Old 02-06-2010, 09:41   #1 (permalink)
CDMA_RASHID's Avatar
Member: 821646
Thanks Meter: 507
Mxkey sd repair solution[SOLVED]
The Mxkey SuperDongle repair solution isn't working. don't know because of fake solution or due to some bugs the solution posted by Mr.MANOLE by writing the HWC , CCC and etc. is not working too actually there is no issue of HWC and CCC part because tested the same thing on same phone with UB box and had no issue in repairing sd or pm auth after sd repair.
here is the log.
check with ub.
here is the check with Mxkey.
here is the sd repair with Mxkey.
log after sd repair.
here is the super sd auth after repair.
Luckily had rpl backup before sd repair, and erased the phone.
here is the erased log with Mxkey.
After erasing it flashed with latest version and restored the RPL which was backuped before .
log after RPL restore.
After flash phone in same state. Restarting
After which I tried to repair the same with ub but costing credits.
here is the ub log for sd repair.
here is the pm auth after sd repair which is perfect means there is no issue with handset's HWC, CCC etc.
Old 02-06-2010, 09:43   #2 (permalink)
Member: 821646
Thanks Meter: 507
here is the pm writing.
here is the Mxkey log after sd repair with Ub.
please Mr.MANOLE can you fix this bug.
Old 02-06-2010, 10:01   #3 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
no need ub just use mx key all is well update is ready just calculate SD And write pm all ok . dont support ub here becoz Mx key Best Forever
Old 02-06-2010, 10:07   #4 (permalink)
Member: 821646
Thanks Meter: 507
Here are the two sd repair files created by ub and Mxkey there should be some thing wrong in the sd repair file.
Hope Mxkey team help us all.
thanks.
File Type: rar sd files.rar (542 Bytes, 83 views)
The Following 2 Users Say Thank You to CDMA_RASHID For This Useful Post:
Old 02-06-2010, 10:11   #5 (permalink)
Member: 821646
Thanks Meter: 507
I know the sd repair update is ready with Mxkey but I think you haven't heard about the sd verify error after sd repair the above post is regarding that error
not about repairing sd.
please read carefully and post.
Old 02-06-2010, 10:17   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
Repair SUPERDONGLE
br,
Old 02-06-2010, 10:17   #7 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
Luckly we have Manole on our side....
Now, they(MX-KEY TEAM) made it perfect SD repairing work like chams...
Go,Go,Go MX-KEY TEAM...
br.
Old 02-06-2010, 10:25   #8 (permalink)
Member: 821646
Thanks Meter: 507
Originally Posted by MobileEx-Team View Post
yes sir i can see that but what about sd verify error your method is working only on sl-1 and no success with sl2 and sl3 only sd verify error cant write pm after sd repair.
Old 02-06-2010, 10:27   #9 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
can u try again right now
and post result and log info here
br,
Old 02-06-2010, 10:37   #10 (permalink)
Member: 821646
Thanks Meter: 507
sure,
Have another 5220 with sd damaged ill try and post the logs.
Old 02-06-2010, 11:17   #11 (permalink)
Member: 821646
Thanks Meter: 507
WOW.
Thanks. Mxkey team
really fast response.
successfully repaired sd right now.
Thanks for the support.
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair MANOLE MXKEY Nokia Flasher and Unlocker (by Alim Hape) 629 07-07-2010 07:15
3110 not charging problem solved by sd repair thanks mxkey SanjanMobile MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-16-2010 16:55
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair akashub MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-06-2010 10:30
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair MANOLE Service Products News & Updates 0 02-06-2010 10:10
Solution who have incounter after SD repair Mx-key Contact Service Solve by Cyclone Code:L.A 22 Nokia Base Band 5 ( BB-5 ) 3 02-04-2010 16:27
Page generated in 0.20823 seconds with 10 queries
