Old 10-07-2012, 16:27   #1 (permalink)
Member: 1813549
Sonork: DJ PARVEZ
Thanks Meter: 2
mxkey nokia c1-01 flash problem
sir.i am unable to flash nokia c1-01 with usb micro cable.please solution my problem.
Old 10-07-2012, 16:55   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
How can ask for help without Buscheck Logs & details of Phone condition.
BR,
ZUBER
Old 10-07-2012, 17:22   #3 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,136
is xgold bb5 tab and untick safe flash go do the job done.
next time post here screen shot give better help understand.
BR.
Arsalan gsm2000.
Old 12-26-2012, 13:52   #4 (permalink)
sskanwal's Avatar
Member: 1380808
Sonork: askanwal
Thanks Meter: 10
nokia c1.00 showing error during flashing
MXKEY Serial: [FT SCR2000 0] - C0811099
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Driver: UHCI:HUB:HUB:UFS2XX, ver: 2.0.0.0 , NTMP ver: 2.0.0.1
Module ver: 1.0.0.17841(12-07-2011), Library ver: 1.0.0.14214(25-10-2012)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921600
could not read flash id !
Task failed at (08000024)!!!
Last RX buffer: 4E 02 03 00
Old 12-26-2012, 13:52   #5 (permalink)
sskanwal's Avatar
Member: 1380808
Sonork: askanwal
Thanks Meter: 10
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
Old 12-26-2012, 13:55   #6 (permalink)
Crazy Poster
Member: 681159
Thanks Meter: 5
use ufs3 with usb cable
Old 12-26-2012, 14:00   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
1. You are using an ancient version of mobileex.
2. You are modified mobileex, crossed module is very buggy.
3. Support for other FBUS interface is ended.
- get HTI, do your job with mobileex current version.
Old 12-27-2012, 20:14   #8 (permalink)
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,136
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
1st Select Nokia Usb Rom It's Dead Usb Mode Select Market Firmware Unchecked Safe Mode Than Hit Flash Hit Usb That's All.
BR.
Arsalan gsm2000.
Page generated in 0.23593 seconds with 7 queries
