02-21-2010, 11:05 | #1 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 43
Member: 39948 Status: Offline Thanks Meter: 68 | MXkey flash X3-00 with dead usb Code: Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Processing file: rm540__03.60.mcusw as MCU [BB5,XSR 1.6] size: 25.93 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2B19FE29 RAP SYSTEM ASIC ID: 000000010000022600000001020C192102034100 [RAPS2 ver: PA 4.x] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 0EA0000ED0340E4961122779C924DDB3566D2594 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D RAP ROM ID: 67E82268F29CEA60 [ADL] Loading CMT secondary boot code SecondaryBoot: rap3gv40_2nd.fg [BB5] version: 9.38.1 revision: 2.1 size: 0x3BC0 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: ONENAND,RAP [ADL] Loading CMT Update Server Data Algorithm: rap3gv40_xsr17_alg.fg [XSR 1.6] version: 9.38.1 revision: 2.1 size: 0x7DE72 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Update Server code loaded. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2B19FE29 [ADL] Verifying communication to device OK. RAP PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E Storing certificate OK. Partitioning.... Partitioning complete Total erase size: 64.00 KB Flash programming ... CMT PAPUBKEYS: CEFA9C4100686F9FC9B1B3778774A19500303230 (RAP Certificate 193 v.1) written. Programming completed in 38.562 s Processing file: rm540__03.60.ppm_x as PPM [BB5,XSR 1.6] size: 7.62 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Total erase size: 8.87 MB Flash programming ... Programming completed in 11.234 s Processing file: rm540__03.60.image_x_0581264_001 as CNT [BB5,XSR 1.6] size: 12.98 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Total erase size: 64.00 KB Flash programming ... Programming completed in 19.312 s [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia USB Generic, ID: 595FDD3 [ADL] Verifying communication to device OK. Flashing completed in 2 min 18.047 s Phone Type: RM-540 (Nokia X3-00) SW Version: V 03.60 21-10-09 RM-540 (c) Nokia Imei plain: 35797703756919-9 Product Code: 0581263 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357977037569199 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 2 min 20.907 s Good work and keep up MX team. |
The Following 3 Users Say Thank You to mentari For This Useful Post: |
Succes Flash nokia N97 With Dead USB | ServiceTEL | Cyclonebox | 7 | 09-13-2009 23:44 |
