Old 06-06-2011, 17:59   #1 (permalink)
Member: 599037
Thanks Meter: 103
Exclamation mxkey read wrong codes via bf???? (ANSWERED)
hi team i just uploaded a job and it got finished in 2 or 4 seconds and supplied he wrong coes.. plz chk following..
Imei net: 357978035099866
Version: SIMLOCK SERVER
Provider: Optus Mobile Pty. Ltd. , Country: Australia
Counter: 2/3, 2/10
CONFIG_DATA: 5050200000000000
PROFILE_BITS: 8000000000000000
BLOCK1: 1=CLOSED(MCCMNC), DATA=50502F [Australia-Optus Mobile Pty. Ltd. ]
Reseting LOCK Counter ...OK.
Counter: 0/3, 0/10
Erasing NCK ...OK.
Counter: 0/3, 0/10
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7
#pw+ 574752021519015 +1 #
#pw+ 055731246508904 +2 #
#pw+ 306226316406425 +3 #
#pw+ 142658208062495 +4 #
#pw+ 954130603777857 +5 #
#pw+ 206693950910540 +6 #
#pw+ 149896625795172 +7 #
Codes file saved to: C:\mobileEx\3.5\data\SL3\357978035099866_SP_CODES.txt
Sending NCK code ...
Trying NCK lock 7 ...FAILED: wrong code
Trying NCK lock 6 ...Trying NCK lock 5 ...FAILED: wrong code
Trying NCK lock 4 ...Trying NCK lock 3 ...FAILED: not ready
Trying NCK lock 2 ...FAILED: wrong code
Trying NCK lock 1 ...
Reading Simlock info ...
Counter: 0/3, 3/10
#pw+ 761569325749849 +1 #
#pw+ 343630043779289 +2 #
#pw+ 611817210163293 +3 #
#pw+ 030672270095323 +4 #
#pw+ 574121180838332 +5 #
#pw+ 905556599832166 +6 #
#pw+ 297433483543850 +7 #
Trying NCK lock 6 ...Trying NCK lock 5 ...FAILED: not ready
Trying NCK lock 4 ...FAILED: wrong code
Trying NCK lock 3 ...Trying NCK lock 2 ...FAILED: not ready
Trying NCK lock 1 ...FAILED: not ready
Counter: 0/3, 5/10
what shud i do??
Old 06-07-2011, 17:07   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
hi,
please use our alternative free cod converter
http://www.mx-key.com/mxkeysl3freecodecalculator.php
input the result manually.
Old 07-06-2011, 02:03   #3 (permalink)
bettsy's Avatar
Member: 53422
Thanks Meter: 20
link is dead...............................
The Following User Says Thank You to bettsy For This Useful Post:
Old 07-06-2011, 04:15   #4 (permalink)
budukbol's Avatar
Member: 638371
Thanks Meter: 52
Originally Posted by gbluez View Post
hi,
1st 0ption is as writen above, if it still wrong code,
the 2nd option is go to data, and in sl3 folde delete the lbf result XXXXXX.COD and continue3 the bruteforce
sometime when grapic card memory overload, LBF shows task finish, but when
you open the COD file via note pad and observe is lots of zeroes like this
3582410xxxxxxxx
[TARGET_HASH]
B518E03565E73A39C09FB3E13B5A140DF8Exxxxx
[MASTER_SP_CODE]
000000000001000700030000000804
its a wrong code
The Following User Says Thank You to budukbol For This Useful Post:
Old 07-06-2011, 04:39   #5 (permalink)
bettsy's Avatar
Member: 53422
Thanks Meter: 20
use 3.4 1.2 to calc the code. for the cod
tested by me working.
why does 3.5 1.0 give the wrong code?
and why is the calc link dead?
Old 07-07-2011, 21:42   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
hi,
yes. no more free services for NON MXKEY users.
use HTI, all be done locally.
The Following User Says Thank You to gbluez For This Useful Post:
Old 07-07-2011, 23:52   #7 (permalink)
bettsy's Avatar
Member: 53422
Thanks Meter: 20
yeah but why are wrong codes generated with 3.5 1.0 when calculating the cod for a nokia 2730?
if i used 3.4 1.2 on another pc (without hti) it gives the right code?
can this be looked into?
Old 07-08-2011, 01:43   #8 (permalink)
Member: 1559039
For me when I had HTI conected, mobileex used local nck calculator and it had calculated wrong codes, it did't worked, but when I used online loger and connected to server using mx-key and calculate NCK online the codes was always corect. Use online it works.
BR.
Old 07-08-2011, 01:56   #9 (permalink)
Member: 1112585
Sonork: 100.1645028
Thanks Meter: 89
Always use the most latest Revision suite.
This will help you & will help TEAM.!
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 13:52
PIN1/PIN2 CODE Jon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-26-2012 03:40
Eeprom reading KLImax Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-22-2011 15:55
5110 Security Code Help! cahrisma Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 07-05-2010 09:04
Page generated in 0.32460 seconds with 8 queries
