01-29-2010, 17:52 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Nepal(Mobilezone)
Member: 1016132 Status: Offline Sonork: 100.1592677 Thanks Meter: 188 | mxkey can't solve security-test failed. Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35420603425xxxx Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 354206034255583 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF br roshan |
01-29-2010, 18:48 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | can u post with details info, what your step done ? do RPL backup, post log and rpl here please. do SX-4 by server, and post log info here. and maybe other details info,wo can help us easy analisys br, |
01-29-2010, 20:35 | #4 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: esmeraldas-ecuador
Member: 392589 Status: Offline Sonork: 1597152 Thanks Meter: 50 | Quote:
here Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 12345610654321-? Product Code: 0581651 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! SIMLOCK_DATA corrupted! an them bus check Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11893, Date: 26-01-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 25100213E24F7F5648515A3923BC0A9605D77401 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: Empty Original Product code: Empty Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 12345610654321-? Product Code: 0581651 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! Imei plain is invalid !!! SIMLOCK_DATA corrupted! need from your help i send you the rpl tanks | |
01-29-2010, 20:44 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | @mobilezone1997 : Service > Phone Tests > Various > BB5 Certificate Validation. Lets see if any error there. paste here the log. @wilmer: [Imei plain: 12345610654321-?] > if you dont have this unit ORIGINAL NPC that still contain imei, NO TOOL can fix. only rpl by nk can help you. |
The Following User Says Thank You to gbluez For This Useful Post: |
nokia n76 sucussfully phonestartup failure solved .security test fail solved | manish_jain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 02-14-2011 06:55 |
How can i solve Security Test Fail, after unlock by Mx-key | powerplay83 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 03-25-2010 14:39 |
7210c Security Test failed yet now pls help me MXkey Team | asmanju08 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 30 | 02-11-2010 12:16 |
I can't repair Security Test Failed on N96 | gsmlife | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 19 | 02-08-2010 06:44 |
security test Fail nokia 5800 [SOLVED] | langin | Cyclonebox | 10 | 01-10-2010 22:34 |
