Old 06-30-2010, 14:35   #1 (permalink)
SONU898's Avatar
Member: 617865
Thanks Meter: 111
Angry mxkey how to solw this
i got nokia 3110from customer with problem of contect service.i scan the mobile with mxkey and result is as below:
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35683302746676-6
Product Code: 0550573
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 356833027466766
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
then i try to make pmm auth,but this error is appear:
Scanning local SX4 Card ...
No SX4 Card found.
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1
Authenticating using [MX] security server ...
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 116.74.99.120
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Retrying ...
Retrying ...
now please tell me what to do ?
Old 06-30-2010, 15:26   #2 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 686
use in Mxkey new system................
tick in load RFBB from server and store RFBB to server
......and then write............sucsess in security field
The Following 2 Users Say Thank You to jaleelkuttikkar For This Useful Post:
Old 06-30-2010, 17:00   #3 (permalink)
Member: 553599
brother use this rpl file 100000000% sucess
i had solve same problem many times
3110c-Contact Service.rar - 4shared.com - online file sharing and storage - download
The Following User Says Thank You to mukul_korde22 For This Useful Post:
Old 06-30-2010, 18:49   #4 (permalink)
Member: 1299960
Thanks Meter: 36
before starting nokia tool, goto options, click servers and click again server list. if server list show, select blade server 4 and click select server. now run nokia tool - click scan, goto PM and then select PMM auth (it will get succeed) load pm which contain field 1 and 309, click on write and everything will be ok, 100% tested.
The Following User Says Thank You to PB Enterprise For This Useful Post:
Old 07-01-2010, 06:33   #5 (permalink)
SONU898's Avatar
Member: 617865
Thanks Meter: 111
Cool good keep it up .............
your trick is work .very good post
keep it up
Old 07-02-2010, 16:43   #6 (permalink)
Member: 1299960
Thanks Meter: 36
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
No SX4 Card found.
Retrying ...
Retrying ...
start mx-key, goto options-server and click server list. when server list shows up, click the Blade server #4 and click select server. now try again PMM AUTH, write pm filed 1 and 309 and post result
Old 07-11-2010, 12:37   #7 (permalink)
Registered User
Member: 502031
Thanks Meter: 66
SW Version: V 07.30 07-05-09 RM-237 (c) Nokia.
Imei plain: 35934302500000-2
Product Code: 0566963
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 359343025000002
Counter: 0/3, 0/10
Boot error: 00 00 72 00
- Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar.
- Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables.
- On rare occasions phone might be damaged or dead. So, if possible, try with another phone.
Certificate programmed successfully !
ncp file right
no rijlt mxkee pm 1-309 bat sem pl help me
Old 07-11-2010, 13:02   #8 (permalink)
Member: 1327245
Thanks Meter: 57
thankssssssssssssssssssssssssssssssssssssss
Old 07-11-2010, 13:08   #9 (permalink)
Member: 1152038
Thanks Meter: 256
-Repair SD
-PM Auth
-write Full PM
-full factory
100%will be solve
Old 07-11-2010, 13:08   #10 (permalink)
m.awais.as's Avatar
Member: 1284347
Sonork: 100.1592292
Thanks Meter: 976
thankx bro......for this info...........good work
Old 07-11-2010, 13:10   #11 (permalink)
Member: 1341353
Thanks Meter: 15
nice,.............
but can be solve easily by recov-Cert .................
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.39548 seconds with 8 queries
