11-18-2012, 14:38 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Bangladesh Age: 43
Member: 1430165 Status: Offline Sonork: 100.1594449 Thanks Meter: 480 | mxbox sx4 server is now offline Last edited by ..::SADHAN::..; 11-18-2012 at 14:39. Reason: text missing |
The Following User Says Thank You to ..::SADHAN::.. For This Useful Post: |
11-19-2012, 09:52 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi Bro. Can you tell me why you need SX4 Server ? HTI Box Standalone, So post Buscheck Logs & will provide Solution. BR, ZUBER |
11-19-2012, 16:46 | #5 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C0XXXX78 Using device: HTI, FW ver: 00.50, SN: 01XXXX5A Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Phone type: RM-634 (Nokia E5-00.2) SW version: V ICPR82_11w16.3 19-05-11 RM-634 (c) Nokia ApeCoreSw: 071.003 Using cached productData. PUBLIC ID: 12200206B1D60344C33647B6CB568B36BA60C386 PRIVATE ID: C4557A4D7B93DB6EDC9CE9BC1EA0EAF9F2F7AC51 Updating SUPERDONGLE_KEY ...OK Authenticating to SUPERDONGLE ... SUPERDONGLE authorized ! Now you can write RFBB/PM data to the phone. Done. Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (10 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (10 bytes) Warning: failed to write 1 - 7 (214 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (10 bytes) Warning: failed to write 1 - 16 (208 bytes) Warning: failed to write 1 - 18 (208 bytes) Warning: failed to write 1 - 20 (208 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 28 (10 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (208 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (376 bytes) Warning: failed to write 1 - 35 (16 bytes) Warning: failed to write 1 - 37 (4 bytes) Warning: failed to write 1 - 39 (36 bytes) Warning: failed to write 1 - 40 (16 bytes) Warning: failed to write 1 - 41 (182 bytes) Warning: failed to write 1 - 42 (4 bytes) Warning: failed to write 1 - 43 (36 bytes) Warning: failed to write 1 - 44 (182 bytes) Warning: failed to write 1 - 45 (182 bytes) - 239 skipped - 308 skipped Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 3 (36 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Completed in 10.250 s |
11-19-2012, 17:45 | #6 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2012 Location: COOCHBEHAR,WB
Member: 1714311 Status: Offline Sonork: 100.1604096 Thanks Meter: 271 | do backup npc,reset npc only...........in this condition write pm section 1 and 309 and restore npc........... |
