mxkey nokia c1-01 flash problem sir.i am unable to flash nokia c1-01 with usb micro cable.please solution my problem. |
How can ask for help without Buscheck Logs & details of Phone condition. BR, ZUBER |
is xgold bb5 tab and untick safe flash go do the job done. next time post here screen shot give better help understand. BR. Arsalan gsm2000. |
nokia c1.00 showing error during flashing MXKEY Serial: [FT SCR2000 0] - C0811099 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UHCI:HUB:HUB:UFS2XX, ver: 2.0.0.0 , NTMP ver: 2.0.0.1 Module ver: 1.0.0.17841(12-07-2011), Library ver: 1.0.0.14214(25-10-2012) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921600 could not read flash id ! Task failed at (08000024)!!! Last RX buffer: 4E 02 03 00 |
use ufs3 with usb cable |
2. You are modified mobileex, crossed module is very buggy. 3. Support for other FBUS interface is ended. - get HTI, do your job with mobileex current version. |
