Old 02-06-2010, 08:24   #1 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,949
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
We solved some bugs on server side at first SX4 Auth when phones had bad PM uploaded (e.g. PM308 from another phone, empty PM308, ...)
Now all SD repair should work well.
Here is general repair procedure.
It will repair any phone (SL1, SL2) with any kind of damaged PM, except phones with RPL NPC damaged (IMEI 123456....).
It will repair ONLY SD (not Simlock) for supported hashes "pure SL3" based phones.
1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309)
2. make Simlock RPL repair
3. make SD RPL repair
4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model
5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, can get from here:
http://rapidshare.com/files/34542441...e_by_MxKey.zip
http://www.mediafire.com/file/2hijdm...e_by_MxKey.zip
http://www.4shared.com/file/21610198...thout_NPC.html
http://www.megaupload.com/?d=2MSDVYSY
Please report your results in this thread.
Manole
The Following 793 Users Say Thank You to MANOLE For This Useful Post:
Old 02-06-2010, 08:31   #2 (permalink)
Member: 352189
Thanks Meter: 130
7210c nice working SUPER SD AUTH.
but security test failed not solved...
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 05.20 15-10-08 RM-436 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Restarting phone ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 16, size 86 bytes written.
- Key: 18, size 86 bytes written.
- Key: 20, size 86 bytes written.
- Key: 25, size 4 bytes written.
- Key: 29, size 6 bytes written.
- Key: 34, size 80 bytes written.
Section: 2
- Key: 0, size 432 bytes written.
Section: 4
- Key: 0, size 1 bytes written.
- Key: 1, size 64 bytes written.
- Key: 3, size 10 bytes written.
- Key: 4, size 8 bytes written.
- Key: 5, size 8 bytes written.
- Key: 6, size 8 bytes written.
- Key: 9, size 5 bytes written.
- Key: 18, size 80 bytes written.
- Key: 19, size 4 bytes written.
Section: 8
- Key: 0, size 12 bytes written.
- Key: 1, size 12 bytes written.
- Key: 2, size 128 bytes written.
- Key: 3, size 128 bytes written.
- Key: 6, size 4 bytes written.
- Key: 7, size 8 bytes written.
Completed in 0.843 s
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1C70020464827D56F6F896063B7E8FAEF0C5B3BE
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 35318003022777
Original Product code: 0566814
Bluetooth ID: 00247CE925C6
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 05.20 15-10-08 RM-436 (c) Nokia
Imei plain: 35318003022777-4
Product Code: 0514950
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 353180030227774
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following 40 Users Say Thank You to great4nara For This Useful Post:
Old 02-06-2010, 08:35   #3 (permalink)
mujahid_ali's Avatar
Member: 547967
Thanks Meter: 646
Manole
Hello
hope this solution will work and solved all Security Test Fail! Problem
Thanxs
The Following 12 Users Say Thank You to mujahid_ali For This Useful Post:
Old 02-06-2010, 08:38   #4 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
thankx mr.manole all is well
Using device: J.A.F, FW ver: 01.B1
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1C5001049A607A567A92F527A1DC95D16F875343
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
FlashID0: 0001 0041 - 0000 6A21 [AMD ] type: NOR,RAP
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90
RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
Original Imei: 35351102577302
Original Product code: 0554543
Bluetooth ID: 002108181145
Phone Type: RM-217 (Nokia 6300)
SW Version: V 07.30 07-05-09 RM-217 (c) Nokia.
Imei plain: 35351102577302-8
Product Code: 0546631
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353511025773028
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
The Following 13 Users Say Thank You to ..::Rizwan::.. For This Useful Post:
Old 02-06-2010, 08:38   #5 (permalink)
Code:L.A 22's Avatar
Member: 990900
Thanks Meter: 539
another link please 4shared.com. mediafire i cannot download to rapidshare
The Following 2 Users Say Thank You to Code:L.A 22 For This Useful Post:
Old 02-06-2010, 08:42   #6 (permalink)
bipugunjan's Avatar
Member: 526223
Sonork: 100.1605395
Thanks Meter: 106
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 202.56.7.142
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
plz help
The Following 6 Users Say Thank You to bipugunjan For This Useful Post:
Old 02-06-2010, 08:42   #7 (permalink)
obioha's Avatar
Member: 121356
Thanks Meter: 73
thanks manole i always know that you must deliver the right solution.thanks for the hard work
The Following 6 Users Say Thank You to obioha For This Useful Post:
Old 02-06-2010, 08:43   #8 (permalink)
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
thankx mr manole all is well
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 12800211FD1603541E3D0AE67FBE6F0A7A9C44D2
ASIC MODE ID: 00
FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP
RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B
Original Imei: 35366201619972
Original Product code: 0563614
Bluetooth ID: 0021ABEDB9F0
Phone Type: RM-411 (Nokia 5220 XpressMusic)
SW Version: V 07.23 17-07-09 RM-411 (c) Nokia
Imei plain: 35366201619972-1
Product Code: 0563611
Language Pack:
- not available.
SIMLOCK_TEST passed
TimeStamp: 2009-07-22T07:56:36Z
SW Version: 07.23
Variant Version: 008
ProductProfile: RM411_0563611_07.23_008.spr
Simlock: 0563611_simlock.bin
Imei net: 353662016199721
Counter: 0/3, 0/10
The Following 6 Users Say Thank You to ..::Rizwan::.. For This Useful Post:
Old 02-06-2010, 08:44   #9 (permalink)
swechacnu's Avatar
Member: 115144
Sonork: 100.1590698
Thanks Meter: 498
Here is the Another Link
http://www.sendspace.com/file/ust557
The Following 3 Users Say Thank You to swechacnu For This Useful Post:
Old 02-06-2010, 08:44   #10 (permalink)
vodafoneserver's Avatar
Member: 617174
Sonork: 100.1622609
Thanks Meter: 579
Good solution ................
The Following User Says Thank You to vodafoneserver For This Useful Post:
Old 02-06-2010, 08:45   #11 (permalink)
Moderator
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
Thanks Meter: 787
http://www.mediafire.com/file/32jlub...e_by_MxKey.zip
The Following 3 Users Say Thank You to loca|host For This Useful Post:
Old 02-06-2010, 08:45   #12 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
More links added in first post.
The Following 20 Users Say Thank You to MANOLE For This Useful Post:
Old 02-06-2010, 08:47   #13 (permalink)
marcdashale3126's Avatar
Member: 580978
Thanks Meter: 35
problem solve
Product: V 07.23 17-07-09 RM-436 (c) Nokia
Section: 1
- Key: 2, size 70 bytes written.
- Key: 3, size 70 bytes written.
- Key: 4, size 70 bytes written.
- Key: 6, size 276 bytes written.
- Key: 7, size 276 bytes written.
- Key: 8, size 276 bytes written.
- Key: 10, size 384 bytes written.
- Key: 11, size 384 bytes written.
- Key: 12, size 384 bytes written.
- Key: 14, size 384 bytes written.
- Key: 15, size 384 bytes written.
- Key: 16, size 384 bytes written.
- Key: 17, size 32 bytes written.
- Key: 19, size 16 bytes written.
- 120 skipped
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
- Key: 22, size 12 bytes written.
Completed in 1.875 s
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35574302231725-5
Product Code: 0566807
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 355743022317255
Counter: 0/3, 0/10
thanks problem solve
The Following 8 Users Say Thank You to marcdashale3126 For This Useful Post:
Old 02-06-2010, 08:47   #14 (permalink)
Member: 923652
Sonork: 1601428
Thanks Meter: 89
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.91 29-10-09 RM-495 (c) Nokia
Imei plain: 3552320*******-0
Product Code: 0578115
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
SIMLOCK invalid!
SIMLOCK_TEST failed!
SIMLOCK_DATA corrupted!
this phone sl3 5130c-2 not supported yet
correct me if im wrong???
thanks for bugs repair! mr. manole
The Following 4 Users Say Thank You to ilaw For This Useful Post:
Old 02-06-2010, 08:47   #15 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,435
thanks sir unforunatly log not saved cause power cut
but set 7210c ok now
Imei plain: 35931002587683-0
Product Code: 0566806
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 359310025876830
Counter: 0/3, 0/10
The Following 10 Users Say Thank You to sneha For This Useful Post:
1000% All Sl1 & Sl2 Solved "SECURITY_TEST failed!" after SD repair jonysant MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 07-18-2010 15:58
[MXKEY - SERVER UPDATE] Solved "Bad phones ack on step1" for so called "SL3" MANOLE MXKEY Nokia Flasher and Unlocker (by Alim Hape) 164 05-05-2010 12:17
[MXKEY - SERVER UPDATE] Solved "Bad phones ack on step1" for so called "SL3" MANOLE Service Products News & Updates 0 02-07-2010 22:17
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair akashub MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-06-2010 09:30
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair MANOLE Service Products News & Updates 0 02-06-2010 09:10
Page generated in 0.67312 seconds with 9 queries
