Old 01-02-2010, 07:55   #1 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
[MXKEY - INFO] Nokia BANDCHANGE RPL Files
Let's share here
LIST OF BB5 BANDCHANGE RPL
3110cBandChange.rpl
3500BandChange.rpl
5200BandChange.rpl
5300BandChange.rpl
5310BandChange.rpl
5610BandChange.rpl
6085BandChange.rpl
6300BandChange.rpl
6301BandChange.rpl
6500cBandChange.rpl
6500sBandChange.rpl
6555BandChange.rpl
N78BandChange.rpl
N95BandChange.rpl
!!! BEFORE DOING ANY THING PLS MAKE FULL BACKUP OF ALL THE IMPORTANT THINGS LIKE RPL DATA AND PM !!!
IN CASE IF ANY THING GOES WRONG U CAN MAKE THE SET AGAIN IN THE ORIGINAL CONDITION.
THERE MUST BE MORE BANDCHANGE RPL FILES SO PLS ALL MX-KEY USERS POST HERE ALL THE STUFF.
THESE FILES ARE NOT MADE BY ME I HAVE JUST COLLECTED IT AND POST IT HERE FOR ALL THE MX-KEY USERS.
HAPPY NEW YEAR TO ALL MX-KEY USERS, SUPPORTERS AND MX-KEY TEAM.
WBR
sahil2000ind
The Following 283 Users Say Thank You to sahil2000ind For This Useful Post:
Old 01-02-2010, 08:28   #2 (permalink)
Member: 472388
Thanks Meter: 6
do u have for N82?
TQ
The Following 6 Users Say Thank You to zoland_hole For This Useful Post:
Old 01-06-2010, 12:19   #3 (permalink)
Registered User
Member: 461468
Thanks Meter: 139
Originally Posted by sahil2000ind View Post
Let's share here
3110cBandChange.rpl
3500BandChange.rpl
5200BandChange.rpl
5300BandChange.rpl
5310BandChange.rpl
5610BandChange.rpl
6085BandChange.rpl
6300BandChange.rpl
6301BandChange.rpl
6500cBandChange.rpl
6500sBandChange.rpl
6555BandChange.rpl
N78BandChange.rpl
N95BandChange.rpl
WBR
sahil2000ind
Hi, please inform? How to use this?
The Following 13 Users Say Thank You to abellcell For This Useful Post:
Old 01-06-2010, 13:59   #4 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
Thanks Meter: 526
Originally Posted by uttam4u2002 View Post
how to use it? can u explain please?
write rpl ......................
after unlock having weak signal you must write band change rpl as a rpl
signal may vary in different country so you need to write this to have full signal..
The Following 20 Users Say Thank You to marvin03 For This Useful Post:
Old 01-07-2010, 03:40   #5 (permalink)
Sniper_04's Avatar
Member: 704097
Sonork: 100.1607742
Thanks Meter: 820
back-up first pm308 and rpl,then write band change rpl,thats all
The Following 3 Users Say Thank You to Sniper_04 For This Useful Post:
Old 01-07-2010, 07:36   #6 (permalink)
jodhpur_raj's Avatar
Member: 737954
Sonork: Mobile
Thanks Meter: 107
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11472, Date: 27-11-2009
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 07000209800F7E5603DE4C60DEFB3799B84AFF7B
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 35318003757231
Original Product code: 0572571
Bluetooth ID: 0025CF038268
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 05.60 10-12-08 RM-436 (c) Nokia
Imei plain: 35318003757231-3
Product Code: 0572571
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2009-04-21T08:32:08Z
SW Version: 06.51
Variant Version: 011
ProductProfile: RM436_0572571_06.51_011.spr
Simlock: 0572571_simlock.bin
Imei net: 353180037572313
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
how solu this problems
The Following 12 Users Say Thank You to jodhpur_raj For This Useful Post:
Old 01-11-2010, 17:38   #7 (permalink)
Member: 132529
Thanks Meter: 12
anyone have for 6280??
The Following User Says Thank You to xtreme_digital For This Useful Post:
Old 01-13-2010, 06:19   #8 (permalink)
Member: 1201278
Sonork: 100.1679408
Thanks Meter: 30
give mi all nokia video manual plish mx key
The Following 3 Users Say Thank You to ismailmobile For This Useful Post:
Old 01-16-2010, 04:55   #9 (permalink)
noey's Avatar
Member: 969424
Sonork: 15710
Thanks Meter: 47
@ sahil2000ind
How to mnual Save to folder
The Following User Says Thank You to noey For This Useful Post:
Old 01-16-2010, 08:25   #10 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
Originally Posted by noey View Post
@ sahil2000ind
THERE IS NO SPECIFIC MANUAL FOR THIS.
IF U WANT TO CONVERT URE PHONE
BB5 BAND CHANGE
BB5 850/1900mhz to 900/1800mhz
THEN U CAN USE THESE BAND CHANGE RPL FILES. JUST SELECT THE REQUIRED RPL FILE AND WRITE IT TO THE PHONE.
WBR
sahil2000ind
The Following 8 Users Say Thank You to sahil2000ind For This Useful Post:
Old 01-20-2010, 19:59   #11 (permalink)
Member: 255072
Thanks Meter: 46
isnt need to be change filter ic u know some old models was need it exact 6030b?
The Following User Says Thank You to speedstarrr For This Useful Post:
Old 01-21-2010, 07:03   #12 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
THESE BAND CHANGE RPLS ARE ONLY FOR BB5 SETS.
WBR
sahil2000ind
The Following 2 Users Say Thank You to sahil2000ind For This Useful Post:
Old 01-21-2010, 08:08   #13 (permalink)
sanjubhai's Avatar
Member: 386868
Thanks Meter: 125
boss in bb5 the hardware structure is almost same the difference is just in the software ..........
wbr: sanjubhai.
The Following 2 Users Say Thank You to sanjubhai For This Useful Post:
Old 01-21-2010, 16:35   #14 (permalink)
Member: 358086
Thanks Meter: 2
change
BB5 BAND CHANGE
WBR
sahil2000ind
how to change bb5 900/1800 to 850/1900
The Following User Says Thank You to general_py For This Useful Post:
Old 01-23-2010, 05:20   #15 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
5300b ,5200 and 5310b tested by me just backup your o/g rpl and pm data and write band change rpl no need to any modifay in hardware..
The Following 9 Users Say Thank You to kalpeshoza For This Useful Post:
Page generated in 0.30788 seconds with 10 queries
