11-19-2011, 12:10 | #136 (permalink) |
Junior Member Join Date: Mar 2007
Member: 462159 Status: Offline Thanks Meter: 0 | mx key error only one time opening software , then after i am restart computer after opening mx-key showing error application error |
11-19-2011, 14:12 | #138 (permalink) | |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | Quote:
http://forum.gsmhosting.com/vbb/f550...t-ppm-1341361/ | |
11-19-2011, 14:36 | #139 (permalink) |
Freak Poster Join Date: Jul 2007 Location: FENI,BANGLADESH Age: 38
Member: 537829 Status: Offline Thanks Meter: 96 | nokia e72 ded usb flash success. nokia e72 ded usb flash success. MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085F7C0 Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.70 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Processing MCU file: rm530_071.004_prd.core.fpsx [BB5,XSR 1.6] size: 107.57 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1A28A2CB CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 1980021876790344BB1C0C9A5C0C18A0EF91E7B1 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID: 3E273BF637BE26FA Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0058 - 0000 0121 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1A28A2CB FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35151304746947_CE RT.rpl" CMT PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 227.31 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0E77FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 660D81A4 [RAP Certificate 175 v.1] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 2 min 21.234 s Processing PPM file: rm530_071.004_41.01_APAC_QW2_prd.rofs2.fpsx [BB5,XSR 1.6] size: 57.52 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 81 MB CMT FLASH,MuxOneNAND area [07CC0000-0CDBFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 1 min 22.422 s Processing CNT file: rm530_071.004_U007.000_prd.uda.fpsx [BB5,XSR 1.6] size: 10.20 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 265.75 MB CMT FLASH,MuxOneNAND area [0E780000-1F13FFFF] Flash programming ... Programming completed in 14.969 s Total time for flashing process(boot+erase+write) was 4 min 25.234 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia E72 USB Phonet, PORT_ID: 2F197EB Verifying communication to device OK. Phone type: RM-530 (Nokia E72-1) SW version: V ICPR82_11w16.3 19-05-11 RM-530 (c) Nokia Imei plain: 35151304746947-0 Product code: 0587211 Battery voltage: 3855 mV, current: 139 mA ApeCoreSw: 071.004 Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 351513047469470 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
11-20-2011, 08:57 | #140 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 46
Member: 81130 Status: Offline Thanks Meter: 52 | fu*** as this update just u can say BUY ORIGINAL XTC CLIP PLUS < add and add .......balabala bugfixed and bugfixed balabala ......... u know 2 days i tryed to unlock n95-8g , cant unlock it with this version 3.5 1.5 and this 3.5 rev 1.4 after many times and entered 5 fourm i found the same problem and the problem solved with 3.5 rev 1.2 ......u can say to all member downgrade its best fuc******************!!!!!! |
11-20-2011, 16:01 | #141 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1205820 Status: Offline Thanks Meter: 14 | mxbox Hi, colleagues here Mxbox installation Hti 100% with the instructions of the forum everything went as planned, all applications are working. Congratulations, Mr. Manolo and Team. Now towards December 1, 2011 ... Hugs .. |
11-22-2011, 17:54 | #144 (permalink) |
Insane Poster Join Date: Jul 2009 Location: **********
Member: 1073029 Status: Offline Sonork: 100.1587016 Thanks Meter: 49 | Need help Dear MaNOLE Sir, My MX-Key BB5 credits automatically converts into SL3 credits, whereas i not click it for convert, How can my credits reverse in last stage. Regards |
11-23-2011, 09:14 | #146 (permalink) |
Freak Poster Join Date: Dec 2009 Location: India
Member: 1191805 Status: Offline Thanks Meter: 58 | Bro thaks again... As u said, i try to update HTI on other pc, but same result i received as above. I cant understand why is this like this..??? I have good DSL internet connection and good quality of cable. I Request to MANOLE, please give some suggestion on this problem... Why i cant update my HTI. Thank You Regards mick12 |
11-23-2011, 11:13 | #147 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | PLEASE TEAM HELP I INSTALL HTI TODAY MADE UPDATE ALL SUCCESS BUT WHEN I OPEN mobileEX 3.5, HTI FLASHER INTAFACE DISPLAYED BUT SHOWS NO SECURITY DONGLE DETECTED |
11-23-2011, 15:40 | #148 (permalink) |
Major Poster Join Date: Jan 2009
Member: 954857 Status: Offline Sonork: mzabbasi79 Thanks Meter: 6 | Brother i have installed hti but still i can't use the programme. The following massage is shown in the desktop MXKEY Executable has encountered a problem and needs to close. We are sorry for the inconvenience.Please help. I tried reinstall but same problem. Previously version 3.4 was working well, with new version it can not be installed correctly. Please reply me and solve my problem. |
11-23-2011, 16:04 | #149 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | MANOLE Please unblocked my card it is not my fault that you deslike IPMART BANNER, I paid you for you SL3 Credits and you CDMA Credits, PLEASE unlockedd it, i need work and i need pay bills like you! you are the responsable, im not going to pay for another card, ok??? that is an abuse of mx team, im from venezuela, and my reseller bought it two years ago! |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
