09-29-2012, 18:53 | #1 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1725935 Status: Offline Thanks Meter: 21 | mxkey buscheck scan problem mxkey djt4 bb5 bus chech scan flash problem MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0854????Using device: HTI, FW ver: 00.50, SN: 00000??? Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 changed chip bcp 69. but the same bus check scan error |
09-29-2012, 19:30 | #3 (permalink) |
Member: 1725935 Status: Offline Thanks Meter: 21 | 6300 bus check MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085???? Using device: HTI, FW ver: 00.50, SN: 00000??? Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1D80020D4DB46F56DA337A574B2023B88312AA5A ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD 1600 bus check MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0854??? Using device: HTI, FW ver: 00.50, SN: 00000??? Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Error flash config request! |
09-29-2012, 19:32 | #4 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
BR. Arsalan gsm2000 | |
09-29-2012, 19:51 | #6 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: Kathmandu,Nepal Age: 46
Member: 983663 Status: Offline Sonork: 100.1623270 Thanks Meter: 551 | Quote:
09-29-2012, 19:54 | #7 (permalink) |
Member: 1725935 Status: Offline Thanks Meter: 21 | nokia 1208,1600,6300 phone has been tested many have the same error 6300 bus check MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085???? Using device: HTI, FW ver: 00.50, SN: 00000??? Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1D80020D4DB46F56DA337A574B2023B88312AA5A ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD 1600 bus check MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0854??? Using device: HTI, FW ver: 00.50, SN: 00000??? Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Error flash config request! |
09-29-2012, 19:56 | #8 (permalink) | |||
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Must be having NXP Chip Hardware Malfunctioning in HTI Box. (Possibility) So please check for the same confirm with Latest HTI Firmware Updater. BR, ZUBER | |||
09-29-2012, 20:26 | #9 (permalink) | |
Member: 1725935 Status: Offline Thanks Meter: 21 | Quote:
hti box updater log........ | |
09-29-2012, 20:50 | #12 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Iz it problem will all Phones or some Particular Models? If some, then please report here, Will Check it out. BR, ZUBER |
09-30-2012, 06:48 | #14 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Tanzania
Member: 161280 Status: Offline Sonork: 100.1616990 Thanks Meter: 82 | Quote:
my dear friend can you give us the history of your box it was work fine early after buy all this problem occur all the life of your box you have not use you box in fbus? IF YES Check NXP Bug BUT I SEE THE SEVER PROBLEM SORRY FOR THAT BUT WE NEED TO KNOW NXP BUG RESULT | |
09-30-2012, 11:54 | #15 (permalink) | |
Using device: HTI Flasher Interface (WinUSB) Connection status: EHCI:HUB:HUB:USB 2.00 Full-speed Interface: MXBOX/HTI (Powered by MXKEY) OTP ID: 42170707A00C4E5371C2624B040000F5 Boot ver: 00.07, Box SN: 00000A77 FW version: 00.50 HTI Flasher Interface (WinUSB) ready. | |
