Old 10-05-2012, 10:41   #1 (permalink)
Member: 497274
Thanks Meter: 15
mxbox sx4 not ok
please questions sever mxbox of off??
Old 10-05-2012, 10:56   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Why you need SX4 Server, when HTI Box is Standalone.
Post Full Logs of Error or mention your problem in details.
BR,
ZUBER
Old 10-05-2012, 11:27   #3 (permalink)
Member: 497274
Thanks Meter: 15
log phone error
Phone type: RM-237 (Nokia 3110c)
SW version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35196303837292-0
Product code: 0514950
Battery voltage: 4778 mV, current: 64 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
WMDRM_PD seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST passed
Imei net: 351963038372920
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
log repair SD
Using cached productData.
PUBLIC ID: 1DD00108804B7E566A9CFFA89BFD878B4C053DF5
PRIVATE ID: A3B078B4BF8D8DB31D9D20D397AEEEC7ACA0031E
Updating SUPERDONGLE_KEY ...error 0x3
Authenticating to SUPERDONGLE ...
Wrong response to SD verify request
log error Super SD Auth
ERROR: Missing SD BLOCK or PM corrupted !
To Repair SUPERDONGLE please use "Repair SD" !
log error repair splock
Updating SIMLOCK ...error 0x1
Reading Simlock info ...
SIMLOCK_DATA corrupted!
Old 10-05-2012, 18:56   #4 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,136
All is well dear working fine check network connection and try again and again.
BR.
Arsalan gsm2000.
Old 10-05-2012, 19:02   #5 (permalink)
israrbjr's Avatar
Member: 748544
Sonork: 100.1601881
Thanks Meter: 173
no sir sx4 server is offline..........
Old 10-06-2012, 04:05   #6 (permalink)
Member: 497274
Thanks Meter: 15
to day not ok ,sever offf
Old 10-06-2012, 07:06   #7 (permalink)
unuunu's Avatar
Member: 1623262
Sonork: 100.1621312
Thanks Meter: 96
sx4 is standalone ........ no need internet brother......
Old 10-06-2012, 19:13   #8 (permalink)
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,136
what's you are face problem screen shot post here give better idea and help you.
BR.
Arsalan gsm2000.
Old 10-08-2012, 10:37   #9 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 497
no need sx4 server anymore if you had hti (green\orange\...nxt version)
1.just select pm(must with 1&309).
2. just click on pmm auth.
after phone superdongle auth simple click on write pm...
Page generated in 0.26904 seconds with 7 queries
