Old 02-21-2009, 00:24   #1 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
[MXKEY - INFO] MXKEY CCS Tools Manual
Flashing Step For CCS Tools
1. Info
Phone should Powered ON in any operation.
Always "Scan Phone" before any operation.
For dead phone use "Emergency Mode".
2. Info
Press Emergency Mode
 Press and Hold (* + 5 + Power button) now ...
Pooling phone ...
wait until Phone Detected
3.Manual Phone Selection
Phone detected in download mode.
Please select "Model" manually ...
Check CBB to Open Flash File
Select From File
and Open
Loaded Flash File
Flash Phone
Flashing Proses , Please wait
Flashing Process done .
Video Manual download
Cable Scema download
br,
The Following 149 Users Say Thank You to Andra For This Useful Post:
Old 03-31-2009, 03:57   #2 (permalink)
Member: 724987
Sonork: 100.1588989
Thanks Meter: 13
Need help to find my English not good download CCS Tools Manual
Platform to connect, please help.
The Following User Says Thank You to wangbaojie For This Useful Post:
Old 03-31-2009, 04:19   #3 (permalink)
Member: 724987
Sonork: 100.1588989
Thanks Meter: 13
This problem has been resolved
Old 03-31-2009, 09:31   #4 (permalink)
Member: 174952
Thanks Meter: 2
hi all
before i update my smart card i can use emulator pk-83
but after i upgrade smard card ccs3tools service softawre can't detect dongle..
what wrong?
thank's
Old 03-31-2009, 09:55   #5 (permalink)
Member: 174952
Thanks Meter: 2
hope emulator pk-86 available soon
thank's
Old 04-01-2009, 09:05   #6 (permalink)
Member: 942099
thank's
Old 04-03-2009, 14:24   #7 (permalink)
Member: 325999
Thanks Meter: 113
is it possible to use prolific moto 139 usb cable for nokia 2505 ? i tried with above cable schema but not succeed ,need help.
REGARDS
Old 04-03-2009, 17:02   #8 (permalink)
Member: 325999
Thanks Meter: 113
[QUOTE=neo_49;4317728]is it possible to use above cable schema for n2505 couse i m not succeed with that
REGARDS
Old 04-19-2009, 09:55   #9 (permalink)
suntysunty's Avatar
Member: 226172
Thanks Meter: 946
Error
Error
Error
ErrorErrorErrorErrorError
Error
Old 04-26-2009, 17:44   #10 (permalink)
Alim Hape's Avatar
Member: 43548
Thanks Meter: 2,192
Originally Posted by suntysunty View Post
Error
Error
Error
Error
hey, what is your problem?
The Following 5 Users Say Thank You to Alim Hape For This Useful Post:
Old 06-15-2009, 20:36   #11 (permalink)
virgix's Avatar
Member: 69608
Thanks Meter: 63
hello sir,
what kind of cable can we use for this software
test using RJ45 cable/Moto C261 cable detect ok using QPST configuration but not detect on your software whats wrong????thanx you..please reply
Old 06-23-2009, 20:10   #12 (permalink)
Member: 1059036
Thanks Meter: 57
pls need help how to unlock my phone with mx-key
hi
i have many pcs but i dont now how i can unlock this type
of phone bb5+ and new dct4 pls method tnks in adv....
Old 06-23-2009, 22:48   #13 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
just follow,read,and study by doing our sticky post
br,
The Following 3 Users Say Thank You to Andra For This Useful Post:
Old 07-13-2009, 19:31   #14 (permalink)
Member: 1073927
Sonork: mas_mas
I'm unable to connect 2505 and already follow the guides given, I bought 2 pcs cable and none of them worked.. Check the RX and TX and all is ok, the phone was locked and already try with another phone and still not connect. Detail cable needed, please...
Old 07-13-2009, 19:37   #15 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
p
Use moto c261 profolic usb cable..flash phone in emergency mode by pressing *+5+pwr on..software should detect ur phone..also dont forget to set profolic com port configuration in interface tab.
[MXKEY - INFO] MXKEY Nokia PM Files Andra MXKEY Nokia Flasher and Unlocker (by Alim Hape) 163 04-19-2013 08:44
[MXKEY - INFO] Nokia BANDCHANGE RPL Files sahil2000ind MXKEY Nokia Flasher and Unlocker (by Alim Hape) 79 12-03-2011 17:09
[MXKEY - INFO] Learning Videos - how to work with software hamada-almasry MXKEY Nokia Flasher and Unlocker (by Alim Hape) 301 03-01-2011 11:03
[MXKEY - INFO] MXKEY Main Features and Supported Phones Alim Hape MXKEY Nokia Flasher and Unlocker (by Alim Hape) 86 04-11-2010 16:06
Page generated in 0.26658 seconds with 9 queries
