03-14-2010, 11:57 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: burkina faso
Member: 457765 Status: Offline Thanks Meter: 77 | mxkey with hwk interface help |
03-14-2010, 21:18 | #8 (permalink) |
Insane Poster Join Date: Jun 2003 Age: 50
Member: 31665 Status: Offline Thanks Meter: 4 | i have same problem ! Cable is ok, i can flash phone with HWK. By pressing scan buttom - mx-key read information an phone info work ok. only BUS-Check don´t work, allways bootloader problem, and i can not flash !!! |
03-14-2010, 22:09 | #9 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
there are 2 flash loader, which flash loader you are using on? BR | |
03-14-2010, 22:59 | #12 (permalink) |
Member: 31665 Status: Offline Thanks Meter: 4 | OK. I have installed mx-key v3.2, then 3.3v1.6, and i have all bootloder folder: 03.09.002.1 8.6.1.31560 8.30.12.34536 8.36.2.35145 8.49.19.36652 09.38.13.3 I have tested all folder, but nothing works !!! whats wrong bro....... |
03-14-2010, 23:02 | #13 (permalink) |
Member: 31665 Status: Offline Thanks Meter: 4 | by pressing phone info buttom: Version Info: MCU SW version: V 5.10 17-11-06 RM-189 (c) NMP HW version: 0521 UEM version: 2339 UPP version: 8705 RFIC version: 0500 DSP version: P05w06.v39 LCD version: SDI:LD184v89 PPM version: V 5.10 17-11-06 RM-189 (c) NMP AD ADSP SW version: p V 5.10\n17-11-06\nRM-189\n(c) NMP\nad Product Info: Production serial number: DDR273383 Product code: 0515541 Module code: 0203314 Basic production code: 0515909 Serial Numbers: IMEI warranty: 354819/01/901854/3 IMEI plain: 354819019018543 IMEI spare to net: 3A 45 18 09 91 10 58 04 IMEI SV to net: 33 45 18 09 91 10 58 24 F3 Other Info: CS type : GSM/DCS1800 Project Name: Dragon (EU) BSI: 3,4 KOhm Imei net: 35481901901854 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN only bus chek not work!! |
03-14-2010, 23:12 | #14 (permalink) | |
Insane Poster Join Date: Dec 2005 Location: Armenia Age: 42
Member: 206700 Status: Offline Thanks Meter: 6 | Quote:
i have a some problem using ufs as fbus interface after reading this thread , i was try with ub , but not work , mx-key can't find ub as interface , i try refresh , but not work | |
03-15-2010, 04:42 | #15 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Philippines
Member: 230087 Status: Offline Thanks Meter: 373 | SOLUTION TO: " bootloader not responding mostly ram problem message" here is the solution: 1- create folder and name it "FLASH LOADERS" 2- copy all known loaders from jaf, hwk, cyclone, old mx-key version and PASTE IT THERE 3- Now paste the folder in C:\mobileEx\3.3\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\Flash Loaders 4- Then Go to "CONFIG" and tick "FLASH UPDATE DIRECTORY" and select "FLASH LOADERS" which you have created. http://img133.imageshack.us/img133/1048/cfg1o.jpg http://img34.imageshack.us/img34/6658/cfg2.jpg Now test. Let MXteam concentrate on SL3..... |
Need help to install mxkey with jaf interface | aminnovelty | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 05-17-2011 17:01 |
mxkey with ufs interface dct4 flashing problem ..the solution is here | ELOY1024 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 03-28-2010 02:10 |
cannot unlock Sharp 802sh with HWK , pls help | preshaust | HWK | 5 | 12-23-2005 11:18 |
M-Bus Errors on UFS with HWK please help.. | alexbrowne | HWK | 0 | 12-16-2005 20:58 |
