07-29-2009, 08:15 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Location: MUMBAI Age: 53
Member: 41672 Status: Offline Thanks Meter: 195 | @ MXkey 1208 after write rpl restart SIMLOCK_DATA corrupted! 2} Area [013B0000-013EFFFF] erased in 1.141 s Area [017C0000-017EFFFF] erased in 1.250 s Area [01FC0000-01FEFFFF] erased in 1.000 s Flash programming ... Programming completed in 41.906 s File Processed in 1 min 23.594 s Processing file: rh1050_nai5.80mg ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_amd.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0048929E:2984DA60 Programming Content Pack ... rh1050_nai5.23mg: [DCT4,DCT4 ALGORITHM] size: 163.78 KB Supported Ids: 2292 Area [01380000-013AFFFF] erased in 1.188 s Flash programming ... Programming completed in 2.641 s Content extract fail, continue anyway ... File Processed in 57.687 s Processing file: rh105_05.80mg ASIC ID: 0x2292 [UPPCosto ver: 1.3] u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 327E [AMD S29NS128P,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_amd.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0048929E:2984DA60 Programming PPM ... rh105_05.80mg: [DCT4,DCT4 ALGORITHM] size: 1.06 MB Supported Ids: 2292 Area [01240000-0124FFFF] erased in 0.578 s Area [01250000-0137FFFF] erased in 5.469 s Flash programming ... Programming completed in 17.359 s File Processed in 38.062 s Flashing completed in 3 min 32.469 s why not mxkey auto convert 64 to 128k CNT file after flash why SIMLOCK_DATA corrupted! 3) Version Info: MCU SW version: V 5.80 14-11-08 RH-105 (c) NMP UEM version: 1328 UPP version: 8850 RFIC version: 0700 DSP version: ICPR62_08w31_UPP LCD version: SDI:NAXv89 S6B33BD PPM version: V 5.80 14-11-08 RH-105 (c) NMP MG ADSP SW version: p V 5.80\n14-11-08\nRH-105\n(c) NMP\nmg Product Info: Serial Numbers: IMEI plain: 354195035138346 IMEI spare to net: 3A 45 91 05 53 31 38 04 IMEI SV to net: 33 45 91 05 53 31 38 64 F8 Other Info: CS type : GSM/DCS1800 BSI: 1.4 KOhm Imei net: 35419503513834 Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! |
07-29-2009, 12:44 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | JUST MAKE INIT SIMLOCK AND URE SET WILL BE OK WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
07-30-2009, 04:44 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Full erase, full flash with latest version (see all three parts mcu.ppm & cnt successfully gets flashed), complete ui settings, write good pm, unlock, write rpl. If needed write pm and again unlock after writing rpl. Port result! |
07-30-2009, 06:54 | #5 (permalink) |
Freak Poster Join Date: May 2009 Location: West Java Flasher
Member: 1035137 Status: Offline Thanks Meter: 72 | flashing content file is not finish yet. try flash it againt. try this method: 1. flash only MCU+PPM, do full factory default 2. flash with MCU+PPM+Content, do full fact default & init simlock this failed in flashing extracting content most recently in upgrading and downgrading Firmware SW. Flashing process is flashing MCU first >>>> Content. while extrackting CNT phone should have Local Mode but the PPM is different from new MCU file, so local mode is imposible. you will get fail in extracting CNT. so safty choice is flashing is only MCU+PPM first and flash againt MCU+PPM+Cnt. BR |
The Following User Says Thank You to mr. uem For This Useful Post: |
