Old 07-07-2012, 20:06   #1 (permalink)
Member: 1725935
Thanks Meter: 21
mxkey djt4 bus check error
mxkey box 35.16 exe 0.50 box firmware after the ubdate 1200 1202 1661 1680 2680 models such as error gave the. This problem happened xp.
This problem is known by everyone,I've tried a lot mxkey box and pc.
I have the same problem with the new exe 35.22.
A study for this problem I wonder Mr Manole what when?
Old 07-07-2012, 20:37   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro. Once again Update HTI Box will solve it, if not then post Buscheck Logs for Assistance.
BR,
Zuber
Old 07-07-2012, 22:13   #3 (permalink)
Member: 1725935
Thanks Meter: 21
BR,
Zuber
dear sir
did not understand what you mean?
what ubdate
Old 07-07-2012, 22:28   #4 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Originally Posted by gokhaniletisim View Post
dear sir
what ubdate
..Yes my friend ZUBER,s idea is very hopefull. Just update your HTI BOX FIRMWARE. It will fix ur problem.
Old 07-07-2012, 22:32   #5 (permalink)
Member: 1725935
Thanks Meter: 21
dear sir
updated 0:50 HTI box at least 10 times. but the result is the same
Old 07-08-2012, 12:40   #6 (permalink)
Member: 1725935
Thanks Meter: 21
BR,
Zuber
Receive firmware from server ...
SERVER->MXKEY - BLADE Z at upd, agent version 1.2 revision 0.3
Firmware version on server: 00.50
changes:
added: boot mode switch function
improved: serial and flash bus communication routine
added: dct4 product data calc algorithm
added: broadcom sec.repair algorithm
minor bug fixed.
Received buff checksum verified OK.
Updating HTI firmware, please WAIT ...
HTI firmware update OK.
» End transaction (status: 0, Successfull)
Waiting HTI in application mode ...Done.
scan
[SIZE=1]Phone type: RH-112
SW version: V 03.10 21-01-09 RH-112 (c) NMP
Imei plain: 354***********-9
Product code: 0562273
Cellular system: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: AD
Language Pack:
English,French,German,Turkish
Master code: 6625342420
Imei net: 354**********4
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
bus check
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C******8
Using device: HTI, FW ver: 00.50, SN: 0******8
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
Error sending bootloader !
Old 07-09-2012, 12:56   #7 (permalink)
Member: 1725935
Thanks Meter: 21
0.3
00.50
changes:
minor bug fixed.
Successfull)
scan
Ppm Id: AD
Language Pack:
Counter: 0/3, 0/10
bus check
Old 07-09-2012, 13:05   #8 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
0.3
00.50
changes:
minor bug fixed.
Successfull)
scan
Ppm Id: AD
Language Pack:
Counter: 0/3, 0/10
bus check
Bro. I think so, you should change BCP69 Power Transistor, may be slightly leaked thats why getting problem only in DCT4 as BB5 Power section supports better than DCT4.
BR,
Zuber
Old 07-09-2012, 13:45   #9 (permalink)
Member: 1725935
Thanks Meter: 21
BR,
Zuber
and 10 pc box of 10 new mxkey I tried it but got the same error had changed bcp 69. HTI had this problem after 00:50 this is my problem, not everyone. I looked at a friend's box, I have the same problem. nokia 1110 69 have been corrupted bcp causing the bus error does not check
The Following User Says Thank You to gokhaniletisim For This Useful Post:
My 5110 v5.11 have a strange error.., it resets it self every 60second luuk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 08-11-2006 15:29
Avoid 3 times error code in Nokia 6185 X-plot Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-08-2000 20:24
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-20-1999 19:12
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Page generated in 0.23020 seconds with 9 queries
