03-30-2012, 11:42 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: POLAND
Member: 27761 Status: Offline Thanks Meter: 55 | mxkey can't flash nokia 6230i rm-72 (ppm and ucp version M), no problem via JAF lower flash log from mxkey - bad flash, not finished = phone dead next flash via JAF no problem phone is working fine. i repeat this is 6230i version M not E and flash files set correctly for both boxes. flashed/tested with fbus cable 3.3K and ufcv2 cable nr6 3.3k to 7.5K (for mxkey becasue jaf went on fbus 3.3K) mxkey log: Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: CXXXX Using device: HTI, FW ver: 00.50, SN: 000XXXXX Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Processing MCU file: rm72_73_11003.890 [TIKU BT2,TIKU ALGORITHM] size: 10.14 MB Supported Ids: 1052, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 007995E1:977ADA60 Area [00000000-0000FFFF] erased in 0.454 s Area [00010000-009FFFFF] erased in 1 min 14.580 s Area [00A00000-00B3FFFF] erased in 9.393 s Area [00B60000-00FAFFFF] erased in 31.744 s Flash programming ... Programming completed in 1 min 18.472 s File Processed in 3 min 24.509 s Processing CNT file: rm72_73_110M_03.89.ucp_b [TIKU BT2,TIKU EIJA SSR] size: 3.94 MB Supported Ids: 1052, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660 Supported Ids: 1051, 1052, 2051 Mass Memory Storage Device detected. Configuring MM bus ... Formating partition ...OK Opening MM device ... Erasing disks ...OK Flash programming ... Przekroczono limit czasu semafora Error while programming [2E] at 0x01000020, Result: 0000 flashing terminated ! this is flash via JAF - OK: Code: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.890 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110M_03.89B CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110M_03.89.ucp_b ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,French,Polish,Romanian,Hungarian MCU: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.890 Booting phone... MCU ID: 0x2051 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.4C.00 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22E800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia Loader version: 04.4C.00 -> Revision: 0007 Loader size is 0x84D8; Loader chk: 28 Loader is ready... P-key nokia module version 01.02 MSID: 846E7E8D4604D7FD79FF9353B7 MSID decoded: 80B0BAE9007995E1A8000000 FAID: 758EF5A7B042690939E89A35 Operation took 0 minutes 11 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 009FFFFF... Erasing area: 00A00000 - 00B3FFFF... Erasing area: 00B60000 - 00FAFFFF... Operation took 1 minutes 55 seconds... Writing... Perm. Data Restore OK Operation took 1 minutes 0 seconds... Restarting MCU... NAND Format OK! CNT: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110M_03.89.ucp_b Booting phone... MCU ID: 0x2051 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.4C.00 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22E800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_oncsm.fia Loader version: 04.4C.00 -> Revision: 0007 Loader size is 0x5660; Loader chk: a9 Loader is ready... Operation took 0 minutes 7 seconds... Erasing Content Pack... Mass Memory Device Detected... MM Bus Configured... Formating MM...Format OK Mass Memory Opened... Mass Memory Erased... Operation took 0 minutes 2 seconds... Writing... Operation took 0 minutes 34 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Extracting Content Pack... Running: (c) Nokia File Server CNT Extract OK. Operation took 0 minutes 16 seconds... PPM: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110M_03.89B Booting phone... MCU ID: 0x2051 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.4C.00 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22E800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_oncsm.fia Loader version: 04.4C.00 -> Revision: 0007 Loader size is 0x5660; Loader chk: a9 Loader is ready... Operation took 0 minutes 7 seconds... Erasing PPM... Mass Memory Device Detected... MM Bus Configured... Mass Memory Opened... Mass Memory Erased... Operation took 0 minutes 1 seconds... Writing... Operation took 0 minutes 38 seconds... Restarting MCU... Flashing Done! Operation took 5 minutes 8 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RM-72, Software version: 03.89 IMEI: 35761600XXXXXXXXX Product Code: 0527657 Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 4 seconds... Done! Done! Product profile uploaded OK... WAP Bookmarks uploaded OK! Done! |
03-30-2012, 12:01 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. you are using very old version with updated HTI will not work, so download latest ver3.5 rev1.9 will solve all problem. |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
