02-20-2009, 10:03 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | MXBOX/HTI - MXKEY Software Updates mobileEx 1.8 released Whats NEW: - Added, BB5 Flashing support. With Selectable RAP and APE flash only for best flashing result. - Added, BB5 Read ASK(GT format) and Write RPL(NMP format) - Improved, Communication logic to fixes CPU and Mem usage on some PC. - Improved, Base band Self test to fix BB5 issues. - Added, DCT4+ Asic 2 and Asic 11 direct unlock. - Added, DCT4 'new' Asic 2 (1110,1600 new version) unlock. - Added, LCD contrast reset to fix 1110i LCD issues after unlock. - Improved, DCT4 Imei patch to fix ESN patch issues. - Fixed, CS patch only for 7250i or 6610i. - Fixed, BB5 SIMLock backup & restore. - Improved, Menu Editor (propuct profile) parser to support new *.ppu. - Improved, UFSx boot to fix NBOX 'cant boot' issues. - Added, ASIC_ID check when flashing so you wont kill the phone if you select incorrect file. - Many minor bugs fixed. |
The Following 429 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2009, 10:11 | #2 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | April 19 2007 mobileEx v1.9 ready Whats NEW: - Added, BB5 Standalone SW downgrade procedure credits to Dejan K. - Improved, DCT4/BB5 phone change mode. Last edited by MANOLE; 02-20-2009 at 10:19. |
The Following 96 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2009, 10:19 | #3 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | May 05 2007 mobileEx 2.0 is out Whats NEW: - Added, Self update button, software update made simple. - Added, DCT4 online logger/IMEI fix - Added, Direct USB connection for FBUS protocol. - Added, Integrated and online(under construction) help file - Re-enabled, DCT4 ADSP flashing function - Added, DCT4 ADL/APE flashing function - Added, DCT4 CNT128 auto conversion - Improved FBUS and MBUS connection. - Improved DCT3 flashing function. - Improved Multiflashing, flashing continuously is now possible. - Improved Format and Self test function. - Fixed, DCT4 relock bugs. - Fixed, BB5 booting problems on some phones. - Added, BB5 Certificate (NPC + SIMLOCK) backup - Added, BB5 custom erase. WARNING: Erasing flash could be dangerous for BB5 phones, use with good reason only !!! - Added, logs while reading PMM - Added, LED status to determine box state - Added, Progress on file info while flashing DCT4 phones - also so many changes that would be fill out this page if written ) |
The Following 70 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2009, 10:23 | #4 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | May 26 2007 mobileEx 2.1 Whats NEW: - Added, BB5 USB Flashing. - Added, Direct BB5 SP unlocker using UFS/JAF/DKU2 USB/COM port - Improved, BB5 Certificate backup(read) and RPL write - Added, BB5 PMM (superdongle) auth (currently only working IF SX4 connected to the system, server solution under construction) - Fixed, DCT4 Watchdog test - Added, SP Unlock for some CDMA phone to fix 'Phone restricted' - Fixed, ESN patch not work when invalid ESN entered - Added, Patch software option for IMEI/ESN changer. - Some other bugs fixed. |
The Following 47 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2009, 10:26 | #5 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | June 30 2007 mobileEx v2.2 Whats NEW: - Added, Support Server for BB5 PMM(SX4) Auth - Fixed, BB5 RAP3Gv3 boot - Fixed, BB5 USB flashing for BB5 RAP3Gv3. - Fixed, DCT4 ADL flashing bugs - Fixed, VCOM changing mode result in 'busy' - Improved, BB5 RPL write PRODUTCODE,HWID and PSN now written. fixed SIMlock upload for BB5 RAP3Gv3. - Improved, BB5 SIMlock INFO(BB5 RAP3Gv3). - Improved, 'GetAddr' for BB5 custom erase - Improved, Phone Detection after restart. - Changed, COM port detection in device list, Only active ports are displayed - Improved, Self Update. Will download Only if version on server is newer. - Fixed, DCT4 RPL logger - Changed, internal code for WinXP X64 and Vista compatibilities |
The Following 45 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2009, 10:27 | #6 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | July 11 2007 mobileEx v2.2.1 Whats NEW: - Added, DCT4 IMEI logger client to support mx server - Improved, BB5 USB flashing - Improved, "PhoneSafe" function for BB5 - Added, read BB5 RAP FLASH IMEI when BUS check - and some minor bug fix. |
The Following 48 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2009, 10:38 | #7 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | August 20 2007 mobileEx v2.2.2 build 778 fresh installer released Whats NEW: - Fixed, all RAP3Gv3 BB5 boot (hopefully ) - Improved, BB5 USB flashing ('new' APE phones) - Improved, BB5 certificate tool backup 'ALL section' will read NPC,VARIANT,CCC,HWC RAP and APE. write RPL function now able to write ALL section from backup or NMP. - Improved, SL INFO read - Added, HW & Part info during 'Phone Info' - Added, Master Code read during 'BUS check' The master code readed from phone could be used to unlock security code for attached phone even counter was already blocked, including 'new' TIKU CDMA phones - Added, Mass Memory Storage Device flash handle (6265,6230i, etc) - Changed, Format File System routine(tab maintenance->tabset FS). - Fixed, DCT4 ADSP flashing(NGAGE) - Fixed, DCT4 APE flashing - Fixed, some minor bugs and added new bugs(maybe) |
02-20-2009, 11:15 | #8 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | August 31 2007 mobileEx v2.3.0 whats NEW: - Added, DATA1 backup confirmation before FLASH erase - Improved, BB5 certificate backup (certificate size displayed, will exit if certificate is corrupted !) - Improved, PMM auth routines (will exit if IMEI or SIMLOCK is bad!) - Improved, Master code read (remember: we're the first and the only one solution at the moment) - Improved, SL_INFO read (sometimes readed corrupted data at long size on CDMA phones) - Improved, EEP address allocation on 'GetAddr' - Improved, 'Get details' on selftest - Fixed, BT MCM auth bug - Fixed, PMM read bug (readed 0 bytes value) - Fixed, server password missing char |
The Following 38 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2009, 11:27 | #9 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | December 07 2007 mobileEx v3.0 public-beta Whats NEW: - Almost all elements are new, the most important part of this βeta was that it was finally recoded from scratch. Not implemented yet: - JAF interface support - DCT3/L function - DCT4PLUS unlock patch - BB5 generic unlock - and some other. This brand new exe will supports MXKEY and MXKEY LiTE What is MXKEY LiTE? its new dongle for mobileEx, SmartCard based. What about future support about MXKEY? We released MXKEY LiTE for *******r satisfaction. MXKEY LiTE will be cheaper, and thats why we call it "Lite". MXKEY will be fully supported as MXKEY LiTE, note that there was no differences between MXKEY and the LiTE version. Unimplemented features will be added as soon as possible. while that, you could also request feature |
The Following 35 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2009, 11:31 | #10 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | December 11 2007 v3.0 Beta3, Public-Release. Whats NEW: - re-constructed, CDMA Tuning. - re-constructed, Quick repair page (BT repair, LCD reset, etc). - improved, Online Updater. - added, CDMA NFP folder to model selection. - and other minor. |
The Following 37 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2009, 11:35 | #11 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | December 15 2007 v3.0 Beta4, Public-Release. Whats NEW: - re-constructed, DCT4 CNT 64->128k conversion. - Added, support for new product profile type (BB5,DCT4PLUS). - re-constructed & improved, DCT4PLUS unlock patch - RELOCK now possible, also support 1200/1208 all version (click "No" if you asked to restore flash block) - Fixed, crash (application closed) on VCOM module. - Improved, FBUS scan (will change phone mode if needed) - Fixed, PM write function (BB5 RF & BB parameters bug) - Added, Auto driver update for UFS and Token on setup. - and other minor. Note: you could also update using "Check For Update" button from mobileEx.exe |
The Following 40 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2009, 11:41 | #12 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | December 27 2007 v3.0 Beta5, Public-Release. Whats NEW: - New MXKEY LiTE firmware introduced, FW ver: 00.13 - Added, JAF FBUS protocol (Flashing bus not implemented yet) - Added, Component version info on load. - Fixed, Erase whole flash bug on multi flash chip phones. - Fixed, BT flush after firmware update. - Fixed, BB5RPL decryption fail when write RPL. - Added, Product code auto selection on "Scan" - and other minor. Note: For MXKEY LiTE dongle user, you need to "Update FW" first. This will also solved activation issue. Use "Check For Update" button for self update |
The Following 42 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2009, 11:58 | #13 (permalink) | |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | January 18 2008 v3.0 Beta6, Public-Release. Whats NEW: - JAF BOX fully supported. - Added, Flash Emulation mode (to verify flash files, will not write to the phone) - Added, Support for BB5 RAPIDO phones (RAP NAND flash handle) - Added, Easy IMEI restore (Automatically search for backup from '\data\backup\RPL\' folder if available) - Added, DCT4 Mass Memory device (NAND) flashing support - Added, UFS FW V 2.8 update dialog if needed (required for RAPIDO phones) - Added, UFS Driver update dialog if 'NO CONNECTION' - Fixed, N-GAGE Adsp flashing bug (CRC error=Contact retailer). - Fixed, DCT4 Online IMEI Logger (ESN issues) - Fixed, WD2 boot (increasing boot timeout) - Fixed, User Code changes - Fixed, BT MCM image upload - Fixed, Erase whole flash routine - Fixed, Reset DATA1 (WD2 bug) - Fixed, TIKU flashing with huge image header stopped - Fixed, DCT4 UCP 128k conversion (2865 issue) - Fixed, DCT4 PLUS SpUnlock bug on old models - Removed, Joker module from installer - Added, SIEMENS Tool for EGOLD and SGOLD (not tested!) module. - and other minor. Required: for MXKEY, FW ver: 00.11 for MXKEY LiTE, FW ver: 00.13 Interface: UFS FW: v2.8 JAF FW : 01.B0 Quote:
02-20-2009, 12:08 | #14 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | February 07 2008 v3.0 Beta7, Public-Release. Whats NEW: [MAIN] - Added, "Dont Show This Again" checkbox of UFS FW update confirmation dialog - Improved, Check For update routine will allow to update module separately on future updates [CCS] - Added, New Module CCS "Foxconn PST" (NK CDMA ODM/QUALCOMM) Features: * Flashing using HEX/ CBB (Bundle Files) * Normal Flashing or Emergency Mode (*+5+POWER) supported * Flashing Emulation * Security Code Read/Write * SPC read/write * LCD contrast Read/Write * Reset File System (PRI) * Userdata Backup/Restore * EFS File Explorer * And soon [VCOM] - Revised, VCOM module [NK] - Added, Patch SIMLOCK flashing option + SKip SW patch on Init Simlock (1650 bug) - Improved, Flash erase routine - Added, UEM WD test - Added, Verify UEM option on DCT4 RPL write [SIEM] - Fixed, SGOLD baudrate issue - and other minor. Version Information: Main: » mobileEx.exe, version: 3.0.0.889 » mobileEx.dll, version: 1.0.0.1144 Modules: » ccs.dll, library version: 1.0.0.103, module version: 1.00 beta » nk.dll, library version: 1.0.0.897, module version: 1.00 beta » siem.dll, library version: 1.0.0.293, module version: 1.01 beta » vcom.dll, library version: 1.0.0.664, module version: 1.02 final Required Dongle revision: MXKEY, FW ver: 00.11 MXKEY LiTE, FW ver: 00.13 use "Check For Update" button for self update |
The Following 52 Users Say Thank You to MANOLE For This Useful Post: |
02-20-2009, 15:40 | #15 (permalink) |
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | February 12 2008 v3.0 Beta8, Public-Release Whats NEW: MAIN - Fixed, "Check For Updates" bug - Fixed, UFS baud problem (DCT4 erase issue?) NK - Fixed, DCT4PLUS non patch unlock (1600,1110i) - Added, Automatically save RPL backup on "Bus Check" for DCT4 - Fixed, DCT4 Erase ! (hopefully fixes this common issue, tested on 3 different PCs Intel/AMD based) VCOM - Fixed, Incorrect registration pop-up |
The Following 72 Users Say Thank You to MANOLE For This Useful Post: |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
ORIGINAL SOFTWARE FOR SALE OR TRADE !!!!!!!!!!!!!!!!! | andrew bennett | Main Sales Section | 1 | 07-27-1999 21:31 |
