| | #16 (permalink) |
| Product Manager Join Date: May 2008 Location: MXKEY probably BEST NOKIA TOOL
Member: 780644 Status: Offline Sonork: 100.88888 Thanks: 598
| April 14 2008 v3.0 Beta9 RC1, Public-Release Whats NEW: MAIN - Improved, Check for updates (more control to updates) - Implemented, Online News(add RSS feeds and forum news) - Implemented, Options to enabled/disabled specific module NK - MTBOX Partially supported(FBUS function) - Improved, DCT4 boot - Improved, Auto phone detection (always "Scan phone" or "Bus check" before any operation!) - Improved, CDMA phones compatibility - Improved, Keyboard test map (now possible to test all keys including communicator series) - Added, Various tests (Camera,IR,MMC,SIM,USB) - Added, Band & System mode control - Added, CDMA NVD (Pri) management (under Phone Settings tab) - Added, CDMA CS product type read - Added, RF/BB PM backup/restore - Added, BB5 CNT 128 K conversion - Added, COMBOFLASH detection - Fixed, DCT4 write RPL (add DATA1/2 only options) - Fixed, BB5 Custom erase - Fixed, DCT4 APE flash(better error handler) - Improved, DCT4 SP unlock routine - Improved, CDMA tuning (SET,CAL and PANEL data are now readed and written correctly) - Redesigned, PMM, Phone Settings, CDMA tune & Quick Fix page(under services tab) - Reconstructed, BB5 'Dejan K' unlocker - Introduced, DCT4 read flash works for Asic type 2 phones only (check 'Phoenix format' for writable output) - just for test ! - Introduced, DCT4 Non Volatile Data(NVD) management (in development, not finished yet) CCS - Added, ARMPRG/Bootloader manual select to handle 'dead' phones - Improved, Phone explorer routine and ui use "Check for Update" button |
| The Following 13 Users Say Thank You to MANOLE For This Useful Post: |
| | #17 (permalink) |
| June 08 2008 v3.0 Beta10 RC, Public-Release Whats NEW: MAIN - Added, Support forum and homepage menu (News) NK - Added, Image DL button (direct image download from support based on product code, currently for BB5 products only !) - Implemented, RX2 loader support (UFS FW v28 only !!!). - Implemented, Show detailed options in configuration window - Added, Auto select Gen when "Scan" product in configuration window - Added, Auto set RX2 for BB5 in configuration window - Added, market highlight for easy market choice in configuration window - Added, Auto set RX2 for BB5 in configuration window - Added, BB5 CNT page size detection for auto CNT conversion - Added, Skip if not empty option - Added, Manual PP write file - Added, BB5 MMC and SD card content flashing - Added, BB5 verify NPC option on write RPL - Added, BB5 skip specific section on write RPL - Added, BB5 skip (certificate) erase option on write RPL - Added, BB5 Reset NPC - Added, BB5 online logger client (instant !!!) - Added, BB5 RPL write on RX2 enabled phones - Fixed, DCT4 MM flash handling - Added, DCT4 imei OTP/UEM read via FBUS for non CUI phones. - Added, Latest DCT4PLUS ASIC11 sp unlock patch method(Patch on the fly) - Added, DCT4PLUS ASIC11 online logger client - Added, extended GSM/WCDMA band type set - Improved, BB5 (RAP/CMT) NAND flash handling - Improved, Flash chip info. device page size and type now displayed. - Improved, DCT4PLUS ASIC11 ask read + manual IMEI/ESN input when UEM damaged - Changed, 'Browse' to Directory setting in configuration window CCS - Improved, QCOM protocol for faster flashing - Improved, Dead phone flashing handle - Added, Phone code read for 6088,7088 phone - Added, Image DL button (direct image download from support) - Fixed, User area backup/restore |
| The Following 12 Users Say Thank You to MANOLE For This Useful Post: |
| | #18 (permalink) |
| June 09 2008 v3.0 beta10 RC2 released (module patch update) Whats NEW: - NK library version 1.0.0.4225 -Fixed, BB5 Online Logger -Fixed, BB5 RAP NAND (with RX2 enabled) flashing -Added, Full BB5 RPL backup for new phone (SIMLOCK+SIMLOCK_KEY,WMDRM_PD) -Added, BB5 user code reset(blocked counter) and status, will not lose user data. -Improved DCT4 Asic 11 Online Logger (Imei challenge issue) -Added, auto create folder option on configuration window -Fixed, DP2.0 folder listing Use "Check for update" but u need to tick "Check modules update automatically" on Options-> General Settings (beta10 required to be installed first !). After update: Code: Main: » mobileEx.exe, version: 3.0.0.2329 » mobileEx.dll, version: 1.0.0.2098 Modules: » ccs.dll, library version: 1.0.0.498, module version: 1.00 B » nk.dll, library version: 1.0.0.4225, module version: 1.00 B10a » siem.dll, library version: 1.0.0.293, module version: 1.01 B » vcom.dll, library version: 1.0.0.757, module version: 1.03 Drivers: » UFS2XX.sys, version: 2.2.4.1 » FTD2XX.sys, version: 1.6.20.1 |
| The Following 17 Users Say Thank You to MANOLE For This Useful Post: |
| | #19 (permalink) |
| June 27 2008 v3.0 Beta11 RC2, Public-Release Whats NEW: MAIN - Improved, dongle communication routine - Fixed, Self Update NK - MTBOX DCT4 flash supported. - Improved, DCT4&BB5 Online Logger - Improved, RX2 auto enabled - Added, Simple hint "detailed" BB selftests - Fixed, PP extract for DP2.0 phones - Added, DCT4PLUS UEM imei read CCS - Added, Forced RX queue for better handle of dead phone flashing - Fixed, Emergency mode Image DL enabled OTHER Added Latest mxLogger client(v1.4a) in setup |
| | #20 (permalink) |
| v 3.0 beta12 is out ! November 13 2008 v3.0 Beta12 RC, Public-Release Whats NEW: MAIN - Fixed, dongle registration popup NK - DCT3 fully implemented - Fixed, BB5 flash for new phones - some improvement and minor bug fixes CCS - Fixed, 6066/88 flash |
| The Following 11 Users Say Thank You to MANOLE For This Useful Post: |
| | #21 (permalink) |
| Beta13 fixed is ready ! November 26 2008 v3.0 Beta13 RC, Public-Release Whats NEW: NK - Added "skip Restore" patch for DCT4PLUS unlock - minor bug fixes VCOM - Fixed, registration popup - Added, PK-83 Dongle emulation (you need to install CCS3 Tool first before it works) |
| | #22 (permalink) |
| Beta14 now ready ! December 08 2008 v3.0 Beta14 RC, Public-Release Whats NEW: HW - MXKEY LiTE dongle firmware version 00.14 released(Improvement dongle check, to avoid CARD BLOCKED) - Please update using SW build beta14 only. NK - Added RAP NAND option in manual erase - Added, CRC check before flashing if declared in definition files(BB5) - Image DL in background mode improved (CRC check) - minor bug fixes |
| The Following 15 Users Say Thank You to MANOLE For This Useful Post: |
| | #23 (permalink) |
| Product Manager Join Date: Nov 2003 Location: 00000000h Age: 28
Member: 43548 Status: Offline Thanks: 17
| mobileEx Setup beta15 released ! Changes: v3.0 Beta15 RC, Public-Release - MAIN help file updated minor bug fixes - NK DCTL/LINDA fully implemented with Custom erase to fix old 9210i CS problem Fixed, Image DL (server communication protocol changed) Fixed, BB5 custom certificate backup Fixed, New PP files manual upload Improved, SUPERDONGLE auth (show the detailed error msg) Improved, User code reset for BB5 phones minor bug fixes Download area for MXKEY users: http://id.mxkey.biz/downloads.php Last edited by MANOLE; 02-24-2009 at 13:32. Reason: added info for download area |
| The Following 46 Users Say Thank You to Alim Hape For This Useful Post: | ags_nadhif, alwi7666, Andra, andreiza, Audsky, ccipo, cdma-india, chan_lie, CxVj, dhiet, didin yulian, didiraden, freedomqn, gbluez, gemuuk, gobel_xxx, GSMcracker, gsmfans, haniey_x, hima010, ishwarabhi65, iwan_t, jedephone, juhal, jupizet, kamza, kasner, koka_stone, MANOLE, mohamed183, nasirns, nnamdi maduike, notgood, N_YOUNGBY, omelin, redarea, shahzaadbutt, SHANU, shimul_777, shinta, sulimanusa, sumatera, titan_wonder, trian, wayan_pdcell, yobb |
| | #24 (permalink) |
| v3.1 Beta16, Public-Release Changes: - MAIN Removed old card protocol(MXKEY REV 1.X/ROCKEY6), for this release only MXKEY REV 2.X card supported minor bug fixes - NK Fixed, loader issue Added, single phones setting (VPP,RX2, Fast checkbox now saved to config for each phone) Added, BB5 No TP Unlocker, Dejan RAP3GV2 unlocker removed. Fixed, `highlight market` bug minor bug fixes - CCS Improved, communication. Dead phones full flashing now working without errors Download area for MXKEY users: http://id.mxkey.biz/downloads.php BR. |
| The Following 22 Users Say Thank You to Alim Hape For This Useful Post: |
| | #25 (permalink) |
| Hi, All MXKEY working with last update V3.1 Beta16 will have, starting today, 1000 mxLogger credits for DCT4 RPL and for DCT4+ RPL. Old MXKEY dongle that are purchased before 1 march will not have this service for free. BR, Manole |
| The Following 60 Users Say Thank You to MANOLE For This Useful Post: | ..::M-GSM::.., abiyoso63, adelgsm, allentelecom, alwi7666, andreponsel, ask_gsm, ASK_ME, aswancamel, bijet, bledhuk, bronce, bun.prasert, dessertcell, dhaiems, didin yulian, dil_pol, doctorcel, drsty, fabicel, gilgamish, gobel_xxx, gsm4sp, GSMcracker, GsmEasy, habib jobayr, Hariadi Lianto, haroon75, hima010, htsgsm, hva8, irada, jollen_9, kamza, kiken, koka_stone, kpdahal, kristine dawn, md.suvo_khan, meer_fsn2, mohamed183, mrnazam, MULIA CELL, mwcellciputat, nasirns, nokiacareasr, obg1, P cell, redarea, Ryogusti, sanju_peter, shahzaadbutt, shahzad_786, shimul_777, smt_mamun, star_as900, sulimanusa, sumatera, TO_palopo_JI, zunair |
| | #26 (permalink) |
| v3.1 Beta16a (Patch update) Changes: NK -Fixed Online logger using "Dongle Id". Password is automaticaly sent to email address after registration/activation. The email address will be asked when registration process begin, make sure you're entering the correct email address. Download area for MXKEY users: http://id.mxkey.biz/downloads.php BR. |
| The Following 30 Users Say Thank You to Alim Hape For This Useful Post: | alwi7666, andreiza, aswancamel, barhoomh, Byte, CxVj, dany_kroya81, datux`s, denbagus, didin yulian, gobel_xxx, GSMcracker, hima010, irada, kamza, karikari, kiken, koka_stone, MANOLE, mohamed183, mwcellciputat, nasirns, neo_49, N_YOUNGBY, priyanto78, redarea, shahzaadbutt, shimul_777, ska mobile, sumatera |
| | #27 (permalink) |
| v3.2 FINAL, Public-Release - MAIN Improved Server communication Added, Support area access Goto Options->Server->Server List (make selection on 'Support') then Goto Support button will enabled - NK Added, Standalone BB5PLUS SL2 No TP Unlocker PM Auth checkbox also added for some phones which need SUPERDONGLE to be authorized while writing PM120 and PM308 Added, DCT4PLUS "on the fly" imei changes Improved, DCT4PLUS "on the fly" unlock patch (+new security also supported) Improved, PM read and write (if field not checked will be skipped) To Open PM, you can now Drag And Drop PM file to listbox Fixed, BB5 loaders bug for new phones Fixed, image download Fixed, BB5 auto set RX2 Fixed, DCT4PLUS Online Logger bug minor bug fixes - VCOM Fixed, PK-83 binary for MXKEY REV 2.0 compability #Siemens FREE module recompiled for new api & library compability. Download area for MXKEY users: http://id.mxkey.biz/downloads.php BR. |
| The Following 29 Users Say Thank You to Alim Hape For This Useful Post: | alberto_Ariel, alwi7666, Andra, Audsky, cxacxa, Feda, gobel_xxx, gsm4soltan2, gsmcambodia, GSMcracker, hima010, kamza, karikari, kiken, koka_stone, MANOLE, mohamed183, nasirns, nongmobile, pawangrover94, raychevski, redarea, roshantelecom&s, rotharo, shahzaadbutt, shimul_777, ttlin5188, xtreme_digital, ~AKSingh~ |
| | #28 (permalink) |
| v3.2 bug-fixed, Public-Release - NK DCT4 RPL server host changed, to fix timeout in some country Improved, DCT4PLUS "on the fly" unlock patch and imei patch Added, AMS loader v. 8.49.19.36652 to the installer minor bug fixes - VCOM Fixed, Active-X initialization to fix rx no respond in some pc Code: Main: » mobileEx.exe, version: 3.0.0.3182 » mobileEx.dll, version: 1.0.0.3345 Modules: » ccs.dll, library version: 1.0.0.796, module version: 1.01 B » nk.dll, library version: 1.0.0.6438, module version: 1.02 » siem.dll, library version: 1.0.0.293, module version: 1.01 B » vcom.dll, library version: 1.0.0.935, module version: 1.03 to avoid confuse to existing users, maybe we will not call any future release a final or beta Download at: http://id.mxkey.biz/downloads.php BR. Last edited by Alim Hape; 04-22-2009 at 11:18. |
| The Following 30 Users Say Thank You to Alim Hape For This Useful Post: | .::PATEL TELECOM::., alberto_Ariel, alwi7666, andreiza, Doglag, Feda, gobel_xxx, gsmcambodia, GSMcracker, hima010, irada, kalpesh.1978, kamza, koka_stone, lovingazmee, MANOLE, mobiletelecom40, mohamed183, mr khalid, mr.6630, nagendra_20061, nasirns, N_YOUNGBY, rashel.com, raychevski, rudidar, saajith, shahzaadbutt, shimul_777, zeel_zeel |
| | #29 (permalink) |
| mobileEx v3.2 revision 1.0, Public-Release - MAIN Added, UI Localization ;languages selectable from 'quote' menu ;locale files stored to 'locale\*.xml' directory ;added, Chinese (Simplified) language for test (translated using Google Translate, so am sure its not 100% correct), unicode enabled. ;full localization might be added at the future Added, balloon Tips stored to locale files Fixed, Application not opened in some PC caused by not previlege account (specially XP SP3 and Vista SP1) List of loaded drivers version are now displayed at start up Server list are now selectable Added, posibility to play custom sound on error/finish Added, Card Serial Port drivers ;allow to use serial(comport) based reader for the card Added, 'Nokia USB ROM' virtual device to be used for BB5 USB DEAD PHONE flashing Fixed, Connect<->Disconnect bug (appl. crash) - VCOM Small change in UI Changed, PK-83 binary to support new drivers - CCS Fixed, nkser(6088,6066,7088) driver handling when flashing stop at the middle of process - NK Added, BB5 USB Flashing ; Supported loaders RAP3Gv2+APE(external loader), RAP3GV3+APE, RAP3GV3 NON APE+DEAD FLASH, RAPIDO NON APE+DEAD FLASH, RAPIDO +APE, RAPIDO (RAP3NAND) NON APE+DEAD FLASH. ; Version check mechanism is possible when flashing NON DEAD phone ; LANGUAGE only option also posible for fast and safe phone update Added, Multiple version of flash update/loaders ; selectable from 'quote' menu 'Config->Directory' ; Newer phones might need newer flash loader, by default is '8.6.1.31560' Fixed, BB5PLUS RAPIDO SL2 spunlock Added, Pinout image for UFC based cable (press small button near phone image) ; pinout images are stored at 'data\image\pinout' directory Multiple Data Package directory are now possible (usefull when working with Multi-OS PC) Added, 'Force WHOLE flash' on erase(Advance Page) to allow RAP flash full erase (Last chance, if NPC reset still not work to revive DEAD/BLINK Phone) Added, PP file read Added, Phonebook/Contacts backup and restore (Phone Settings->Selection:User Settings) Removed, Host setting (please use 'select server' from Main|Server List page) - SIEM Siemens module recompiled for new api compability ------------------------------------ Download at: http://id.mxkey.biz/downloads.php or goto Support Area for existing users. PS: To go to Support Area, Go Options page->Server, push 'Server List' then select on of active server so "go to Support Area" will be enabled. |
| The Following 24 Users Say Thank You to Alim Hape For This Useful Post: |
| | #30 (permalink) |
| v3.2 revision 1.1, Public-Release #Patch update - NK Fixed, Online Logger not shown when 'Imei changes' disabled. Fixed, BB5 Restore Imei+Write RPL Download at: MXKEY - Official Mirror (rapidshare) http://rapidshare.com/users/P5JHS5 will also available in support area and download page. BR. |
| The Following 28 Users Say Thank You to Alim Hape For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| [MXKEY - NEWS] MXKEY Support Area | Alim Hape | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 186 | 08-19-2010 20:26 |
| how to update latest software updates by mxkey | abdulqadir_eee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-22-2010 17:51 |
| NEWS MXKEY Software Updates 100% Download | amir hossain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 06-17-2009 06:59 |
| motorola software update locked my motokrzr k1 | martindale024 | P2k Series | 0 | 05-01-2008 02:20 |
| COOL NEWS : software update for moto | Aymen G | P2k Series | 4 | 08-18-2006 07:45 |
