successfull Version Info: Code: Version Info: MCU SW version: V 07.21 05-11-08 RM-237 (c) Nokia. HW version: 6002 RFIC version: 17211721 DSP version: ICPR61_08w10 PPM version: V 07.21 05-11-08 RM-237 (c) Nokia. C Retu version: 32 Tahvo version: 53 Content Pack version: Content: voda_ie V 07.21 13-01-09 RM-237 (c) Nokia. Product Info: Production serial number: KKT141060 Product code: 0550269 Module code: 0203291 Basic production code: 0542523 Serial Numbers: IMEI plain: 354206034xxxxx0 IMEI spare to net: 3A 45 02 06 43 68 00 01 IMEI SV to net: 33 45 02 06 43 68 00 21 F5 Other Info: Model : Nokia 3110c (Classic Phone) BSI: 3.4 KOhm Provider: Vodafone - Eircell, Country: Ireland Counter: 0/3, 0/10 CONFIG_DATA: 2720100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 27201F, DATA=27201F Code: Provider: Vodafone - Eircell, Country: Ireland Counter: 0/3, 0/10 CONFIG_DATA: 2720100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 27201F, DATA=27201F Backup saved to "BB5_354206034xxxxx0_SIMLOCK.back" ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending bootloader, size: 0x3D00 ... Calculating data ...OK Receiving PM buffer, please WAIT ... OK Writing PM buffer ... OK Completed in 26.297 s Restarting phone ... Reading Simlock info ... Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF kabir telecom |
The Following 5 Users Say Thank You to kabirhossain For This Useful Post: |
07-04-2009, 14:38 | #52 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | 6120c Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 2: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F Backup saved to "BB5_359850014502988_SIMLOCK.back" ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 Sending bootloader, size: 0x3AC0 ... Calculating data ...OK Writing PM buffer ... OK Restarting phone ... Reading Simlock info ... Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=00101F Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=00101F |
The Following 4 Users Say Thank You to vodafoneserver For This Useful Post: |
07-05-2009, 07:02 | #53 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | N95 8GB unlock successfull Provider: Vodafone, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2341500000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23415F, DATA=23415F BLOCK 2: 1=LOCKED (MCC+MNC): 23415F, DATA=23415F Backup saved to "BB5_356983013538480_SIMLOCK.back" ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 Sending bootloader, size: 0x3AC0 ... Calculating data ...OK Writing PM buffer ... OK Restarting phone ... Reading Simlock info ... Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=00101F br kushol |
The Following 5 Users Say Thank You to vodafoneserver For This Useful Post: |
07-05-2009, 08:52 | #54 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | NOKIA 6300b RM-222 V 04.71 UNLOCK OK WITH MX-KEY READED INFO Code: Version Info: MCU SW version: V 04.71 28-02-07 RM-222 (c) Nokia. HW version: 2007 RFIC version: 17211721 DSP version: pb06w14v33 PPM version: V 04.71 28-02-07 RM-217 (c) Nokia. N Retu version: 32 Tahvo version: 53 Content Pack version: Content: SunCom v1 28-05-07 RM-222 (c) Nokia. Product Info: Production serial number: RIL830720 Product code: 0548622 Module code: 0203165 Basic production code: 0538161 Serial Numbers: IMEI plain: 354827019553286 IMEI spare to net: 3A 45 28 07 91 55 23 08 IMEI SV to net: 33 45 28 07 91 55 23 08 F7 Other Info: Model : Nokia 6300 (Classic Phone) BSI: 3,9 KOhm Counter: 0/3, 0/10 CONFIG_DATA: 3104900000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 310490, DATA=310490 SP UNLOCK Code: Counter: 0/3, 0/10 CONFIG_DATA: 3104900000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 310490, DATA=310490 Backup saved to "BB5_354827019553286_SIMLOCK.back" ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending bootloader, size: 0x3D00 ... Calculating data ...OK Receiving PM buffer, please WAIT ... OK Writing PM buffer ... OK Completed in 33.157 s Restarting phone ... Reading Simlock info ... Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF WBR sahil2000ind |
The Following 5 Users Say Thank You to sahil2000ind For This Useful Post: |
07-05-2009, 09:51 | #55 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | NOKIA 5200 RM-174 REPAIRED OK Code: Processing file: rm174__05.53.mcusw RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 1820001255C9605618D61E81DDA2ACCC8D5B80DE ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Programming MCU ... rm174__05.53.mcusw: [BB5,BB5 ALGORITHM] size: 14.52 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 16.37 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00020000-0007FFFF] CMT NOR area [00080000-000DFFFF] CMT NOR area [00100000-001FFFFF] CMT NOR area [00200000-0031FFFF] CMT NOR area [00320000-0105FFFF] CMT NOR area [01060000-01067FFF] CMT NOR area [01068000-0107FFFF] erased in 4.781 s Flash programming ... Selecting first PAPUB block with matching CMT RootKey, CMT PAPUBKEYS, Rap Certificate 31 v1 written. Programming completed in 5 min 46.765 s Processing file: rm174__05.53.ppm_w RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 1820001255C9605618D61E81DDA2ACCC8D5B80DE ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: D6D07E588DC4E06DEE7012A3C0ECC4E35D3CE263 Programming PPM ... rm174__05.53.ppm_w: [BB5,BB5 ALGORITHM] size: 3.99 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 4.50 MB CMT NOR area [01080000-014FFFFF] erased in 11.406 s Flash programming ... Programming completed in 1 min 35.484 s Processing file: rm174__05.53.image_w NOR page size in the phone is 128 K. RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 1820001255C9605618D61E81DDA2ACCC8D5B80DE ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: D6D07E588DC4E06DEE7012A3C0ECC4E35D3CE263 Programming Content Pack ... rm174__05.53.image_w: [BB5,BB5 ALGORITHM] page size: 64 K size: 3.69 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 10.87 MB CMT NOR area [01500000-01FDFFFF] erased in 29.516 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 1 min 35.078 s Flashing completed in 10 min 22.907 s Phone Type: RM-174 (Nokia 5200) SW Version: V 05.53 03-03-08 RM-174 (c) Nokia. Imei plain: 35484801830184-0 Product Code: 0535401 VariantId: W Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 10 min 36.266 s READED INFO Code: Version Info: MCU SW version: V 05.53 03-03-08 RM-174 (c) Nokia. HW version: 2002 RFIC version: 17211721 DSP version: 06w14pb_07w32 PPM version: V 05.53 03-03-08 RM-174 (c) Nokia. W Retu version: 32 Tahvo version: 53 Content Pack version: Content: w V 05.53 03-03-08 RM-174 (c) Nokia. Product Info: Production serial number: DAH528280 Product code: 0535401 Module code: 0203053 Basic production code: 0530542 Serial Numbers: IMEI plain: 354848018301840 IMEI spare to net: 3A 45 48 08 81 03 81 04 IMEI SV to net: 33 45 48 08 81 03 81 14 F7 Other Info: Model : Nokia 5200 (Classic Phone) BSI: 4,1 KOhm Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF WBR sahil2000ind |
07-05-2009, 11:00 | #56 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | N95 8GB unlock successfull Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 2: 1=LOCKED (MCC+MNC): 23420F, DATA=23420F BLOCK 3: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F BLOCK 4: 1=LOCKED (MCC+MNC): 23594F, DATA=23594F Backup saved to "BB5_356842025885646_SIMLOCK.back" ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending bootloader, size: 0x3AC0 ... Calculating data ...OK Writing PM buffer ... OK Restarting phone ... Reading Simlock info ... Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=00101F |
07-06-2009, 07:14 | #58 (permalink) |
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | 5610 unlock successfull Provider: T-Mobile, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 310160, DATA=310160 BLOCK 2: 1=LOCKED (MCC+MNC): 310200, DATA=310200 BLOCK 3: 1=LOCKED (MCC+MNC): 310210, DATA=310210 BLOCK 4: 1=LOCKED (MCC+MNC): 310220, DATA=310220 BLOCK 5: 1=LOCKED (MCC+MNC): 310230, DATA=310230 BLOCK 6: 1=LOCKED (MCC+MNC): 310240, DATA=310240 BLOCK 7: 1=LOCKED (MCC+MNC): 310250, DATA=310250 BLOCK 8: 1=LOCKED (MCC+MNC): 310260, DATA=310260 BLOCK 9: 1=LOCKED (MCC+MNC): 310270, DATA=310270 BLOCK 10: 1=LOCKED (MCC+MNC): 310310, DATA=310310 BLOCK 11: 1=LOCKED (MCC+MNC): 310580, DATA=310580 BLOCK 12: 1=LOCKED (MCC+MNC): 310660, DATA=310660 BLOCK 13: 1=LOCKED (MCC+MNC): 310800, DATA=310800 BLOCK 14: 1=LOCKED (MCC+MNC): 310490, DATA=310490 Backup saved to "BB5_352941020524665_SIMLOCK.back" ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending bootloader, size: 0x3C00 ... Calculating data ...OK Writing PM buffer ... OK Restarting phone ... Reading Simlock info ... Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=00101F |
07-06-2009, 07:37 | #59 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | NOKIA 5200 RM-174 REPAIRED SUCESSFULLY FLASHING LOGS Code: RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 0F90021907AA6C563B73740BDADCC23CEA683475 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: D6D07E588DC4E06DEE7012A3C0ECC4E35D3CE263 Reading RAP NPC (0x168 bytes). Reading RAP VARIANT (0x0 bytes). Reading RAP CCC (0x160 bytes). Reading RAP HWC (0xD4 bytes). Flash Imei: 35768901070116 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.2\data\backup\RPL\BB5_35768901070116_back.rpl" Processing file: rm174__07.20.mcusw RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 0F90021907AA6C563B73740BDADCC23CEA683475 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: D6D07E588DC4E06DEE7012A3C0ECC4E35D3CE263 Programming MCU ... rm174__07.20.mcusw: [BB5,BB5 ALGORITHM] size: 14.55 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 16.37 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00020000-0007FFFF] CMT NOR area [00080000-000DFFFF] CMT NOR area [00100000-001FFFFF] CMT NOR area [00200000-0031FFFF] CMT NOR area [00320000-0105FFFF] CMT NOR area [01060000-01067FFF] CMT NOR area [01068000-0107FFFF] erased in 41.468 s Flash programming ... Valid PAPUB key found, CMT PAPUBKEYS, Rap Certificate 31 v1 written. Programming completed in 6 min 56.594 s Processing file: rm174__07.20.ppm_w RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 0F90021907AA6C563B73740BDADCC23CEA683475 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: D6D07E588DC4E06DEE7012A3C0ECC4E35D3CE263 Programming PPM ... rm174__07.20.ppm_w: [BB5,BB5 ALGORITHM] size: 4.00 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 4.50 MB CMT NOR area [01080000-014FFFFF] erased in 11.265 s Flash programming ... Programming completed in 1 min 51.781 s Processing file: rm174__07.20.image_w NOR page size in the phone is 128 K. RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 0F90021907AA6C563B73740BDADCC23CEA683475 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: D6D07E588DC4E06DEE7012A3C0ECC4E35D3CE263 Programming Content Pack ... rm174__07.20.image_w: [BB5,BB5 ALGORITHM] page size: 64 K size: 4.94 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 10.87 MB CMT NOR area [01500000-01FDFFFF] erased in 29.218 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 2 min 13.610 s Flashing completed in 13 min 19.281 s Phone Type: RM-174 (Nokia 5200) SW Version: V 07.20 23-10-08 RM-174 (c) Nokia. Imei plain: 35768901070116-6 Product Code: 0535510 VariantId: W Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 13 min 38.296 s READED INFO Code: Version Info: MCU SW version: V 07.20 23-10-08 RM-174 (c) Nokia. HW version: 2003 RFIC version: 17211721 DSP version: ICPR61_08w10 PPM version: V 07.20 23-10-08 RM-174 (c) Nokia. W Retu version: 32 Tahvo version: 53 Content Pack version: Content: w V 07.20 13-01-09 RM-174 (c) Nokia. Product Info: Production serial number: DTA142347 Product code: 0535510 Module code: 0203053 Basic production code: 0530542 Serial Numbers: IMEI plain: 357689010701166 IMEI spare to net: 3A 75 86 09 01 07 11 06 IMEI SV to net: 33 75 86 09 01 07 11 26 F3 Other Info: Model : Nokia 5200 (Classic Phone) BSI: 4,0 KOhm Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF FULL FACTORY... OK USER DATA... OK Reset User Code (to default:12345) ... OK Completed in 5.046 s WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
07-06-2009, 10:25 | #60 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | NOKIA3110c RM-237 REPAIRED SUCESSFULLY FLASHING LOG Code: RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 22E0001538C17B5634D2B29215E818AAE15ECD17 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel ] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: C0E691EA16A7593A9BB28832D7312A39F7ED668D Reading RAP NPC (0x168 bytes). Reading RAP VARIANT (0x0 bytes). Reading RAP CCC (0x160 bytes). Reading RAP HWC (0xD4 bytes). Flash Imei: 35641802370344 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.2\data\backup\RPL\BB5_35641802370344_back.rpl" Processing file: rm237__07.21.mcusw RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 22E0001538C17B5634D2B29215E818AAE15ECD17 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel ] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: C0E691EA16A7593A9BB28832D7312A39F7ED668D Programming MCU ... rm237__07.21.mcusw: [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 16.37 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00020000-0007FFFF] CMT NOR area [00080000-000DFFFF] CMT NOR area [00100000-001FFFFF] CMT NOR area [00200000-0031FFFF] CMT NOR area [00320000-0105FFFF] CMT NOR area [01060000-01067FFF] CMT NOR area [01068000-0107FFFF] erased in 1 min 23.953 s Flash programming ... Valid PAPUB key found, CMT PAPUBKEYS, RAP Certificate 66 v2 written. Programming completed in 1 min 37.187 s Processing file: rm237__07.21.ppm_mr RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 22E0001538C17B5634D2B29215E818AAE15ECD17 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel ] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: C0E691EA16A7593A9BB28832D7312A39F7ED668D Programming PPM ... rm237__07.21.ppm_mr: [BB5,BB5 ALGORITHM] size: 3.55 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 4.62 MB CMT NOR area [01080000-0151FFFF] erased in 20.843 s Flash programming ... Programming completed in 22.297 s Processing file: rm237__07.21_sd_ctv_India_512MB_V01.fpsimage file is empty, skipped. Processing file: rm237__07.21.image_ctv_india_mr NOR page size in the phone is 128 K. RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 22E0001538C17B5634D2B29215E818AAE15ECD17 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel ] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: C0E691EA16A7593A9BB28832D7312A39F7ED668D Programming Content Pack ... rm237__07.21.image_ctv_india_mr: [BB5,BB5 ALGORITHM] page size: 64 K size: 4.00 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Total erase size: 10.75 MB CMT NOR area [01520000-01FDFFFF] erased in 1 min 14.906 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 25.266 s Flashing completed in 6 min 28.156 s Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35641802370344-4 Product Code: 0550573 VariantId: M Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 6 min 41.500 s INFO LOGS Code: Version Info: MCU SW version: V 07.21 05-11-08 RM-237 (c) Nokia. HW version: 5005 RFIC version: 17211721 DSP version: ICPR61_08w10 PPM version: V 07.21 05-11-08 RM-237 (c) Nokia. MR Retu version: 32 Tahvo version: 53 Content Pack version: Content: ctv_india_mr V 07.21 13-01-09 RM-237 (c) Nokia. Product Info: Production serial number: MPF373249 Product code: 0550573 Module code: 0203291 Basic production code: 0542523 Serial Numbers: IMEI plain: 356418023703444 IMEI spare to net: 3A 65 14 08 32 07 43 04 IMEI SV to net: 33 65 14 08 32 07 43 24 F5 Other Info: Model : Nokia 3110c (Classic Phone) BSI: 4,6 KOhm Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF FULL FACTORY... OK USER DATA... OK Reset User Code (to default:12345) ... OK Completed in 5.187 s WBR sahil2000ind |
